iCloudin Review: Where to Download? How to Use? [Full Review]
In this article, we will review iCloudin, a free tool to bypass the activation lock. We will explore where to download it and how to use it. Also, we will walk you through an effective step-by-step guide for effective results. So, if you are someone who is stuck out of his iPhone/Ipad due to an iCloud activation lock, this guide is for you.
Author Avatar Joy Taylor Last Updated: Dec. 14, 2023
Are you facing the activation lock issue on your iPhone or iPad? Do you want a simple solution to unlock your iOS device? If yes, then you are at the right place.
Many iPhone users get stuck on the activation lock screen without knowing how to bypass it. However, tools like iCloudin are a blessing in disguise for this situation. In this article, we are going to introduce you to the iCloudin tool. We will see where to download iCloudin and how to use it to bypass the iCloud activation lock. So just keep reading this iCloudin review.
What Is iCloudin?
iCloudin is a tool that helps users to unlock the activation lock of their iPhones/iPads. The activation lock is a security feature incorporated into Apple devices. It prevents unauthorized access if any iOS device gets lost or stolen.
However, when you factory reset your iPhone or iPad, you may forget your Apple ID and password and thus get stuck on the iCloud activation lock. At this time, you may need a tool like iCloudin to bypass it. So here we have introduced the key features of this tool to help you learn more about it.
iCloudin Software Interface
Key Features of iCloudin
  • iCloud Activation Lock Bypass: iCloudin is designed to bypass the iCloud activation lock. It allows users to access their iOS devices even when they forget their Apple ID.
  • User-Friendly Interface: The iCloudin software offers a simple and easy-to-use interface. This makes it accessible to users with different skill sets.
  • Device Compatibility: iCloudin is compatible with various iPhone/iPad models. It provides an effective solution for a broader audience.
  • No Technical Skill Required: Users don’t need to have special skills to use iCloudin. The process is straightforward.
  • Free to Use: iCloudin is available for free. It is best for those looking to unlock their iOS devices without spending money.
Now that we know what is iCloudin and also have explored its features. Let’s move forward and see how to download and use it.
How to Use iCloudin?
Although iCloudin solves a frustrating issue, many users worry it might be difficult to use. However, using iCloudin to remove the activation lock from iPhone or iPad is very simple. Don’t let doubts hold you back! Walk through our step-by-step guide to learn using iCloudin.
You can follow the instructions given below to bypass the activation lock using iCloudin:
Step 1. Free download iCloudin from a trusted website. Then extract the program files from the ZIP file to install the software. (You can also use iCloudin tool online)
Download the iCloudin App
Step 2. Ensure that you have the latest version of iTunes installed on your computer. If not, then install the latest version.
Step 3. Now connect your iPhone/iPad to the computer via a USB cable.
Step 4. Once the iOS device is successfully connected, open iCloudin and click “Host’s file IMEI.”
Step 5. You will see a new window pop up. Now find the iCloudin folder and click “Hosts_Activation_IMEI.java.”
Step 6. Right after selecting the file, unlocking the Activation lock process will start. You will also see a progress bar to track the process.
When the progress bar reaches the end, it means that the Activation lock has been removed. You can check your phone whether it is unlocked or not.
Now that we have seen the steps of using iCloudin, let’s talk about its pros and cons.
Pros and Cons of iCloudin
Every Software has its pros and cons so does iCloudin. It is best for users who got successful in the purpose. On the other hand, it could be a waste of time for those unable to remove the activation lock. If you are about to try it, you can have a look at the pros and cons and decide whether it seems good or not.
Pros:
  • iCloudin has a user-friendly interface that makes it accessible to all users.
  • It is available for free. You don’t have to pay anyone to bypass the activation lock.
  • It supports a wide range of iPhones and iPads with various iOS versions.
  • It provides a guide within the Software interface for users who are not tech bees.
Cons:
  • It is only available for Windows. There is no Mac version available.
  • It requires iTunes, so you must have the latest version of iTunes installed on your computer.
If you have tried iCloudin, but failed to bypass the iCloud activation lock, then you need an alternative. So here we also get you the other solution to solve your problem. Let’s explore it together!
Best Alternative to iCloudin – AnyUnlock
Getting stuck at the activation lock screen is a new common among iPhone/iPad users. It is frustrating when you can’t remember your Apple ID credentials. Whereas the only solution to access your device again is to bypass the activation lock. iCloudin can help you do that. However, in case you fail with iCloudin, we have got you an amazing alternative, which is AnyUnlock – iPhone Password Unlocker.
This tool offers an easy yet effective solution to remove the iCloud activation lock. Compared with iCloudin, AnyUnlock works well on both Windows and Mac, so you don’t need to worry about the compatability. And the best part is its intuitive interface makes you bypass iCloud activation lock in just a few clicks. And you can learn more about its main features.
  • Only 3 steps – You can bypass iCloud activation lock only in 3 simple steps. There are no complicated operations.
  • No need to wait – You only need to spend 5 minutes to quickly remove iCloud activation lock. Save your precious time as much as possible.
  • 100% security guarantee – AnyUnlock does not contain any malware or viruses. And while unlocking, your privacy and device data will not be disclosed to anyone.
  • Not just iCloud lock – AnyUnlock can also help you find Apple ID, check device lock status, unlock screen lock, remove MDM, unlock SIM card, and more.
Before starting, free download and install AnyUnlock on your Windows or Mac. Then follow the instructions given below:
Step 1. Launch AnyUnlock on your computer and choose Bypass iCloud Activation Lock mode.
Step 2. Now, connect your iPhone/iPad to the computer via a USB cable. Once it is recognized, click Start Now. Then tap on Jailbreak Now to jailbreak your iOS device.
Click Start Now Button
Connect Your iOS Device to the Computer
Step 3. Once the Jailbreak is done, click Bypass Now to proceed.
Click Bypass Now Button
Step 4. AnyUnlock will start bypassing the iCloud activation lock. When the process is finished, you will see the below interface. Click Done to return to the home page.
iCloud Activation Lock Is Bypassed Successfully
FAQs About iCloudin
Q. Does iCloudin really work?
Yes. iCloudin is a very popular tool for iCloud activation lock, and many users reported that it is effective to help them bypass the iCloud lock.
Whereas there are still some users responding that they got stuck in the middle.
While we are not stopping you from trying iCloudin, we recommend you use AnyUnlock for efficient results if you have failed with iCloudin.
Q. Is iCloudin free to use?
Yes, iCloudin is a free Software. This means you can download and use it without paying any fee. However, choosing the right platform to download the software is essential.
There are tons of fake iCloudin Software available on the internet. They contain a lot of viruses that can be harmful to your system and data. So please make sure you download this tool from the official website.
No doubt, iCloudin offers a solution to bypass the activation lock. However, in case you fail with it, you’d better get an alternative. And AnyUnlock must be your best choice. It helps you bypass iCloud activation lock in minutes and easy steps. And it also provides better support and prioritizes user security. What’s more, AnyUnlock also offers features like removing SIM lock, unlocking screen passcode, unlocking screen time, and more. So, free download AnyUnlock today and get a complete solution to many of your iOS-related problems.
