In this guide, we’ll detail how to easily find and manage saved passwords on your iPhone 11, ensuring you can always access important login information and improving your account security and convenience.
Have you ever found yourself tapping helplessly on your iPhone 11, trying to remember one of the many passwords you have to remember every day? You’re not alone. A recent study showed that the average person spends 12.6 minutes per week trying to recover forgotten passwords, which shows how our digital lives are becoming increasingly complex.
If you’re wondering how to find passwords on your iPhone 11, it’s only a few taps away. This guide will show you how to navigate your iPhone 11 to quickly find and manage your saved passwords, ensuring you’re never locked out of an account again. Whether it’s a WiFi password, a website login, or an app credential….
Get Siri’s attention first, then say “Show my passwords.” If you’re looking for the password for a specific website or app, try saying “What’s my Facebook password?”
To find and manage passwords on your iPhone 11, you can also use the built-in Passwords & Accounts feature, now updated to Passwords in iOS 14 and later. Here’s how to access and manage your passwords:
1. Open Settings: Start by tapping the Settings icon on your iPhone 11’s Home screen.
2. Access Passwords: Scroll down and tap Passwords. This may prompt you to authenticate with Face ID, Touch ID, or a passcode.
3. View Saved Passwords: Once authenticated, you’ll see a list of websites and apps where you’ve saved passwords. You can tap on any website or app to view the associated username and password.
4. Search for a specific password: If you’re looking for a specific password, use the search bar at the top of the Passwords screen to quickly find what you’re looking for.
5. Edit or Delete Passwords: If you need to update or delete a password, tap the website or app entry and tap Edit in the top-right corner. From here, you can change the username, password, or delete the entry entirely by scrolling down and tapping Delete Password.
6. Manually Add a Password: To manually add a password, tap the “+” icon in the top-right corner of the Passwords screen. Enter the website URL, your username and password, and then tap “Done” to save.
This feature not only helps you retrieve and manage passwords, but also suggests strong passwords for new registered users and automatically saves these passwords (if you choose). You can find the passwords saved on your iPhone 11 by using this method.
find passwords on iphone11
As a powerful iPhone password manager, AnyUnlock allows you to view all passwords saved on your iOS device, such as WiFi password, Gmail password, etc., in one click. Most importantly, it supports all iOS systems, such as iOS 17. You can use it to find passwords on iPhone 11.
In addition, AnyUnlock also has iPhone unlocking features, which can unlock iPhone without password, remove screen time from iPhone, and unlock Apple ID without password.
Main Features:
Use AnyUnlock to Find Passwords on iPhone 11:
Step 1. Connect your iPhone to your computer, launch the AnyUnlock app, and click on “More Tools”.
Step 2. Then select the “iOS Password Manager” option. This will help you view your iPhone 11’s password.
Choose ios password manager
Step 3. Click on the button that says Scan Now on the following screen to scan your device for saved passwords.
Click start now to find password
Step 4. Enter a random password on the following screen and click OK. Click on the option that says in the left sidebar and you will see all your passwords on the right panel. Here you can click on the Export button to download your passwords.
Find password
If you use Apple’s iCloud Keychain feature, you can sync and find your passwords on all your Apple devices. iCloud Keychain can save your website login information, credit card information, etc. and automatically fill it in when you need it.
Access saved passwords on iPhone 11 using iCloud Keychain:
Step 1: Enable iCloud Keychain
Make sure iCloud Keychain is turned on on your iPhone:
Step 2: Access saved passwords
Once iCloud Keychain is turned on, you can access passwords saved via iCloud Keychain on your device by following these steps:
Once authentication is successful, you’ll see a list of all your saved accounts and passwords.
If you often use Safari browser, you can also view and manage saved passwords directly in Safari settings:
On iPhone11, go to “Settings” > “Safari” > “Passwords”, where you can view all usernames and passwords saved by Safari. Before entering this setting, you need to authenticate through Face ID, Touch ID or enter the device password.
This article takes a deep dive into how to find saved passwords on iPhone 11, access the device’s password options and manage them with iCloud Keychain. Effective password management not only helps protect personal account security, but also improves the convenience of daily use. The AnyUnlock tool is especially recommended, which not only helps you unlock iOS devices, but also provides efficient password management functions to ensure that your digital life is safer and smoother.
