How to Find Passwords on iPhone [Ultimate Guide]
Your iPhone saves your various passwords such as app passwords on iPhone so that you can automatically log in to those apps and websites. But how to find passwords on iPhone? Just read this article learn methods to find saved passwords on iPhone, as well as ways to manage them.
Author Avatar Joy Taylor Last Updated: Jan. 17, 2024
AnyUnlock – Find Saved Passwords on iPhone with Ease
If you want to find and view passwords on iPhone, just free download AnyUnlock to do that in simple clicks. Passwords saved in iCloud Keychain, passwords for Wi-Fi, app accounts, email, etc. can all be found by this tool. And you can also export and manage them as you like.
Your iPhone is one of the extremely useful gadgets that are available out there. It offers several features to help you make your life easier. One of these features is the ability to save multiple websites and app passwords on your phone. As your iPhone saves your login details for you, you can automatically log in to your favorite websites and apps with a single tap. Mostly you will want to use this saved passwords feature when you want to log in to a website or app.
There are certain times, though, when you would want to find saved passwords on iPhone to check or edit them. But where to see passwords on iPhone? Luckily, there are ways for you to do that with ease. So if you also want to know how to find passwords on iPhone and how to manage them, just read the detailed guide below.
How to Find Passwords on iPhone in Settings
How to find saved app passwords on iPhone? Apple does not offer an independent app for you to find app passwords on iPhone. However, you have an option right in the Settings app to let you solve how to check saved passwords on iPhone.
This option works pretty much the same way as any other password manager. All you basically need to do is access the option, verify your identity, and you can access saved passwords on iPhone. Keep in mind that this requires you to unlock your device and also enter your passcode before finding saved passwords on iPhone. Here is how to view app passwords on iPhone via Settings.
  1. Launch the Settings app from the home screen on your iPhone.
  2. Scroll down and tap on the Passwords & Accounts option to view saved passwords.
  3. Tap on Website & App Passwords at the top to view your website and application passwords.
  4. Use your Touch ID or Face ID to confirm your identity.
  5. A list of saved website passwords will appear. Tap on any website to see its password.
Tap on the Passwords and Accounts Button
In this way, you can easily solve how to find passwords on iPhone. But you need to note that some passwords cannot be found in this way, such as iPhone screen password, WiFi password, etc. Then, just go to the next part to see where to find all passwords on iPhone.
How to Find Saved Passwords on iPhone in Clicks
How do I find all my saved passwords? If you need to view saved passwords for WiFi, apps, etc., or you want to view the detailed information of these passwords, AnyUnlock – iPhone Password Unlocker is your best choice.
It is a complete iOS password tool and can help you view various types of passwords from your iOS devices, like passwords for WiFi, SNS accounts, apps, browsers, and more. The app even allows you to export passwords on iPhone to your computer as a list if you want to manage them or create a backup of your passwords. Most importantly, it supports all iPhone models and iOS versions, including iPhone 15 and iOS 17. To learn more about AnyUnlock, here are some of its features.
AnyUnlock – View Passwords on iPhone/iPad
  • Find passwords for various platforms, like WiFi, websites, apps, etc.
  • Lightning-fast find passwords in 1 click and 3 steps.
  • Support exporting passwords to manage as you like.
  • No erase of data on your iPhone, 100% clean & safe.
Besides, even if you don’t save the password and forget it, AnyUnlock can help you unlock many kinds of passwords, such as screen passwordiCloud Activation Lock, encrypted backup password, Apple ID, etc.
Download AnyUnlock to your computer now, and let’s see how to find passwords on iPhone and manage them as you like!
Step 1. Plug in your iPhone to your computer using a USB cable and launch AnyUnlock. Click on iOS Password Manager on the app’s main interface.
Step 2. Then, AnyUnlock will detect your device automatically. You can view the basic info about your device. Click on Scan Now.
Click on Scan Now to Scan for Safari Passwords
Step 3. Enter a random password and click on OK. On the left panel, choose the WiFi Account option. Now you will find the saved passwords on your iPhone. You can click on the Export button to get the exact one you like.
View Saved Passwords Listed on Your iPhone
Now you have successfully solved the problem of how to find saved passwords on iPhone. Also, if you forget your saved passwords, or if you can’t get into your device with Face ID, AnyUnlock can also help you solve how to retrieve saved passwords on iPhone and how to access passwords on iPhone without Face ID.
How to Save Passwords on iPhone
It is really great that your iPhone saves your website and app passwords for you. However, the issue is that this save prompt usually only appears in Safari. This means, if you use any other browser to log in to your websites, your login credentials are not going to be saved. This results in you having to manually enter your username and password on each of your websites. So, how to save a password on iPhone by yourself?
There is actually a feature in iPhone’s password manager that you can use to manually add your login details to the device. This comes in handy when you use a browser like Chrome or Firefox on your iPhone and you do not get the automatic prompt to save your passwords. This feature to add new login details is easy to find and use. The following shows how to save a password on iPhone.
Step 1. Head to Settings > Passwords & Accounts > Website & App Passwords on your iPhone.
Step 2. If required, confirm your identity using your verification method.
Step 3. On the screen where you see your passwords, tap on the + (plus) sign at the top-right corner to add new login details.
Tap on Plus Sign
Tap on Plus Sign
Step 4. A form will open letting you input logins for your site. Type in the website URL, username, and password in the given fields and then tap on Done at the top-right corner.
Enter New Password Details
After completing the above steps, you can see passwords on iPhone through the previous method.
How to Manage Passwords on iPhone
How to Delete Saved Passwords on iPhone?
There are many reasons why you would want to delete logins from your iPhone. Maybe you are no longer a user on a website you want to delete that site’s logins from your phone? Or maybe you have created a new account on a site and you want to remove old logins from your device? Either way, it is pretty easy to do that.
There are two ways to delete saved passwords from an iPhone. You can either delete passwords for multiple sites at once or you can delete passwords individually for each site. The following is a detailed guide on how to delete saved passwords on iPhone.
Step 1. Open the Settings app and head to Passwords & Accounts > Website & App Passwords.
Step 2. Authenticate yourself using your security method.
Step 3. On the following screen, if you want to delete multiple passwords at once, tap on Edit in the top-right corner. Then, select the passwords you want to delete and tap on Delete in the top-left corner.
Choose Password to Delete
Step 4. If you want to individually delete passwords, tap on a website on the list. Then, tap on Edit at the top-right corner and tap the red minus sign to remove that password from your phone.
Click on Done Button
How to Change Saved Passwords on iPhone?
In addition to deleting passwords, many people ask: how do I change my password on my iPhone? Because you probably want to change to a stronger password. Actually, this is very simple. If you want to know how to change password iPhone, please read below.
Step 1. Continue to stay in the password list mentioned in Step 3 above. Click on the password you want to change.
Step 2. Select Change Password on Website. Then you can enter your new password and related information. Finally, click Done to complete.
No matter why you want to view the passwords, there are some easy ways on how to find passwords on iPhone. And you can also add, delete or change your passwords as needed. But if you need to view passwords other than app passwords, or if you want to view and manage these passwords as quickly as possible, AnyUnlock must be your best option. Just free download AnyUnlock to have a try.
