“I restarted my iPhone. After that it requires me to enter passcode to unlock, but I didn’t set passcode on my iPhone. why it happens? How can I unlock my iPhone?” – An iPhone user asked.
We are going to address the issue of the iPhone requiring passcode after restarting in detail. Before going into detail, we must know the cause and ways to fix this issue. Step by step, all the detailed information related to the iPhone requires your passcode after restarting is given below.
Before that, we must know the requirements of the passcode. This is to be asked because the user’s device is disconnected from the iCloud. It may be there is no internet connection, so that is why we cannot make a pair with the server.
And if you have some other problems about iPhone restarting, you can find solutions in the articles given below:
Recently many users have complained that the iPhone requires passcode after restarting but I don’t have a passcode. iPhone requires your passcode after restarting only in one condition that the user’s iCloud account is not connected with the device. Users need to access all the tools, so before that user needs to connect the iCloud account to the device. All the useful tips are given below to resolve how to unlock iPhone requires passcode after restarting.
If you get an iPhone as a gift from a friend, then you are the second person to buy the same device. In both conditions, your passcode is required when iPhone restarts. This situation can be resolved with the help of the Try Default Passcode method. The complete procedure is given below.
The user needs to completely wipe the device. Users can check the iPhone’s IMEI or MEID number if the user is not able to get these. Then the user needs to contact the salesperson. He will contact the actual owner of the iPhone and get back to you with the details.
Here are the steps to check the IMEI number of the device. Users can follow any step that is given below.
Check Your IMEI Number
We know that there is a minor change to get the device’s passcode for the original owner. However, users need to follow or take the help of any third-party tool. Check out the images that are given below to understand deeply.
When iPhone needs a passcode after restarting, Many users find that typing the default passcode works for them. However, the user must go for the default passcode that is given below.
For 4 digit default passcode
For 6 digit default passcode
There are many disadvantages of this method. Check out all that is given below.
If you have failed with the default passcode when iPhone requires a passcode after restarting, you can’t access your device. In this situation, to unlock the iPhone, you can use AnyUnlock to help you. With this iPhone unlocker, you can bypass the iPhone screen passcode of any kind, remove Apple ID, bypass remote MDM, and remove local MDM from your iPhone or iPad easily.
Also, this tool is compatible with almost all iPhone models and iOS versions, the latest iPhone 14 and iOS 16 are also supported. You don’t need any technical skills to operate it. Just follow the steps that are given below, and you can easily unlock your phone within a few minutes.
Step 1. Download AnyUnlock on your computer. Connect your iPhone/iPad to AnyUnlock on your computer. Click the Unlock Screen Passcode button.
Choose Unlock Screen Passcode
Step 2. Click Start to begin downloading the iOS firmware for screen password.
Click Download to Download iOS Firmware
Step 3. Wait for the iOS software to be downloaded; once done, click Unlock Now.
Tap on Unlock Now to Continue
Step 4. Wait a minute. When the operation is complete, you will see the Screen passcode removed successfully page below.
iOS Device Unlocked Successfully
In addition to the iPhone requires your passcode after restarting problem, we also list some other questions about iPhone passcode. And here are the answers.
Why does my iPhone ask for passcode after factory reset?
In addition to restarting, some users find iPhone also asks for passcode after factory reset. If you are in this situation, you can try the default passcode mentioned above. If failed, you can click iPhone Asking for Passcode After Factory Reset to solve this problem.
What to do when iPad requires passcode after restarting?
All the methods above can also be applied to solve this problem. But compared with other methods, using AnyUnlock to unlock your iPad is obviously the easiest and quickest way.
In this article, we discussed iPhone requires your passcode after restarting and ways to fix this problem. This has come out after doing a lot of research by experts. Among them, AnyUnlock is a good choice when you want to unlock your iPhone. You can download AnyUnlock now to start unlocking your phone.
