It can be quite overwhelming if suddenly your iPhone says no SIM is available. However, every problem has a solution! This article discusses 11 ways to fix the “No SIM Available on iPhone” error.
With today’s advanced technology, everyone needs to use cell phones. Thus, you may need SIM card service to use social media software via data networks, make phone calls, send text messages, etc. Therefore, SIM becomes very important. But if you see the “no SIM available iPhone” error after inserting your SIM card into your device, it means something is wrong either with your iPhone or the SIM.
How to Fix When iPhone Says ‘No SIM’
However, there are several ways to find out the root cause of this issue and eventually fix it. And that’s what this article is about!
We will go over everything you need to know about a SIM card, why your iPhone isn’t recognizing it, and how to fix no SIM on iPhone. So, let’s dive straight into it!
Further Reading: How to Bypass iPhone Unavailable Lock Screen >>
SIM stands for “Subscriber Identity Module.” It is a little magical card that you put in your phone to unlock your phone’s connection to your cellular network.
It stores important information about your phone number, contacts, and even security stuff. In short, it allows you to make calls, send texts, and use mobile data.
Without a SIM card, your phone would still work; however, you won’t be able to call or text anyone using wireless data over 4G or 5G.
When iPhone says no SIM, it means that your device is unable to recognize or detect the presence of a SIM card.
There can be several reasons that can lead to this error message. For instance:
Regardless of why your iPhone cannot recognize the SIM card, we have several solutions to resolve the iPhone no SIM problem. Let’s have a look.
Whether you’re getting the “No SIM Available on iPhone” error or your iPhone cannot detect it, here are 10 common ways to fix this issue:
It could be that your SIM card is loose or inserted improperly when iPhone keeps saying no SIM available. Therefore, the first quick fix you can try is removing and reinserting your SIM card.
You’ll find the SIM card slot either on the top between the sleep/wake button and headphone jack (for older iPhone models) or on the right or left side of the device (for newer models). Once you find it, here’s what to do:
If the SIM was loose or inserted wrongly, the “No SIM Available on iPhone” error will go away, and you’ll see the signal bars/carrier name instead.
However, if this method doesn’t work, you can try the following trick.
The universal solution to resolve any glitch in an iPhone is to restart it. Whether iPhone keeps saying no SIM or is unable to catch the signals of your carrier, restarting it might fix it.
Here’s how to restart different iPhone models:
Restart iPhone 8 and Earlier
Restart iPhone X and Later
Restarting your iPhone usually solves all issues that come up due to slight system glitches. However, you can move on to the next solution if you still see the “No SIM on iPhone” error.
There’s a possibility that the Airplane Mode on your iPhone is enabled, causing no SIM error iPhone. Therefore, you can quickly check to see if it’s on and turn it off. Or simply turn it on and off again to rule out this reason. Here’s how to get rid of no sim on iPhone in this way:
Turn Airplane Mode Off
If your iPhone was unable to detect your SIM due to the Airplane Mode, you would be able to see the signal bars and carrier name on your iPhone.
It is possible that your carrier plan has been canceled, suspended, or deactivated due to some reason. This can also be one reason for you to see a “No SIM Available on iPhone” error.
Therefore, checking your iPhone’s carrier plan is always a good idea. For this, you can call your carrier’s helpline, provide the necessary details, and check whether you have an active plan or not.
In case you don’t have an active plan, you can subscribe to one. However, if you have an active plan and still your iPhone says no SIM available, you can try one of the following methods.
If your network settings are out of sync, it will cause iPhone saying no SIM. So, resetting the network settings on your iPhone is a good way to resolve this issue.
This will remove all network settings from your device and disconnect you from Wi-Fi and mobile data. When you connect back to the internet, your previous network settings will be restored, and you can use your cellular data again.
Follow these steps to see how to fix no SIM on iPhone.
Go to Transfer and Reset Phone
Reset Network Settings
If the issue was due to the network settings, resetting them will resolve the “No SIM” issue. However, if this method also goes in vain, you can always try the next method on our list.
If there are some issues with your iOS system, you will also face the iPhone no sim available problem. AnyFix, a professional iOS system repair tool, can help you fix it immediately.
It can solve almost all iOS issues in simple clicks, like iPhone saying no SIM available, stuck on Apple logo, white screen, frozen screen, etc. 3 repair modes are offered and you can even repair your system without losing data. All iPhone models and iOS versions are supported, like iPhone 15 and iOS 17.
Just follow the step-by-step guide below to see how to fix no SIM on iPhone.
Step 1. Free download AnyFix on your computer. Open it and choose the System Repair mode.
AnyFix System Repair Option
Step 2. Connect your iPhone to the computer. Choose the issue type and click on Start Now.
AnyFix System Repair Device Bug
Step 3. You will see 3 repair modes. Click Standard Repair if you don’t want to lose data.
AnyFix Standard Repair
Step 4. Then you need to download the firmware for your device.
Step 5. When completed, click Start Standard Repair to start the fixing process.
Step 6. Wait for a while and you will see the success screen when it is completed.
Repair Is Completed
Another common reason to face the “No SIM Available on iPhone” error can be due to an outdated iOS version. Therefore, try updating your iOS to see if it gets resolved.
To update your iOS:
However, if your iPhone is up-to-date, try updating carrier settings.
If your iOS version is not the culprit, maybe your network carrier updated their settings. You usually get a notification for such updates; however, if you didn’t get one or missed it, you can always check if an update is available.
Here’s how:
Update Carrier Settings
If an update is available, you’ll see a prompt for it. However, if there is no carrier settings update, maybe you have a malfunctioning SIM card.
If you still find iPhone says no SIM available after trying all the tips and tricks mentioned earlier, there’s a chance your SIM card is broken.
But how to check whether your SIM card is malfunctioning?
Simply insert it into another device to see if it is recognized. Or, insert another SIM card into your iPhone to confirm whether the issue lies with the SIM or the device.
Otherwise…
Just like restarting an iPhone resolves several known and unknown issues, factory resetting your device also eliminates the issue causing your iPhone to act up.
So, if your iPhone says no SIM, even after trying all the mentioned methods, it’s time to reset it to its factory version.
Here’s how to factory reset your iPhone:
Transfer or Reset iPhone
Erase All Content and Settings
This will factory reset your iPhone, and you can set it up as new. With everything starting from scratch, the “No SIM Available on iPhone” error will likely disappear, and you can make calls and send texts using your SIM once again.
If nothing else works, and you’re still getting the “No SIM” notification, it means something is wrong with the hardware, and the issue is more technical than we imagined. This calls for contacting Apple Support and getting your iPhone checked by a professional.
However, there is one last trick up our sleeves! Before you give up hope, you can always try fixing the “No SIM Available on iPhone” issue with a reliable third-party app.
There’s a possibility that your iPhone has a SIM or carrier lock on it, restricting it from recognizing the SIM card of another network. This usually happens when you purchase a second-hand iPhone that was originally bought from a specific network provider.
If your iPhone has a carrier lock or SIM card restriction on it, you can instantly remove it with the best iPhone unlocker – AnyUnlock.
AnyUnlock is like a super handy tool for your iPhone! It is complete iOS unlocking software that helps you to unlock SIM lock, bypass iCloud activation lock, find Apple ID email, unlock screen lock, etc. Except for unlocking SIM card iPhone, AnyUnlock can also resolve other SIM lock-related issues. Check what it can do for you:
Free get & try AnyUnlock and follow the detailed step guide to unlock the SIM lock below:
Step 1. Download and launch AnyUnlock on your PC > Select the “Remove SIM Lock” option.
Choose Remove SIM Lock
Step 2Connect your iPhone to your PC > Click “ Remove Now” after checking and confirming your phone information is ok.
Click Remove Now
If you haven’t yet jailbroken your iPhone, follow the on-screen instructions before attempting to unlock your SIM card.
Step 3Follow the on-screen instructions to turn off the Wi-Fi on your iPhone and re-insert the SIM. Click on “Ok” to continue.
Forgot This Network on iPhone
Step 4 After that, AnyUnlock will begin to remove your SIM lock automatically. Wait until your phone gets unlocked.
SIM Lock Removed Successfully
It can be quite worrisome to get a “No SIM Available on iPhone” error even when your SIM is inserted correctly, and you have an active data plan. However, there can be other reasons behind this issue, like a glitch with the system or outdated iOS or carrier settings.
We have rounded up 11 quick ways on how to fix no SIM on iPhone. Once you find that the regular methods do not solve the problem, then do not hesitate to try AnyUnlock. As a professional Apple unlocking tool, it can unlock almost all Apple locks and solve your problems quickly and safely. Just free download AnyUnlock to try it!
