4 Easy Ways to Turn off Lock Screen iPhone [2025]
If you’re looking for ways how to turn off lock screen iPhone, we have discussed 4 quick and easy ways to do so in this article.
Author Avatar Joy Taylor Last Updated: Feb. 26, 2025
Keeping a lock screen passcode or face ID has become a norm; however, there are times when it becomes a real pain in the neck. For instance, when you’re in a rush and have to type your passcode but keep mistyping it. Or when your iPhone fails to recognize your face when you’ve just woken up or put on heavy makeup.
Therefore, if you don’t have any important data to secure and want to avoid the hassle of entering your passcode every time you want to use your iPhone, we suggest turning off your device’s lock screen. In this article, we have listed 4 easy ways to turn off lock screen iPhone. Read on to find out.
Bonus Tip: Cannot unlock your iPad? You can read: How to Bypass iPad Password >
How to Turn off Lock Screen iPhone with Password
If you still remember the password of the screen lock, the most straightforward method to turn off lock screen iPhone is by using the existing passcode. As some users may not know how to do that, here we will show you the detailed steps. So now let’s see how to turn off lock screen iPhone with password.
Step 1. Go to “Settings > Face ID & Passcode” and enter your screen lock passcode.
Choose Face ID & Passcode
Step 2. Tap “Turn Passcode Off” and enter your passcode to confirm your selection.
Tap Turn Passcode Off
How to Turn off Lock Screen iPhone without Password
There may be instances where you want to remove your lock screen passcode but don’t remember it. In such a case, you can remove it using a professional iOS unlocking tool, and AnyUnlock – iPhone Password Unlocker is exactly what you need. It is a powerful unlocking tool for iOS users, which can help you turn off lock screen easily. Compared with traditional iOS unlocking methods, AnyUnlock is easier to operate. And the whole unlocking process is super fast, allowing you to use the phone without the lock screen almost immediately. And you can also read on to know more about the key features of AnyUnlock.
  • Unlock all screen locks – It covers all screen lock types, such as digital password, pattern password, face recognition, fingerprint, customized digital code, and so on.
  • Click to unlock – No complicated operations. No cumbersome processes. You can easily remove the screen lock just by clicking a button.
  • Just a few minutes – You only need to spend a few minutes to unlock your device successfully. No long tedious waits.
  • Superior Compatibility – At present, AnyUnlock has supported the latest iOS system and has covered all iPhone/iPad/iPod models.
AnyUnlock also works like a master key for your iPhone and enables you to unlock Apple ID, bypass MDM lock, bypass iCloud activation lock, remove SIM lock, and manage your iOS passwords, among other features.
Just free download AnyUnlock on your Windows or Mac computer. Here’s how to use AnyUnlock to turn off the lock screen iPhone:
Step 1. Open AnyUnlock on your PC, and select the Unlock Screen Passcode option.
Choose Unlock Screen Passcode
Step 2. Connect your iPhone to your PC using a USB-to-Lightning cable, and click Start Now.
Click Start Now Button
Step 3. Check your iPhone’s model and iOS version and click Download to get the firmware. Please don’t unplug your device during the process.
Get a Matching Firmware
Step 4. Once the firmware is downloaded, click Unlock Now to start the lock screen removal process.
Tap on Unlock Now
Tap on Unlock Now
Step 5. When the process is complete, your screen lock has been removed successfully.
Also, note that removing the screen lock with AnyUnlock will erase all data from your device. Therefore, make sure to back it up before starting the process.
How to Turn off Lock Screen iPhone with iTunes
If you cannot remember the password, another easy way to turn off the lock screen iPhone is via iTunes. As we all know, iTunes can always help iOS users solve some common problems, and here, it can also act as an iPhone unlocker. However, this method only works if your iPhone is synced with iTunes. Therefore, please make sure you have synced your device with iTunes and then follow the steps below to turn off lock screen iPhone.
Step 1. Connect your iPhone to your PC using a USB-to-Lightning cable and launch iTunes.
Step 2. Click on the Device Tab > Restore iPhone.
Click Restore iPhone
This will reset your iPhone, and you can set it up as new without a screen lock.
How to Turn Off Auto Lock on iPhone
iPhones have a built-in feature that dims down your screen after 30 seconds of inactivity and eventually locks it. This is called Auto Lock, and it is set at 30 seconds by default. However, you can modify the timing or turn it off completely according to your preference. Here’s how:
Step 1. Go to “Settings > Display & Brightness.”
Step 2. Tap “Auto Lock > Never” to turn off Auto Lock.
Tap Auto Lock and Choose Never
Apple’s security system is one of the most robust and foolproof in the world; the iPhone’s screen lock face ID and passcode are good examples. However, entering your passcode every time you need to use your iPhone can sometimes get quite bothersome. Therefore, if you want to turn off lock screen iPhone, you will find 4 easy ways to do so in this article. And if you forget the screen password, you can also get AnyUnlock for free to turn off lock screen with ease. You can also share your experiences of turning off the iPhone lock screen in the comments below.
