3 Ways to Turn Off Find My iPhone Without Password
If you cannot recall your Find My iPhone password and want to disable the feature, you may want to look for methods for how to disable Find My iPhone/iPad without password. There are actually some proven methods that can help you out in your situation.
Author Avatar Joy Taylor Last Updated: Jul. 23, 2024
AnyUnlock – Unlock Apple ID to Turn Off Find My iPhone Without Password
AnyUnlock supports unlocking Apple ID to turn off Find My iPhone without password. Also, it can help bypass iCloud activation lock if you are stuck on the activation lock screen. Download AnyUnlock and try it out now!
If you have bought a device whose “Find My iPhone” function is enabled, you may need to turn off this feature especially when erasing or resetting your iPhone. To disable this function, you should know the Apple ID credentials and password. In case you do not remember the password or the seller never gave you any password, you may want to find the methods that help remove Find My iPhone without password. Fortunately, there are proven methods to disable Find My iPhone without password. The following guide covers them all for you.
Further reading: How to fix Find My iPhone not updating location
What Is Find My iPhone and How to Use It?
If you are new to the Apple ecosystem or if you have never used Find My iPhone, you may not probably have no idea what this feature is. This section sheds light on what this security feature from Apple is and how you can utilize it on your Apple devices.
Display of Find My iPhone on iOS Devices
Find My iPhone is a feature found in Apple devices that helps you to remotely perform some of the actions on your devices. Firstly, you can easily locate friends and family members. Share your location with others, and let them share back. Besides, if you ever lose your iPhone, iPad, or Mac, you can use Find My iPhone to locate the device on a map. The map will give you the exact location of where your device is.
There are a few other features as well such as the ability to remotely wipe off your device. If you lose your phone or if it gets stolen, you can access this feature and delete all the data on your phone remotely. You can also remove the phone from your account if you no longer own it.
The service can be accessed by going to the iCloud website. From there, you can choose the Find My iPhone/Find iPhone option and then access your devices and perform actions on them.
Access Find iPhone on iCloud
Starting with iOS 13, Apple has combined Find My iPhone and Find My Friends into a single feature called Find My. It does the job exactly the same but with a different name now.
Now that you know what Find My iPhone is, you can go ahead and learn the methods to remove Find My iPhone from your iPhone or iPad without password. The following methods can help you do that on your device.
Method 1. Unlock Apple ID to Turn Off Find My iPhone Without Password
Since Find My iPhone works with an Apple ID to track your iPhone, it’s recommended to unlock your Apple ID and turn off Find My iPhone without password. AnyUnlock is a powerful iPhone unlocker that helps you to unlock Apple ID without password. After removing the Apple ID on your device, Find My iPhone will be turned off directly. Besides, if you are stuck on the activation lock of your second-hand iPhone, AnyUnlock will be the best choice to bypass iCloud activation lock easily.
Follow the steps to unlock Apple ID with AnyUnlock. Additionally, make sure you already have an iPhone backup in advance.
Step 1. Free download AnyUnlock and install it on your computer > Connect your iPhone to your computer and click on Unlock Apple ID in the app.
Click Unlock Apple ID from the Homepage
Step 2. Once your iPhone has been recognized, click on Unlock Now on the following screen to begin disabling Find My iPhone on your device.
Click Unlock Now Button
Step 3. And then, the unlocking process will begin automatically. Minutes later, you’ll see the Apple ID removed successfully page.
Apple ID Removed Successfully
After unlocking the Apple ID, you can set up your iPhone with a new one or manage it for other purposes.
Disable Find My iPhone without Password via DNS Bypass
If you are someone who keeps a tab on the latest Apple news, you have likely heard of the exploits that were found in some of the iOS versions. These versions included from iOS 8 to iOS 10 and you could use an exploit to turn off Find My iPhone without a password.
If your iPhone still runs one of these iOS versions and you have not updated to the latest version, you can use the exploit found in those iOS versions and disable the feature. The trick here is to change the current DNS server on your iPhone to one of the servers that help use the exploit.
You do not need a computer to use this work and you can change the DNS servers when you are connected to a WiFi network on your iPhone. There is no other equipments that you need to accomplish this on your iPhone.
Step 1. Launch the Settings app from the main screen on your iPhone.
Step 2. Find the option that says Wi-Fi and tap on it.
Step 3. Find the WiFi network that your iPhone is connected to and tap on the “i” icon next to that network on the list. This will open the panel where you can edit the DNS servers.
Access your WiFi Network’s Information
Step 4. Tap on Configure DNS on the following screen and then enter one of the following IP addresses:
  • 104.155.28.90 for the US
  • 104.154.51.7 for Europe
  • 78.100.17.60 for Asia
Change the DNS for your WiFi Network
You can then go back to the main menu and try to disable the feature without a password.
Remove iCloud Account to Turn Off Find My iPhone without Password
If you are using iOS 7 on your iPhone, there is a quick method to remove Find My iPhone without a password. This is possible due to a security issue in your iOS version. This requires no equipment or tools and you can do this trick directly on your iOS device.
Delete the iCloud Account on your iPhone
1. Open the Settings app, tap on the iCloud slider, and quickly select the Delete Account option. This might require a few attempts before you can finally succeed at it.
2. Your device will be stuck on a screen. Press and hold down the Power button to turn off your device. Then turn it back on after a minute.
3. When your iPhone boots back up, go to Settings > iCloud and tap on the Delete Account option.
Your account will be removed and Find My iPhone will be disabled without a password.
There are 3 methods mentioned in this article to turn off Find My iPhone without password. You can choose from them and try. Among the 3 methods, AnyUnlock is highly recommended to unlock Apple ID to turn off Find My iPhone quickly. Download AnyUnlock and remove Apple ID or bypass iCloud activation lock without password. Also, if you have any further questions or ideas about this article, please leave your comments below.
