How to Reset Notes Password on iPhone/iPad Easily
Would you like to change your Notes password? Get all information about how to reset Notes password on iPhone/iPad/Mac through the article below.
Author Avatar Joy Taylor Last Updated: Dec. 19, 2024
AnyUnlock – iDevice Passwords Unlocker
Free download AnyUnlock to unlock screen passcode, Apple ID, SIM lock, and so on.
I forgot the password for my locked notes. How can I reset the password?
As information security becomes increasingly important nowadays, we often use passwords to protect our privacy. On Apple devices, we can lock our notes with passwords in the Notes app so that their contents are hidden. It’s a very important security measure that you can take to protect your information.
However, as we create more and more passwords, we tend to forget some of them at certain times. What if you forget the password you use for your Notes app? Would you still be able to reset the password? The answer is YES. How to reset notes password? In this article, you will find answers on iPhone/iPad/Mac. Don’t miss.
Also ReadHow to Transfer Notes from iPhone to iPhone >
How Do I Change My Notes Password on iPhone/iPad
How to change locked notes password on iPhone? Here’s what you should do if you forget your Notes password and want to reset it on your iPhone or iPad.
  1. Go to Settings and then go to Notes.
  2. Tap “Password”.
  3. Select the account for which you wish to reset the password.
    How to Reset Note Password on iPhone/iPad
  4. Tap “Reset Password”.
  5. When prompted, enter your device passcode.
    Tap on Reset Password
  6. Your device will ask you to confirm your intent to reset the password. Tap “Reset Password” again if you’re sure you want to change the password for Notes from now on*.
  7. Enter your new password in the “Password” and “Verify” sections. You can also create a Hint to remind you of which password you have chosen. It’s highly recommended that you write down a hint. Otherwise, if you forget your password, you won’t be able to access your locked notes.
  8. Once finished, tap Done.
    Enter Your New Password
Once you select “Reset Password” in step 6, your old Notes password will be removed even if you choose to cancel in the following steps. So if you’re not sure whether you want to reset your password yet, select “Cancel” in this step.
Now you’ve successfully reset the Notes password on your iPhone or iPad.
Further ReadingHow to Fix iPhone Notes Disappeared After iOS 14/13 Update >
How to Change Notes Password on Your Mac
How to reset notes password on Mac? Please follow the steps below:
  1. Open the Notes app.
  2. In the menu bar, click on Notes, and then click on Preferences.
  3. A new window will pop up. Click on Reset Password and then click on OK.
    How to Reset/Change Note Password on Mac
  4. Click on “Reset Password” to confirm your intent to reset the password.
  5. Enter your new password in the “Password” and “Verify” sections. You can also create a Password Hint to remind you of which password you have chosen.
  6. Once finished, click on “Set Password”.
    Click on Set Password
Once you select “Reset Password” in step 4, your old Notes password will be removed even if you choose to cancel in the following steps. So if you’re not sure whether you want to reset your password yet, select “Cancel” in this step.
If you accidentally delete the notes on your iPhone, don’t worry, here is the solution for you to Recover Deleted Notes on your iPhone.
Bonus Tip: How to Unlock Screen Passcode on iPhone
AnyUnlock – iPhone password unlocker is one of the fantastic apps you can use to get rid of the passwords from your iOS-based device no matter you are stuck in you iPhone/iPad screen passcode, Apple ID, iCloud Activation Lock, or even SIM carrier lock. Here, we will demonstrate how you use AnyUnlock to remove the passcode without actually having to enter it in just a few easy clicks. All you need to do is to select your phone, choose the option that lets you remove the passcode, and it will take care of everything for you.
During the process, it will erase all the data on your iPhone. It will then also update the operating system to the latest version available on your device.
The following are the steps on how to use this app to remove the passcode from your iPhone.
Step 1. Download and install AnyUnlock on your computer. It is available for both Windows as well as Mac machines. Launch the app when it is fully installed on your computer. On the main screen, click on the option that says Unlock Screen Passcode.
Choose Unlock Screen Passcode
Step 2. Click Start and hit the Download button to download the firmware for your iPhone model.
Get a Matching Firmware
Step 3. When the firmware is downloaded, click on the Unlock Now button to start unlocking your iPhone. You should be able to see the live progress on your screen.
Tap on Unlock Now to Remove Screen Passcode
Step 4. The following message will appear when the passcode is removed from your iPhone.
You can now start setting up your iPhone as a new device.
Learn More about Reset Notes Password on iPhone
After solving how to how to reset notes password on your iDevice, then let’s discuss more.
#1. iPhone Notes password reset not working?
If you see the “Reset Password” option on your iPhone is grayed out, it probably means you have already removed your old Notes password. You can simply set up a new password.
Please note that even if you successfully reset your Notes password, you still need your old password to access the notes you locked before. The new password can only be used for notes you wish to lock in the future. So if you find that you can’t open certain notes with your new password, it doesn’t mean that the Notes password reset isn’t working. It probably means that the notes you wish to view are locked before you reset the password and need to be unlocked with an old password.
#2. Why can’t I lock my notes on my iPhone?
There are certain types of notes that can’t be locked on the iPhone. These include:
  • Notes synced from third-party accounts, such as Gmail or Yahoo
  • Notes that have PDFs, audio, video, Keynote, Pages, or Numbers
  • Notes that you’ve shared with other people
#3. How can I access my iPhone notes without my phone?
You can choose to view your iPhone notes on your iCloud account. Simply log into your iCloud account at icloud.com, and then click on Notes. Please make sure that you’re signed in to the same Apple account that you used for your iPhone.你
Now you know how to change locked notes password on iDevice. Have you successfully reset your Notes password on your Apple devices? Comment below if you still have any problems with your Notes app or any other issues with your iPhone, iPad, or Mac. Let us know and we’ll try to help!
