How to Unlock iPad without Password If Forgot [5 Ways]
Locked out of your iPad? Wondering how to unlock iPad without passcode? Unlock your iPad with our guide on accessing it without a password. From utilizing iTunes and iCloud to leveraging advanced tools like AnyUnlock, we have got everything. So you can use these solutions and get back into your iPad.
Author Avatar Joy Taylor Last Updated: Mar. 25, 2025
Whether due to frequent changes in passcodes, or simply facing an unexpected lockout, or a forgotten password; There are times when you need to unlock your iPad without a passcode. It is a common problem faced by many iPad users. So if you’re grappling with the question of “how to unlock iPad without password,” you’re not alone.
In this guide, we’ve discussed five practical methods that will help you regain access to your device. Try out all these solutions, and you’ll find an approach that suits your situation. So let’s get started without any further delay.
How to Unlock iPad Without Password in Simple Clicks
The world has progressed a lot. And today, no matter the technical issue, there is always a solution. In our case, many third-party tools are specifically designed to unlock iPads. Among these, AnyUnlock – iPhone Password Unlocker stands out as a powerful and user-friendly option. AnyUnlock is a tool designed for troubleshooting iOS issues. It can instantly free your iPhone, iPad, or iPod touch from various screen locks. Whether it’s your iPhone’s screen password or an iCloud Lock on your iPad, AnyUnlock can unlock your iPad’s screen lock with a few clicks. Besides, AnyUnlock can also bypass MDM lock, remove Apple ID, bypass screen time passcode, etc. Learn more about AnyUnlock below.
  • Unlocks all iOS screen locks, including fingerprint, Face ID, PIN, 4-digit or 6-digit numeric passcode, pattern, etc.
  • Advanced technology with the highest success rate. Never records or leaks personal information.
  • Works with all iOS iPhone/iPad models and iOS versions, including the latest iPhone 14 and iOS 16.
Download AnyUnlock on your Computer, and follow the guide to unlock iPad without passcode:
Step 1. Launch AnyUnlock and choose “Unlock Screen Passcode” mode. Connect your iOS device to your computer via a USB cable.
Choose Unlock Screen Passcode
Step 2. Click the “Start Now” button. AnyUnlock will suggest suitable firmware for your iPad. Download the iOS firmware to proceed.
Get a Matching Firmware
Step 3. When the download is complete, select the “Unlock Now” option to unlock the screen passcode.
Tap on Unlock Now
Tap on Unlock Now
Step 4. The unlocking process will begin automatically. In just a few minutes, the screen passcode will be removed. Click on the “Done” button to set up your iPad from the start.
Successfully Removed Screen Time Passcode
How to Unlock iPad Without Password Using iTunes
iTunes isn’t just a platform for managing your music and other media. It can also be a vital tool when locked out of your iPad. By utilizing iTunes, you can easily restore your device. However, it’s crucial to note that this process will erase all data on your iPad. It requires that the iPad has been synchronized with iTunes on a computer before the device was locked.
Here’s a step-by-step guide on how to unlock your iPad without passcode using iTunes:
Step 1. Open iTunes on the computer. Then connect your iPad using a USB cable.
Step 2. Now, select the device’s icon in the top left menu.
Note: While not mandatory, it’s wise to back up your device to save important data. Click “Back Up Now” under the Backups section.
Step 3. You will find a “Restore iPad” option in the Summary panel. Click on this option and the restore process will begin.
Restore iPad via iTunes
Step 4. A dialog box will appear for confirmation. Click “Restore and Update” again to confirm that you want to restore the device to the factory settings.
Step 5. iTunes will download the necessary software for the restore. After the process is complete, your iPad will restart.
The only limitation of the iTunes method is that you need a computer for this process. So, let’s move on to another method.
How to Unlock iPad without Computer via Erase iPad
iCloud is a storage space available to every iOS user. But apart from just storage, it is also a platform that integrates many features. The feature we need is the powerful “Find My iPad” tool.
You can erase your iPad remotely by utilizing the “Find My iPad” tool. And after erasing your iPad, your screen passcode will also be removed. This method is especially handy when you don’t have access to a computer or prefer a cloud-based solution. But the iCloud erase method will only work if you have enabled the “Find my iPad” on your device. And your device must also have an internet connection.
Follow this stepwise guide on how to unlock iPad without a passcode via erase iPad.
Step 1. From a separate device or computer, go to the iCloud website. Now sign in using your Apple ID.
Step 2. Locate the “Find My” Button. Click on it to access the devices associated with your Apple ID.
Step 3. Click “All Devices,” and all devices connected to your iCloud account will be displayed here. Choose the iPad you wish to unlock.
Step 4. Once your iPad is selected, click the “Erase iPad” option. Now you’ll be asked to enter your iCloud account passcode to confirm the erase command. Enter the passcode and proceed.
Erase iPad
Erase iPad
Step 5. Your iPad will begin restoring to factory settings.
Step 6. Once the process is completed, your iPad will be ready to use as if it were brand new.
How to Remove iPad Passcode via DFU Mode
DFU stands for Device Firmware Update. This mode allows all devices to be restored from any state. When other standard methods of resolution fail, DFU is the answer most of the time. In DFU mode, the device can interface with iTunes but does not load the iPhone OS or bootloader. That’s what makes it different from the more familiar recovery mode. However, this method will also erase all data on the iPad.
Here is the stepwise guide on how to unlock iPad without passcode using DFU mode.
Step 1. Connect your iPad to the computer using a USB cable. Then launch the latest version of iTunes on your computer.
Step 2. Now press & hold both the Home and the Top/Side buttons simultaneously for 10 seconds.
Step 3. After 10 seconds, release the Top button. But continue holding the Home button. Hold it until iTunes detects a device in recovery mode. Note: Your iPad screen should remain black, indicating it’s in DFU mode. If you see the Apple logo or a message about restoring, you should enter DFU mode again.
Step 4. Now click on the “Restore iPad” button on the screen. A prompt will appear. Select “Restore and Update” again.
Step 5. Allow iTunes to download the necessary software and restore your iPad. This process can take several minutes, so be patient.
Step 6. Once the restoration is complete, your iPad will automatically restart. You can then set it up as a new device.
How to Unlock Disabled iPad Without Passcode via Recovery Mode
Unlike DFU mode, Recovery Mode accesses the system OS before loading the bootloader. And it is a failsafe method in iBoot used during standard iOS upgrades & restores.
When an iPad is disabled because of too many incorrect passcode attempts, Recovery Mode can be used to restore the device. But like other methods, Recovery Mode will also erase all content on the iPad & reset it to factory settings.
Here is the step-by-step guide on how to unlock iPad without passcode via recovery mode.
Step 1. If your iPad is already connected to the computer, disconnect it. Close iTunes if it’s open.
Step 2. Now connect your iPad to the computer again. Then immediately press & hold both the Home and the Top/Side buttons. Continue holding them until you see the Recovery Mode screen. Note: The process to enter recovery mode may differ with different iPad models.
Reboot iPad into Recovery Mode
Step 3. Once in Recovery Mode, iTunes on your computer will pop up a window. This pop-up will show that iTunes has detected an iPad in recovery mode. Select the “Restore” button.
Step 4. Now you’ll be prompted with a warning that this action will erase all data on your iPad. Confirm the action. Select the “Restore and Update” option.
Step 5. Wait until iTunes finishes the process. After that, your iPad will be in its original factory state without any passcode. You can then set it up as a new device.
And that’s everything on how to unlock iPad without passcode. Before we end our guide, let’s look at some of the frequently asked questions.
FAQs
Is It Possible to Unlock the iPad without Apple ID & Password?
Yes. Utilizing tools like Recovery Mode or AnyUnlock can temporarily bypass the need for Apple ID credentials. However, if “Find My iPad” is enabled, the device remains linked to the original Apple ID even after resetting it. And you can’t unlock an iPad without Apple ID and passcode. If this happens, you can use AnyUnlock to unlock the iCloud activation lock.
Can I Unlock an iPad I Found?
Unlocking someone else’s device without permission is an invasion of privacy. And it may be illegal in many jurisdictions. If you find an iPad, the best course of action would be to notify the local authorities. Some iPads may also display contact information on the lock screen. But if you are a legal authority, then you can try to unlock the iPad using AnyUnlock or iTunes.
Final Words
For every iPad user, it’s important to have the know-how on “how to unlock iPad without password.” Because various situations may arise that might warrant such action.
In this article, we’ve provided five practical solutions to unlock your iPad without the passcode. From third-party tools like AnyUnlock to the conventional iTunes method, you can try the one you like. But if you’re searching for a seamless & efficient solution, we recommend trying AnyUnlock. It can not only remove screen passcode but can also troubleshoot many other iOS-related issues.
