You may need to remove the SIM card from your iPhone on occasion. You could be going overseas and wish to use a local SIM card in your iPhone, or you might want to try a different carrier network for a while. You may change the SIM card in your iPhone in just a few simple steps by following our complete instruction on how to change SIM card on iPhone.
Are you acquiring a new iPhone 14? Numerous people are uncertain if an iPhone can simply switch SIM cards. You absolutely can! What happens if you change your SIM card with one from another iPhone? If you remove the SIM card, nothing much will change to your data; everything is preserved on the phone. Nothing happens if you replace the SIM card from your prior iPhone. The only distinction is that there would be no service, so you simply wouldn’t be able to be used as a phone.
Change SIM Card on iPhone
Furthermore, all details on the original SIM card are lost whenever you extract it from your old phone and transfer data to another SIM card. This information is still recorded on the old SIM card so that if you enter the old SIM card into the new iPhone, any contact details or texts and emails that you lose will be accessible. In this article, we’ll show you how to change SIM card on iPhone and provide you with relevant information.
Also Read: How to Bypass iPhone SIM Not Supported Issue >
Yes, iPhones allow you to change SIM cards. Simply take the SIM card from the old phone and place it in the new phone. You will need to remove the SIM card from your old iPhone and place it into your new iPhone 14 to transfer your SIM card from one iPhone to another.
Also Read: How to Switch from Verizon to AT&T with Ease? >
If you remove your SIM card from one phone and insert it into another, the new phone will be unable to access your cellular data or make calls. Your phone number and other account details are stored on your SIM card. The other phone will be unable to connect to the network if it does not have it.
The phone that was initially paired with the SIM card will no longer operate if you move SIM cards across iPhones. The phone will still be able to make and receive calls, but it will not be able to connect to the internet or use any data-dependent apps.
Also Read: 6 Tips for Wi-Fi Not Working on iPhone iPad >
The SIM Card is positioned on the right side of all iPhones sold by Apple in recent years. The SIM card tray is placed on the right-hand side, directly next to the Switch On/Off button, while holding your iPhone with the screen facing you. This way you can simply change SIM card iPhone.
Locate SIM Card on iPhone
To figure out how to transfer SIM card to new iPhone 14, you must first figure out what equipment you will need. Well, “tools” is a bit of a misnomer because all you need is a SIM ejector tool. All iPhones and iPads now have an Apple SIM extraction tool, however, if you don’t have one, any metal paper clip will suffice. Just make sure one of the ends is straightened.
Follow the below-given steps to know how to switch SIM cards iPhone with SIM card remove tool.
Step 1. Check to see whether the phone is switched off. If it isn’t already turned off, do so now.
Step 2. Then, on the right edge of your phone, locate the SIM card tray.
Step 3. By placing the SIM card eject tool into the designated slot/hole, you may unlock the SIM card tray. You may use a little paperclip instead of the SIM eject tool if you don’t have one.
Change SIM Card with Eject Tool
Step 4. Pull the tray out carefully until it sticks, then remove the SIM card from the tray.
After you change SIM card on iPhone, your iPhone may be locked. If you need to unlock your SIM lock, then you can go directly to Bonus Tip.
A SIM card may do more than just make phone calls and connect you to the internet. Contact information, phone numbers, SMS messages, and data consumption can all be stored on them. Furthermore, your SIM will be protected against theft by a personal identification number (SIM unlock PIN).
When your iPhone is locked due to changing SIM cards, you need to use a professional SIM unlocker to unlock your iPhone. Here, we strongly recommend you to use AnyUnlock – iPhone Password Unlocker, because of its unmatched SIM unlock success rate. In addition to unlocking SIM, AnyUnlock also performs well in unlocking screen passcode, removing Apple ID, bypassing iCloud activation lock and finding Apple ID for you. Please read the following contents to find out the specific features of AnyUnlock.
Download AnyUnlock and try to unlock your iPhone by following the detailed steps below!
Step 1. Start AnyUnlock > Click Remove SIM Lock on the left > Connect iPhone and computer with a USB cable > Click Start Now, then Confirm.
Choose Remove SIM Lock
Step 2. After agreeing to the Terms of Use, click Jailbreak Tutorial > After the jailbreak is complete, click Next > Tap on Remove Now.
Click Remove Now
Step 3. Follow the instructions to turn off WiFi and reinsert your SIM card > Click OK. AnyUnlock will start to unlock the SIM lock, the whole process will take you a few minutes, please be patient.
SIM Lock Removed Successfully
We have elaborated here how to change SIM card on iPhone easily and effectively. These steps will help you to switch SIM card in iPhones. You can carry a sim ejector tool for better application. While changing a SIM you must take care that you must not apply a lot of pressure while inserting the SIM back into the phone. And if you need to unlock the SIM lock on your iPhone, don’t forget to download AnyUnlock, the professional SIM unlocker.
