If you use Safari to save your passwords, sometimes you may want to see your saved passwords. There are methods for how to find saved passwords in Safari on both Mac and iOS devices. This guide discusses those methods and helps you access your passwords.
Free download AnyUnlock to view all passwords on your device with simple clicks.
If you’re using an Apple product like an iPhone or Mac, it is likely Safari is your default browser. After all, this is the only web browser that comes preloaded on your machine and is well integrated with both iOS and macOS operating systems. Safari allows you to save your usernames and passwords on a page and you can view saved passwords with the Safari password manager on your iPhone and Mac.
If you are looking to find the password for a particular website or app, Safari will help you reveal those passwords on your devices. This guide covers methods for both Mac and iPhone devices for uncovering your saved passwords in the Safari browser.
Safari cannot find server? Read this guide to find some solutions: 8 Tips to Fix Safari Cannot Find Server on iPhone >
Auto-save passwords is a handy feature for most people because we have so many apps that require accounts and passwords, and it’s a pain to remember them. So how to make iPhone/iPad automatically help us remember passwords? AutoFill password features can help you, which can automatically save and update passwords on iPhone and iPad, as well as providing the ability to automatically create strong passwords when signing up for new accounts online. Here’s how to turn on AutoFill Passwords:
An easy way to access and export your Safari passwords from your iOS device is to use AnyUnlock. This one-stop iPhone unlocker allows you to find, view and export your iOS passwords with simple clicks. Besides, as a full iOS password unlocking software, AnyUnlock also allows you to unlock your iPhones lock screen, iCloud Activation Lock, SIM card lock, and MDM restriction on your iPhone/iPad. Whatever your problem with passwords, AnyUnlock can solve them for you.
See how to view and export safari passwords easily as below.
Step 1. Install AnyUnlock on your computer, connect your iPhone to your computer, and click on “iOS Password Manager” in the app.
Click on iOS Password Manager
Step 2. Select “Scan Now” on the following screen.
Click on Scan Now to Scan for Safari Passwords
Step 3. Enter any password and click on “OK“. Your passwords should now be viewable. Click on “Export” to save them to your computer.
View Saved Passwords Listed on Your iPhone
In this part, we will show you how to find, add, remove, and edit Safari passwords on your iPhone with a detailed tutorial.
Siri is a very convenient feature on iPhone. You can use it to set alarms, check messages, make phone calls, and more. Of course, you can also let it help you find your saved password. You can give commands like this, “Hey Siri, show my passwords.” If you are looking for a password for a specific app or website, then you can give the command like this, “Hey Siri, show my Twitter password.”
Find All Saved Passwords on iPhone Safari
After that, you will see a list of passwords saved in Safari on your iPhone. Tap on any one of them and you will be able to reveal its password.
One of the several advantages of using Safari as your web browser is that you can manually add your login information to the browser. See how to do it below.
Enter Personal Information to Edit Your Passwords
It is important that you keep your passwords stronger so people cannot guess them and use them to log in to your accounts. When you save a password with Safari, this browser actually tells you if your saved password is weak. You will see an icon next to your passwords that Safari thinks are weak and should be changed.
Change a Weak Safari Password on Your iPhone
If you want to view saved Safari passwords on iPad, follow the steps below.
1. Open the “Settings”menu > Click on “Safari” > Click on “Passwords & AutoFill”.
Enter the Passwords and AutoFill Option
2. Click on “Saved Passwords” > If your device has a passcode, you will need to enter it.
View All Saved Passwords on iPad
3. Click on the account you want to get the password for. The password will be displayed as follows.
View the Specific Password You Want
Safari for Mac also lets you save and view your website passwords. The following shows how to find and edit saved passwords in Safari for macOS.
1. Open Safari, click on the “Safari” menu at the top-left corner, and select “Preferences”.
Open Safari Settings and Click Preferences
2. On the screen that follows, click on “Passwords”. Enter the password for your Mac user account and continue.
Enter Mac Password
3. To reveal the password for a website, simply click on the password row for your site and the actual password will appear.
Like iOS, your Mac also lets you add and save passwords in Safari on your machine. Follow the steps below to accomplish it.
Add or Remove Safari Passwords on Mac
If you have changed your password on a website, you may want to update that in Safari as well. You can do it as follows.
Accessing Safari password manager on iPhone & iPad and Mac is fairly easy and it lets you view, add, and update your website passwords. And another professional iOS password manager – AnyUnlock, also allows you to find and edit the saved passwords in Safari. You can download and try AnyUnlock. We hope our guide teaches you how to use this password manager on your Apple products. And if you have any advice about the tips, leave your comments below.
