How to Unlock iPhone with Emergency Call Screen [Guide]
Are you locked out of your iPhone? Don’t panic! Our stepwise guide will show you how to unlock iPhone with emergency call screen or even without it.
Author Avatar Joy Taylor Last Updated: Sep. 03, 2024
AnyUnlcok – Unlock iPhone without Password in 1 Click
Forgot your iPhone password? Don’t worry. Free download AnyUnlock to unlock iPhone screen lock, like digital passcode, Touch/Face ID, PIN, etc. Only 3 steps and 1 click. And all iPhone models and iOS versions are supported, including iPhone 15 and iOS 17.
Have you ever forgotten your iPhone passcode? It’s a pretty common problem that many people face. But if you have an older version of the iPhone, you don’t have to panic at all. There’s a magic trick to unlock iPhone using emergency call hack.
So if you want to find out how to unlock iPhone with emergency call screen, you are in the right place. And even if you have the latest iPhones, we’ve also covered you with possible unlock solutions. Let’s get started right away!
Also Read: You may also use emergency call unlock Android, for details steps, you can read How to Unlock Any Phone Password Using Emergency Call >
Can You Unlock iPhone with Emergency Call Screen
Considering Apple’s security, whether we can unlock iPhones with an emergency call screen is still questionable. So let’s get rid of this query first.
The answer is Yes. But it depends on the iOS version your device is running. For the old iOS version 6.1, it might be a viable option to use emergency code to unlock disabled iPhone. But be aware that this trick is no longer effective in later iOS versions. Apple has already fixed this loophole.
And it’s also worth noting that even though the emergency call trick may work on an iOS 6.1 iPhone, it only grants limited access. You can have access to your photos, phone dialer, and contacts. But attempting to access other features of your iPhone will take you back to the screen lock. Other solutions might be a better fit for complete access to your phone’s data. Then, let’s see how to unlock iPhone passcode without computer using emergency call.
How to unlock iPhone 6 with emergency call screen? If your iPhone is running iOS 6.1 you can unlock iPhone using emergency call hack. If not, just skip this part and we’ll reveal some other solutions for the latest iOS versions below. Here are the steps on how to bypass iPhone lock screen using emergency call.
Step 1. Start by unlocking your iPhone and entering any passcode. On the passcode screen, tap “Cancel.”
Tap on the Cancel Button
Step 2. Slide to unlock your iPhone once more and open the “Emergency Call” feature by tapping it.
Step 3. Now press & hold the Power button until you see the “Slide to power off” slider. But don’t slide it off. Instead, tap “Cancel.”
Step 4. Dial 112 or 119 and tap the emergency call button. Without waiting, tap “Cancel” and turn off the screen by pressing the power button once.
Step 5. Tap either the Home or Power button to wake up your iPhone. Then, slide to unlock the device.
Step 6. Hold the power button for 3 seconds, and before the “Slide to power off” appears on the screen, tap “Emergency Call.” Your iPhone should be accessible now!
But as mentioned earlier, you can’t expect this magic trick to work on the latest iOS versions.
So is there an alternative to unlock the iPhones running on the latest iOS versions? Of course, there is! Let’s jump into it now!
Best Alternative to Unlock iPhone with Emergency Call Screen
Although you can’t unlock the latest iPhones with an emergency screen, there is a fantastic tool to help you. It’s no other than the world’s leading iPhone unlocker – AnyUnlock. With this tool, unlocking your iPhone, iPad, or iPod touch has never been easier. With simple steps, you can remove any passcodes on your device without technical knowledge. And even the latest iOS versions are supported by AnyUnlock. You can learn more about it below.
  • Unlock all iOS screen locks – It can support unlocking any iOS lock screens, such as fingerprint, face recognition, digital password, pattern, PIN, etc.
  • Unlock in 3 easy steps – You just need to tap the button to unlock your device in a few simple steps. There are no complicated operations.
  • No waiting – It only takes a few minutes to unlock. Allows you to get back into your phone as quickly as possible.
  • Highest Compatibility – Supports all iOS versions. Covers all iPhone and iPad models.
You can trust the expert team with 10 years of experience, who have helped over 100,000 users. Moreover, AnyUnlock is reliable and uses advanced technology to guarantee the highest success rate. AnyUnlock can also help you out if you are stuck in other iOS locks, like MDM lock, Apple ID, iCloud activation lock, SIM lock, and more.
Just free download AnyUnlock and here is the stepwise guide to unlocking your iPhone using AnyUnlock.
Step 1. Install and open the latest version of AnyUnlock on your computer. Select Unlock Screen Passcode mode from the opening interface.
Choose Unlock Screen Passcode
Step 2. Now connect your device to your computer and click the Start Now button to proceed.
Click Start Now Button
Step 3. AnyUnlock will automatically provide you the suitable firmware for your iPhone. Confirm the details on the screen and hit the Download button to download the firmware.
Get Matching Firmware for iPhone 13
Step 4. After the downloading of your firmware package is complete, click on the Unlock Now button.
Tap on Unlock Now
Tap on Unlock Now
Step 5. Now wait until the process finishes; you’ll see the following interface when it succeeds. Click on the Done button and use your unlocked device.
Now if you don’t want to use any third-party tool, we’ve also got you covered with some other methods. So let’s move forward and see “Find My” feature of Apple can help us unlock our iPhones.
How to Unlock iPhone with Find My Feature
The iPhone Find My feature is a security feature designed by Apple to help you protect your lost or stolen iPhone. With this, you can track the location of your device in real-time, even if the phone is offline. On top of that, the Find My feature enables you to lock or erase your device remotely.
The feature is available on iPhones running iOS 13 or later. And we can make use of this iPhone feature to unlock our devices. Here are the steps for you to follow.
Step 1. Visit the official iCloud website and sign in with the same Apple ID as on your iPhone.
Step 2. Now click on the “Find iPhone” feature.
Step 3. Click on the “All Devices” button at the top of the screen. Now select the iPhone you want to unlock from the dropdown.
Step 4. You’ll see multiple options on the screen. Click on “Erase iPhone” to unlock your device.
Tap on the Clock Icon at Top
Tap on the Erase iPhone Option
This process will erase your device. Then you can start it up from scratch and use it however you want.
Let’s keep the momentum going and see the next method on our list.
How to Unlock iPhone with iTunes
iTunes is a media player and library application developed by Apple. But along with its media player functions, it can also be used to sync content between your computer and Apple devices. And if you’ve done so, you can easily unlock your iPhone with iTunes.
But remember that the “Find My” feature must be turned off if you don’t want to use the Apple ID and password. Follow these simple steps to unlock the iPhone with iTunes.
Step 1. You’ll need a computer with the latest iTunes installed to unlock your iPhone using iTunes. Now connect your iPhone to the computer with a connection cable.
Step 2. Put your device in recovery mode. The process may differ depending on the model of your device.
Step 3. Now launch iTunes on the computer, and you’ll see a prompt on the screen. Click on the “Restore” button.
Click Restore iPhone
Step 4. Again select “Reset and Update” and wait until iTunes download the latest firmware for your iPhone.
Step 5. After the download of firmware is complete, your device will start resetting. When it’s done, you’ll see the Hello screen of the iPhone.
If the firmware download takes more than 15 minutes, your device will exit the recovery mode. And it’s necessary to reenter recovery mode using the same steps.
But if you still encounter some issues, then try unlocking your iPhone with Siri.
How to Unlock iPhone with Siri
Siri is more than just an ordinary personal assistant for iOS users. It’s an intelligent & capable companion that can help iOS users in many ways. And di you know that you can also unlock your iPhone without a password using Siri?
Well, it’s only possible if your iPhone has iOS 10 and an active internet connection with Siri enabled. But still, it’s possible!!! Here are simple steps to unlock iPhone with Siri.
Step 1. Long-press the home button and ask Siri, “Hey Siri, what time is it?” In a flash, a clock will appear. Simply tap it and hit the plus button at the top right corner.
Step 2. Type any characters in the search box. Then double-tap the name you entered and click on “Select All.”
Unlock Any iPhone via Siri
Step 3. Select the “Share” option and then choose the “Message” app.
Step 4. To proceed, tap any character in the “To” field on the message page, and press the “return” key.
Step 5. Hold on for a moment and hit the home button. That’s it; your iPhone will be unlocked now!
If even this method fails, we’ve still got a last solution.
How to Unlock iPhone with Apple ID
If you use iOS 15.2 or later versions, unlocking your iPhone is just around the corner. Just ready your Apple ID credentials and use the security lockout feature of your iPhone to erase your device. But you’ll need an active internet connection for this process. Here are the instructions you can follow in a step-by-step manner.
Step 1. Put your iPhone in the security lockout by repeatedly entering the wrong password.
Step 2. Tap the “Erase iPhone” button at the bottom right corner of your iPhone.
Step 3. Then, tap the “Erase iPhone” button again and enter your Apple ID password.
Add iCloud Credentials and Erase iPhone Data
Add Apple ID Credentials and Erase iPhone Data
Step 4. Wait until your device resets, and you see the Hello screen. Now you can set up your iPhone from the start.
It’s easy to forget your iPhone passcode, but it doesn’t have to be a hassle. If your iPhone runs on iOS 6.1, try to unlock iPhone using emergency call hack. In this guide, we have shown you how to unlock iPhone with emergency call screen. But if you have a later version of iOS, we highly recommend you try AnyUnlock for free to unlock your device with simple clicks.
