How to Unlock iPhone with Broken Screen [Full Guide]
“I broke the phone and he accidentally entered the wrong password many times, which is why the phone is locked, it says that the iPhone is not available, I remember the Apple ID and a password, is it possible to unlock it somehow? There is very valuable data for me.” – An iPhone user asked.
Author Avatar Joy Taylor Last Updated: Jan. 22, 2025
AnyUnlock –  Unlock Broken iPhone Without Password
AnyUnlock allows you to remove the broken screen passcode so that you can access your device. No worry about your iPhone touch screen issues when it is broken. Support the latest iPhone 16 and iOS 18.
If you are encountering the iPhone screen is broken how to fix issue, this article is what you may need. Here we will discuss the possibility of unlocking a broken iPhone with or without data loss, depending on how severe the broken screen is. Sometimes your iPhone passcode not working due to the broken screen, which makes it complicated to unlock. Don’t worry, no matter what case you are in, you can find an effective way to solve the broken iPhone unlock.
Related topic: How to recover data from a broken iPhone
Can You Unlock an iPhone with Broken Screen?
Yes, an iPhone with a broken screen can be unlocked as long as it still works. There are several ways you can try to unlock and get access to your iPhone with a broken screen, with or without data loss. Moreover, if you are encountering some severe situations in which your iPhone can’t be unlocked, you can also use some password-free methods to remove the screen restrictions. Check the following 5 methods now and unlock your iPhone with broken screen easily.
Unlock Broken iPhone with USB Keyboard [No Data Loss]
When your iPhone screen breaks suddenly, the most urgent thing is to unlock the device and keep your important data. Is it possible to unlock a broken iPhone without data loss? Yes, according to some user tests, unlocking an iPhone with a cracked screen by using a wired USB keyboard can keep your data. Try this method right now if your screen is completely broken due to a lock.
This method is only applicable to iOS versions before 11.4.1.
Enable USB Debugging with OTG Cable
How to Unlock Broken iPhone with USB Keyboard
  •  Using an original lightning cable, connect the external USB keyboard to your broken iPhone.
  • To activate your lock screen, press the space bar twice.
  • To unlock your iPhone, enter your screen passcode on the USB keyboard.
2. How to Unlock iPhone with Broken Screen via Siri
Since the USB keyboard method only supports some older iOS devices, you may need another way to unlock a broken iPhone without losing data. VoiceOver can also be used to access your iPhone when it has a broken and unresponsive screen. It can unlock an iPhone with a broken screen without losing data. however, according to many customer reports, it doesn’t always work for all iPhone users. Now give it a try if you’re the lucky one.
Step 1: To activate Siri, press and hold the Home button.
Step 2: Ask Siri to enable VoiceOver, then press the Home button to return to the main unlock screen.
Step 3: Swipe left or right until the “Slide to Unlock” option appears, then double-tap. The password page now appears.
Step 4: Swipe left or right on the keyboard to highlight the correct keys, then double-tap to “Enter” each one.
Step 5: double-click to enter the password by swiping to highlight enter or done.
3. Unlock Broken iPhone Without Password [Quick & Easy]
How to access iPhone with a broken screen without using Siri? One of the safest, most popular, and hottest options is using a professional iPhone unlocker: AnyUnlock – iPhone Password Unlocker.
AnyUnlock is one of these apps that helps you unlock your iPhone when your iPhone won’t respond to touch, or you can’t slide to unlock your iPhone. Whether the screen on the iPhone is broken or when you forgot the iPhone passcode, got a second-hand device, iPhone is disabled, etc., AnyUnlock can unlock the device as long as the device can be connected to your computer and the app can recognize it.
Key Features:
  • Quick: To unlock a broken iPhone if the touch screen doesn’t work, AnyUnlock is definitely a good helper.
  • Various Options: Support unlocking any iOS screen locks such as digital password, Face ID, fingerprint recognition, PIN, pattern, etc.
  • User-friendly: Only need to click the buttons to unlock your device. No need any technical knowledge, you can use it with ease.
  • Comprehensive: Supports all iPad/iPhone models, such as the latest iPhone 15 and iPhone 14. And it works quite well on all iOS versions.
  • Rich Functions: This complete password unlocker gets 12 unlocking features that allow you to bypass MDM lock, remove Apple ID,  bypass Screen Time passcode, etc.
Free get AnyUnlock and follow the detailed steps to unlock iPhone with broken screen without Siri:
Steps to Unlock iPhone with Broken Screen using AnyUnlock:
Step 1. Free download AnyUnlock and launch it on your computer, click Unlock Screen Passcode.
Choose Unlock Screen Passcode
Step 2. Connect your iPhone to the computer, and wait until AnyUnlock has detected your iPhone. Click Start Now.
Click Start Now Button
Step 3. Download on the iOS firmware package page. When the firmware is downloaded, click the Unlock Now option. Then AnyUnlock will unlock the screen passcode automatically.
Tap on Unlock Now to Remove Screen Passcode
Step 4. And when the recovery process is completed, you will see the Screen passcode removed successfully interface.
Successfully Remove Screen Time Passcode via AnyUnlock
AnyUnlock requires no interaction on the iPhone to unlock it. All that you need to do is on your computer and your phone is unlocked.
Before the remove screen lock goes on, you need to know that AnyUnlock will erase all the content on your device. Also, if the Find My iPhone was turned on, you would be asked for the Apple ID and passcodes after the screen lock was removed successfully.
4. Use Find My iPhone to Remove Password on Broken iPhone
If you do not already know, when you link your iOS-based devices like your iPhone with your iCloud account, you can access many features of your device right on the iCloud website. This allows you to perform some of the actions on your phone as well, all remotely.
This feature is called Find My iPhone and it is located on the iCloud website. When there is an issue with your iPhone, like it is lost, stolen, or has simply got its screen broken, you can use this Find My iPhone feature to unlock your device. In order to use this feature with your iPhone, your iPhone must get Find My iPhone enabled on it. If you did not turn this option on before the screen got broken, you cannot use this method.
Also, you need to keep in mind that unlocking your iPhone with Find My iPhone basically means wiping off all the data on your phone. This will delete all your photos, videos, and all content from your device. Therefore, it is suggested that you make a backup of your device before you use this procedure to unlock your device.
Once you have made a backup and you are ready to unlock your iPhone with a broken screen, the following is what you need to do.
Step 1. Open a browser and head over to the iCloud website. Sign in to your iCloud account if you have not already done so.
Step 2. Once you are logged in to your account, find the option that says Find iPhone and click on it. This will open the Find My iPhone feature for your device.
Access the Find iPhone Option on iCloud
Step 3. On the following screen, you will find an option saying All Devices at the top. Click on this option and choose your iPhone from the list. This will open the actions menu for your iPhone.
Choose the Locked iPhone from the List
Step 4. You can now perform certain actions using iCloud web remotely. Click on the option that says Erase iPhone and then select Remove from Account. This will wipe off your device and remove it from your account. The latter unlocks your device.
Erase and Remove the iPhone from the Account
Your iPhone with a broken screen should now be unlocked.
You may also like: How to Turn off Find My iPhone When Phone is Broken >
5. Unlock iPhone with Broken Screen with iTunes
iTunes is a preferred tool for many iOS users to perform actions on their devices. If you are an iTunes user, too, you might want to check if it is at all possible to unlock your iPhone with a broken screen using this application. Luckily, that is totally possible and you can use iTunes to unlock and restore your iOS-based devices including your iPhone.
Like the Find My iPhone method, iTunes can restore the iOS operating system on your phone to unlock your phone. This basically means clean installing the iOS operating system on your device. You do not need an Internet connection to do this and all you need to do is plug your iPhone into your computer using a USB cable.
There are a few things you should know before you use this method to unlock your broken-screen iPhone. First, the method deletes all the data stored on your device. You will need to back up your device before you unlock it with iTunes. Second, in some cases, you will need to tap on an option in the prompt on your iPhone when you connect your iPhone to your computer.
Your iPhone needs to verify that you trust the computer that you are restoring your iPhone. If you can tap on an option on your broken screen, then you can use this method to unlock your iOS device. The following is how you go about using this method on your computer.
Step 1. Launch the iTunes app using your preferred way on your computer. Mac users need to launch the Finder as iTunes is no longer available in the latest macOS Catalina.
Step 2. Connect your iPhone to your computer using the original USB cable.
Step 3. You will see your iPhone listed in the Finder or iTunes app. Click on your iPhone to see the options for it.
Step 4. Inside the General tab, you will find a button that says Restore iPhone. Click on this button to start restoring and unlocking your device.
Restore the iPhone with iTunes or Finder
When your iPhone is restored, it will be unlocked.
Now that you know how to unlock iPhone with broken screen, you should be able to unlock your phone and sell it or give it in for repair. And AnyUnlock enables you to unlock your iPhone with a broken screen without Siri, including screen passcode, Touch ID, or Face ID. Why not download AnyUnlock and get into a locked iPhone now? We hope your phone gets fixed and you can use it as before.
