Hi there,
I just entered the wrong screen passcode on my iPhone 14 Pro Max, and now it’s showing “iPhone Unavailable” with no timer underneath. Please, what does this mean and how can I fix it? Kindly help!
Free download AnyUnlock – iPhone Password Unlocker to 1-click to resolve Phone Unavailable No Timer.
It’s no longer news that Apple has one of the most rigid security systems of all technology companies out there, which is why you are always required to use strong yet simple to remember security details when setting up your device.
Sometimes one can fall victim to a lost or forgotten passcode. In such a scenario, entering the lost screen passcode multiple times can cause Apple to disable your iPhone and your device will display “iPhone Unavailable” with a timer underneath, which signals that you can try again after a specific time.
However, in some cases, you might not find the timer underneath, just like the situation described above. If that’s what you are currently experiencing, and wondering how to fix it, this post is for you. So continue reading as we explore the 4 simple ways to clear iPhone unavailable no timer issues.
By default, your iPhone should give you another opportunity to enter your screen passcode after entering an incorrect one for the first time. However, after 5 consecutive attempts, the device becomes disabled for some minutes. The stipulated time-frame for trying your new passcode lengthens as you try.
Find below the correspondence between your attempts and the time frame for which your iPhone will be disabled:
Once you exceed the aforementioned attempts, and still enter the wrong passcode, your device will show iPhone Unavailable with no timer underneath. This means your device is permanently locked with no waiting timer for you to retry. You cannot perform any operation on the device besides emergency calls.
Whether your iPhone is unavailable or disabled, all you need to do right immediately is bypass the lock screen and get into your iPhone again. The best thing to unlock iPhone is to get a professional iOS unlock tool to help you. Though there is a wide variety of software that supports this feature, AnyUnlock – iPhone password unlocker is the most effective.
AnyUnlock offers the easiest and safest way to bypass your iPhone unavailable no-timer screen without compromising your system. It’s the best iOS unlocker and second to none, as it handles your iPhone security challenge and grants you access to your device within the shortest possible time. You can also use AnyUnlock with iOS devices like iPads and iPods.
Free get AnyUnlock and follow the detailed steps to unlock iPhone/iPad without passcode or iTunes:
Step 1. Free download AnyUnlock and launch it on your computer, click Unlock Screen Passcode.
Choose Unlock Screen Passcode
Step 2. Connect your iPhone to the computer, and wait until AnyUnlock has detected your iPhone. Click Start Now.
Click Start Now Button
Step 3. Download on the iOS firmware package page. When the firmware is downloaded, click the Unlock Now option. Then AnyUnlock will unlock the screen passcode automatically.
Tap on Unlock Now
Step 4. When the recovery process is completed, you will see the Screen passcode removed successfully interface.
With iCloud, you can also reclaim control of your locked or disabled iPhone. Your iCloud profile lets you fix the iPhone unavailable no-timer security challenge you are faced with on your iPhone easily and quickly using the Find My feature. Are you wondering how this is possible?
Well, the Find My feature on your iPhone supports the Erase iPhone function which could be used to wipe your device remotely. By doing this, all installed content and settings you have on your iPhone is automatically cleared, leaving the system apps and settings.
Using this solution to bypass the iPhone unavailable no-timer issue is super easy, but you must fulfill some conditions for it to work. Find below some of the prerequisites to fulfill:
You can apply the following procedure to fix iPhone unavailable using iCloud:
Step 1: Visit iCloud.com on any mobile or computer system with a stable internet connection. Click the Sign In button and enter your Apple ID and password in the empty field provided.
After entering your details, a 2FA code will be sent to all devices connected to your Apple ID. Check one of the devices, copy the code, and enter in the space given.
Copy the Code and Enter in the Space
Step 2: Next, the following interface will come up on your screen:
Fix iPhone Unavailable No Timer via iCloud
Swipe down the screen and select Find My. For security purposes, iCloud might request that you enter the password of the Apple ID you just signed in. Please do, and click the appropriate button to proceed.
Step 3: Once done, you will be directed to a screen showing all the devices linked to your Apple ID.
Click on your iPhone and you will get an interface similar to what is shown below:
Tap the Erase This Device icon
Tap the Erase This Device icon and your device will wipe immediately. Once the device is erased proceed to set it up and enter a new screen passcode that you can always remember.
iTunes is the native music app for Apple devices. It lets you stream your favorite songs easily and quickly. You can also leverage this app to bypass iPhone unavailable no-timer issues. The approach used to help you reclaim control of your iPhone is straightforward (restoration).
When you restore your iPhone using iTunes, all content and settings, including the screen passcode. Follow the step-by-step guide below to clear iPhone unavailable no timer on your device using iTunes:
Step 1: Download the latest iTunes on your computer, and run it to help you unlock your iPhone. Once the app comes up, get the locked iPhone and connect it using a USB cable.
Step 2: Next, proceed to enter recovery mode on your iPhone. For folks who don’t know how its down, please use the instructions that suits your iPhone model from the guides below:
Force restarting iPhone 8 and later versions
Force restarting iPhone 6 and earlier versions.
This is how the recovery mode screen looks like
Put Your iPhone into Recovery Mode
Step 3: Once iTunes confirms your device is in recovery mode, it will show a screen advising you to update your phone. Click on the Restore button to unlock your device.
Another effective solution to solve iPhone unavailable no timer is via the Erase iPhone option displayed on your iPhone screen when it enters the security lock-out mode. Erase iPhone is the latest feature found on iPhone running on iOS 15.2 and later (excluding iOS 17.0).
This solution resets your device and gets rid of any security settings you’ve set in the past. However, mind you, there are certain preconditions you must put in place before you can use the Erase iPhone option to fix iPhone unavailable no timer. You can check them out below:
Once you have all of the above ticked, you can use the stepwise guide given here to unlock your iPhone:
1. While on the iPhone Unavailable no timer screen, click on the Erase iPhone button at the bottom right corner of the screen.
Fix iPhone Unavailable No Timer with Erase iPhone
A notification briefing you on the consequence of using the Erase iPhone option to unlock your iPhone will come up. Click Erase iPhone again to continue.
2. Enter the password to the Apple ID connected to the iPhone in the space given, your device will be wiped automatically. When that’s completed, your iPhone will reboot. Proceed to set it up and create a new screen passcode.
iPhone unavailable no timer isn’t a big deal anymore with the solutions introduced in this guide. We’ve demonstrated the 4 effective solutions that you can apply to reclaim access to your iPhone. Our best solution from the options provided is the one with the AnyUnlock tool. The software rescues your iPhone from any security challenge, including iPhone unavailable no timer, that you may encounter.
