“I lost my iPhone 13 last month and found it yesterday, but it’s locked by a new passcode. How do I get into it without passcode?” – From an iPhone user.
No passcode or Face ID to unlock iPhone 13? Free download AnyUnlock to remove screen passcode on iPhone 13 in 3 minutes. Support all iPhone 13 models.
In recent times, the demand for iPhone 13 series has skyrocketed tremendously due to the incredible features it supports, from the huge leap in battery life to the high-resolution camera, the A15 bionic lightning-fast chip, and lots more. The device also powers one of the best security systems such as the Face ID and screen unlock- all of which aim to protect users’ data from unauthorized access. Unfortunately, this security system does come with its fair share of issues, and one of them is restricting the real owner of a device access when he or she loses screen passcode or exceeds Face ID verification. If you are faced with a similar challenge, you are on the right page to seek solutions. Today’s post will cover how to unlock an iPhone 13/13 Pro Max without a passcode.
Also Read: How to fix iPhone 13 won’t turn on
Perhaps you can’t remember your screen passcode but have Face ID enabled on your iPhone 13, you can still bypass your lock screen without punching any code on your screen. Here’s how to do this:
To use Face ID to unlock iPhone 13 screen lock without passcode, you must have unlocked the device at least once in the last 24 hours using your screen passcode. Additionally, if you are just turning on your iPhone 13 series, you have to enter your screen passcode before Face ID can start working with it.
If you have the Apple ID linked to your iPhone 13 or any related series, you can leverage it to bypass your locked screen without a passcode. However, the corresponding device must be running on iOS 15.2 or later for this to work. This is so because only this version of iOS supports the Erase iPhone option which lets you wipe and bypass your locked device screen using your Apple credential.
To employ this solution, follow the detailed guide down here:
Click on Erase iPhone Option
Besides streaming music, iTunes also paves the way for bypassing screen lock issues on iOS devices via restoration. You can use it to unlock your iPhone 13 without a passcode and reclaim control of your device within minutes. To unlock your iPhone 13 without a passcode using iTunes, follow the simple illustrative guide below:
Activate recovery mode on your iPhone 13. To do this, follow these instructions:
Restore the iPhone with iTunes or Finder
Restore your iPhone 13 via iTunes
Via Find My, you can wipe all content and settings (including screen passcode configuration) on your iPhone 13 remotely, thereby making it easy for you to access your device without a passcode. This measure works best if you have Find My enabled on the iPhone 13 and you can remember the Apple ID details linked to the device. Once you can satisfy this condition and don’t care about losing your data, follow the stepwise guide below:
Tap on the Erase iPhone icon
The above methods don’t require iPhone 13 screen passcode, but some of them take effect with an Apple ID. In this case, you may fail to unlock iPhone 13 without passcode or Apple ID. Then you can use AnyUnlock iPhone Unlocker. It is the ultimate iPhone unlocker that helps to unlock iPhone 13 without passcode or Face ID. Besides, it doesn’t ask for Apple ID during the unlocking process. This cutting-edge software offers a straightforward way to unlock screen passcode on your iPhone 13 without having to interact with your screen. It doesn’t matter whether you are using a custom passcode, 4/6 digits passcode, Face ID or Touch ID, AnyUnlock will unlock your device and return full access to you.
Steps to Unlock iPhone 13 Directly with AnyUnlock
Download the up-to-date version of AnyUnlock on your computer, launch it, and apply the stepwise guide below to unlock your iPhone 13:
Step 1: When the quick start screen for the software pops up, click on Unlock Screen Passcode to unlock iPhone 13 without passcode.
Choose Unlock Screen Passcode
Step 2: Once done, link the locked iPhone 13 to your computer using a reliable USB cable. AnyUnlock on detecting your connection will direct you to the following screen.
Click Start Now to proceed. AnyUnlock will immediately scan your device and recommend the most suitable firmware to bypass your screen lock. Tap Download to get the firmware.
Click Start Now Button
Step 3: After the firmware download is completed, click Unlock Now on the on the subsequent screen.
Tap on Unlock Now to Remove Screen Passcode
AnyUnlock on receiving your instruction will commence the screen unlock without your screen passcode. Wait for the process to finish, then disconnect your iPhone 13 from the computer and start using it freely.
1. Can I unlock iPhone 13 without Face ID or Passcode?
Yes, you can unlock your iPhone 13 without providing your Face ID biometric or entering your screen passcode. There are numerous ways to go about this, such as restoration via iTunes, system wiping through Find My, plus screen unlock via AnyUnlock. All of which have been discussed in the post above.
2. How to unlock iPhone 13 passcode without erasing it?
Unlocking your iPhone 13 without erasing it is quite challenging unless you are using your screen passcode or Face ID. The screen passcode could be your current one or the previous one depending on the situation. For instance, you can still recollect your screen passcode, you can enter it to unlock your iPhone without wiping it. If you can’t remember the current passcode and wish to bypass screen lock without erasing your device, the previous passcode could come into play. However, you have to run your iPhone 13 on iOS 17.2 or later.
In case you are restricted access to your iPhone 13 due to lost or forgotten screen passcode, any of the techniques recommended in the post above should help reclaim access to your device. Among all the methods, AnyUnlock is the best option to unlock iPhone 13 without passcode or Face ID. It unlocks any kind of iOS screen lock within the shortest possible time. Your iPhone 13 screen is safe with this tool at your disposal.
