Want to delete screen time history on your iPhone or iPad? Discover easy-to-follow steps and learn how to delete screen time history with or without the passcode.
Are you tired of constantly being reminded of your screen time habits every time you unlock your phone? Don’t worry! It’s great to keep track of your screen time usage. But there are instances when one might want to start fresh & remove all the previous data.
For some individuals, completing this task is a walk in the park. However, it can quickly become a headache for those unsure of what steps to take. So in this article, we’ll show you how to delete screen time history on iPhones with and without passcodes. But let’s first answer a simple query.
Also Read: Here is another tip about screen time you may like – How to Hack Screen Time on iPhone >
Yes, you can delete screen time history on your iPhone. However, it’s important to note that you cannot selectively delete Screen Time data on various applications. The entire Screen Time history is deleted when you delete the Screen Time data.
The process to delete Screen Time data is straightforward. Simply turning off the Screen Time feature will do the trick. And when you turn it back on, all the data or history will be deleted.
There are a few ways to do this, depending on whether you have the screen time passcode. With a passcode, you can quickly delete your screen time history through your device’s settings. Without a passcode, you may need to use a third-party app. Or you can reset your iPhone to erase the data.
However, it’s important to note that resetting your iPhone will also delete all other data and settings. So let’s see an excellent third-party tool that can do this job for us.
If you’ve forgotten your passcode and need to delete your screen time history, AnyUnlock is the solution you’ve been looking for. It’s the perfect iPhone unlocker to free your iPhone, iPad, or iPod touch from various locks, including the screen time password. Whether you are using screen time or the restriction mode, they can be easily unlocked by AnyUnlock. Most importantly, no data will be erased while unlocking. And you can learn more about the key features of AnyUnlock below.
What’s more, Anyunlock can also help you get rid of other iOS locks, like iCloud activation lock, Apple ID, MDM restrictions, screen lock, and more. It is fast, professional, and reliable. With a team of experts boasting ten years of experience, AnyUnlock has already helped over 100,000 users.
Now get AnyUnlock for free and read on to learn how to delete screen time history without passcode by using this tool.
Step 1. Open Anyunlock on your computer. Select the Unlock Screen Time Passcode mode from the opening interface.
Choose Unlock Screen Time Passcode Mode
Step 2. Connect your device to the computer with a connection cable. Now hit the Start Now button.
Click on the Start Now Button
Step 3. When AnyUnlock detects your iPhone, check the details and click the Unlock Now button.
Click on Unlock Now
Step 4. Now the screen time removal process will start. Wait patiently, and you’ll see the following interface when it completes.
Successfully Removed Screen Time Passcode
All the screen time data will also be gone with this feature being turned off. You can turn it on again to have a fresh start.
But if you already know your screen time passcode, you don’t need to go through all this hassle. You can delete your screen time history using this passcode in settings.
As discussed earlier, we can delete the screen time history by turning off this feature. And we can turn off this feature any time we want from the settings of the iPhone. But we’ll need the screen time passcode for it. Even if we don’t have the passcode, we can use the “Forgot Passcode” feature to create a new one using the Apple ID credentials.
Not only is this method straightforward, but it won’t cost you a dime. Follow these simple instructions to delete screen time history in settings.
Step 1. Open the device Settings.
Step 2. Now find the “Screen time” option and click on it. You’ll see the screen time history here.
Step 3. Scroll down and click on “Turn Off Screen Time” twice. You will be asked for your screen time passcode here.
Click on Turn off Screen Time
Step 4. After the screen time feature has been turned off, open the settings and click “Screen Time” again.
Step 5. Turn On the screen time again and set a new password. All the previous screen time history is gone, and you can start from this clear board again.
Easy, right? Now let’s keep the momentum and see how to delete screen time history on a MacBook.
Apart from iPhones & iPads, another iOS device is popular among people. It’s the famous MacBook of Apple! And since a MacBook has all the features of iOS devices, screen time is also present. But the process to delete screen time history here differs slightly from iPhones. Here are the steps to delete screen time history on MacBook with a pictorial description.
Step 1. Start your Mac device and click the Apple icon in the top left corner. Select “System Preferences.”
Select System Preferences Option
Step 2. Click the “Screen time” option to open the Screen Time settings.
Step 3. Select the “Options” button at the bottom left corner of the interface.
Select the Options Button
Step 4. Now click the “Turn Off” button to turn off the screen time.
Step 5. Hit the “Turn On” button to start the Screen Time again. When you return, you’ll see that all the previous screen time history has been deleted.
Now that we are on this topic let’s briefly look at all the situations where we need to delete the screen time history.
Screen Time history can reveal a lot about your device usage. So there are various reasons for which you may need to delete it. Here are some of the most important ones:
How to delete screen time for one app?
Unfortunately, Apple doesn’t provide a way to selectively delete Screen Time data for individual apps. When you delete Screen Time data, the entire Screen Time data is deleted. But if you want to remove the specific apps from screen time, you can do it from Settings. This will remove all restrictions from that specific app.
Now, Screen Time will be turned off for the selected app, and it won’t have any restrictions. However, any previous Screen Time data for the app will remain on your device.
How to delete screen time history on iPad?
Both iPhones & iPads use the same operating system. And the Screen Time feature is located in the same place in the settings menu. Therefore, both devices have identical steps to turn off Screen Time and delete all Screen Time data.
Deleting screen time history helps to maintain your privacy and gain a fresh start toward a healthy device usage habit. This article discusses how to delete screen time history on iPhone, iPad, and Mac. And if you don’t have your screen time passcode or even Apple ID credentials, try AnyUnlock for free. It can quickly delete the screen time history even without the passcode.
