Smartphones are easily lost or stolen, which is why they need to be protected with a screen lock and password. Trying to unlock your iPhone after multiple wrong attempts in a row can result in disabling the device – so it’s necessary to learn how many attempts to unlock iPhone you have at your disposal and what to do if you’re still locked out of your iPhone after multiple failed attempts.
iPhone provides many types of passcode for you to choose from: 4-digit or 6-digit numeric code, custom numeric code, custom alphanumeric code, Touch ID, or Face ID. No matter which kind it is, AnyUnlock iPhone Unlocker can unlock iPhone passcode for you in a single click.
How Many Attempts to Unlock iPhone
The popularity of iPhones has its dark side – those practical and valuable devices are often a target for theft, which is why it’s highly recommended to use some type of screen lock. On the other hand, this can become a problem if you forget your screen passcode or a friend or family member changes the combination without telling you.
To deter unauthorized access and prevent someone from guessing the password through trial and error, you only have a limited number of tries before you’re permanently locked out of your iPhone. Aware of this, some phone owners are petrified of making a mistake that could lead to serious data loss.
In reality, you have quite a few chances to enter the right passcode. Even if you end up disabling your iPhone due to too many incorrect entries, there are still a few things you can do to remove the lock and retry to access the device.
How many attempts to unlock iPhone? Some people think that iPhone will immediately become disabled if you type in the wrong password, but it is not always the case. In fact, your iPhone will behave normally during the first 5 unlocking attempts. In other words, you can try 5 times before iPhone is disabled, or within 5 times, you can still try to enter the passcode to access your iPhone. Afterward, we’ll summarize what will happen after trying more than 5 failed attempts to unlock iPhone.
iPhone passcode lockout times? As the 10th attempt is the final attempt and if you don’t get the passcode right, you won’t be allowed to enter the passcode anymore. That is to say, you have 10 times until iPhone is permanently disabled. Then you will see a pop-up message saying “iPhone is disabled, connect to iTunes”. And worse, your iPhone will be erased after 10 attempts if the security feature was turned on.
To unlock your iPhone after multiple times or even 10 failed attempts, please take a closer look at the following solutions. And, you can still find a solution below to unlock your iPhone before disabled.
How to Unlock My iPhone After Multiple Attempts? If your iPhone becomes disabled because enter the wrong passcode after multiple attempts, you have 4 proven solutions to successfully unlock it again.
As mentioned before, if you have tried to unlock your iPhone but failed too many times in a row, your iPhone may become disabled as a result. And in this case, you should make use of some special iPhone Unlocker tools to take the last try. Among the most welcomed iPhone Unlocker tools in 2024, we highly recommend AnyUnlock – iPhone Password Unlocker.
No matter how many times you’ve tried to unlock an iPhone, you can easily unlock your iPhone in 3 clicks with the help of AnyUnlock’s iPhone Screen Unlocker feature. And, it allows you to unlock your iPhone before it’s disabled. You don’t need to enter any passcode.
Free install the latest version of AnyUnlock and take the following steps to get your iOS device back to normal.
Step 1. Launch AnyUnlock on your computer > Tap on the Unlock Screen Passcode on the welcome page.
Choose Unlock Screen Passcode
Step 2. Connect your locked or disabled iPhone to the computer > Click the Start Now button to initiate the process.
Click Start Now Button
Step 3. Check the device model shown on the interface and download the corresponding iOS firmware. After the download is complete, tap on the Unlock Now button when the download completes.
Tap on Unlock Now
Step 4. Then AnyUnlock will start to unlock your iPhone. Wait for a few minutes and you will see the following page.
iOS Device Unlocked Successfully
Entering the Recovery mode is an effective way that help you access a locked phone, but only if you have a PC with iTunes installed on it. This method will essentially wipe the phone clean and return it to factory settings, so all data that wasn’t backed up will be lost.
Restore iPhone with iTunes
iCloud online service provides an alternative way to get back in control if you forgot how many attempts to unlock iPhone you had and ended up disabling the smartphone. For this approach to be successful, your phone must have the option Find My Phone activated and you need to know the Apple ID password used to log in to iCloud.
Tap on Erase iPhone in iCloud
Assuming those requirements are met, you should access the iCloud account from another Apple device (i.e. Mac computer or iPad).
Some iPhone owners regularly sync their devices with iTunes, and they might be able to unlock a disabled phone without any loss of data if they react promptly before new sync is made.
Restore Your iPhone in iTunes
Apple devices can be locked out by entering the wrong password ten consecutive times, but even if this happens there are several possible solutions. Depending on which syncing and security options were active at the time of the accident, you could use AnyUnlock introduced in this article to get around the lock and continue using your iPhone and all the apps.
