If you enter the wrong passcode on your iPhone, you get locked out of it. However, in this article, you will find 4 foolproof methods how to bypass iPhone unavailable lock screen.
Most people think Apple devices are overrated because they are too expensive or high-maintenance. However, if there’s one thing nobody can question, it’s Apple’s security system. It is bulletproof!
How to Bypass iPhone Unavailable Lock Screen
For instance, if someone tries to get into your iPhone and enters the wrong passcode a couple of times in a row, the iPhone will get locked, and an “iPhone Unavailable” message will appear on the screen.
The more incorrect attempts, the longer the iPhone security lockout will last!
So, how to bypass iPhone unavailable lock screen? In this article, we have put together 4 tried and tested ways to bypass iPhone security lockout. And as a bonus, we have thrown in a few common queries to help you out.
Further Reading: How to Unlock Apple ID without Security Questions >>
iPhone has several foolproof security features, including the screen lock passcode. If you enter the wrong passcode 5 times in a row, you will get locked out of your iPhone for 1 minute, and an ‘iPhone Unavailable” message will be displayed on the screen.
If you enter the wrong passcode for the 6th time, the iPhone screen will be unavailable for 5 minutes. iPhone security lockout can go up to 3 or 8 hours, depending on the number of wrong attempts, eventually getting locked for good. This means the iPhone will no longer give you the option to enter the passcode, and you will have to factory reset your iPhone to fix this issue, erasing all your data as a result.
Therefore, if you’re locked out of your iPhone and want to bypass the iPhone unavailable lock screen, below are 4 foolproof ways to do so.
How to bypass iPhone unavailable lock screen? The first and most reliable method we will use to bypass iPhone unavailable lock screen without a password is using a third-party tool: AnyUnlock – iPhone Password Unlocker.
AnyUnlock is an iPhone password unlocker tool that bypasses iPhone security lockout in some simple steps. It is so easy to use that you don’t require any prior knowledge or experience to use it successfully. Now, let’s check what it can do for you.
Step 1. Download and launch AnyUnlock on your PC > Select the “Unlock Screen Passcode” mode.
Choose Unlock Screen Passcode
Step 2. Connect your iPhone to your PC with a USB cable. Once everything is set up, click “Start Now.”
Click Start Now Button to Remove Screen Passcode
Step 3. Download on the iOS firmware package page. When the firmware is downloaded, click the Unlock Now option. Then AnyUnlock will unlock the screen passcode automatically.
Tap on Unlock Now
Step 4. Now that the screen lock passcode is removed, your iPhone will be reset, and you can set it up as new.
How do I bypass iPhone unavailable without a computer? The second fast and easy method to fix iPhone’s unavailable lock screen is simply using the “Erase iPhone” option. Here’s how:
Click on the Erase iPhone Option
The third method to fix iPhone’s unavailable lock screen is via Finder or iTunes. For this method, you must have a macOS PC or a Windows PC with the latest version of iTunes.
Here’s how it works:
1.Power off your iPhone and put it in Recovery Mode.
2. Launch Finder of iTunes, and connect your iPhone to your PC using a lightning cable. You will see a pop-up box with 3 options. Click on “Restore.”
3. Another pop-up box will appear, asking you to confirm your selection. Click “Restore and Update” to continue.
This option will restore your iPhone to its factory version, and you can set it up as new.
How to do an iPhone unavailable hack? Another way to fix iPhone unavailable is through the iCloud Find My iPhone feature. Like all other methods, this is also pretty straightforward.
Sign in to iCloud
Click on Find Devices
Click on Erase iPhone
That depends on how often you have attempted to unlock the iPhone with the wrong passcode.
Unfortunately, you can’t speed up the iPhone unavailable time. It will allow you to enter the correct passcode only when the security lockout timer ends.
Whether your iPhone is stolen or your kids have attempted to unlock it using a wrong passcode, you will get the ‘iPhone Unavailable” notification and won’t be able to access it until the timer ends.
However, if your iPhone gets locked permanently after 10 attempts, or you want to access it immediately for some important work, you can bypass the iPhone’s unavailable lock screen using the 4 tried and tested methods discussed above. And with the help of AnyUnlock, it is very easy and convenient to bypass iPhone unavailable lock screen. Why not download AnyUnlock and give it a try now!
