How to Fix Apple ID Disabled or Locked
Getting error messages like “Your Apple ID has been disabled” on your iPhone can be frustrating but that’s not the end of the device. You can easily clear the Apple ID error message popping up on your iPhone using any of the five (6) solutions shared in this post. Read on >>
Author Avatar Joy Taylor Last Updated: Aug. 13, 2024
Hi,
I just turned ON my iPhone 12 after a long while, and discovered my Apple ID is disabled. I noticed this when I tried downloading an app from the App Store and my device displayed the error message “Your Apple ID has been disabled”.  How can I fix this? Please help!
It’s no news that the Apple ID is the powerhouse to all Apple devices and everything underneath its ecosystem. Without the Apple ID, you cannot perform operations such as the playing of music, app installation, and more, on your iPhone.
So it can be annoying when you encounter an error message like “Your Apple ID has been disabled for security reasons”, just like the above. Fortunately, it’s nothing to worry about now that you are here, as our team has figured out how to fix Apple ID disabled or locked issues.  Continue reading to learn how this is done.
What Does Mean of Apple ID Locked or Disabled?
If your Apple ID is locked or disabled, it simply means one of the following issues has occurred:
  • Provision of Wrong Apple ID Credentials
The Apple ID requires you to enter your correct credentials each time you are asked to provide them. Your inability to recollect or remember these credentials/details correctly can cause your device to display the “Apple ID is disabled” error message.
  • Too Many Apple ID Reset Prompts
Did you send the Apple ID reset prompt too many times? If so, then you can receive the “Apple ID is disabled” error message on your device. The reason for this is that Apple suspects there’s a security threat on your profile (Apple ID).
  • iOS/System Issues
iOS or system issues are another crucial reason why your Apple device misbehaves and displays the “Apple ID is disabled” error message. In this case, you need to update your system or repair your firmware package using the most appropriate software.
Other reasons for the Apple ID disabled issue include:
  • Billing or Disputed Charges
  • Not Using Your Apple Profile for A Long Time
1. Unlock Locked or Disabled Apple ID without Password [SAFE!]
How to Fix Apple ID Disabled or Locked? The most straightforward and easiest way to fix your locked or disabled Apple ID is to unlock it. The most important thing to unlock an Apple ID is to try safe and reliable unlocking software.  AnyUnlock – iPhone Password Unlocker is a top-quality iOS unlock utility with an easy-to-manage interface that allows you to quickly unlock or fix Apple ID issues on any iPhone or iPad model. The software clears the “Apple ID is disabled” error message on your iDevice with high accuracy.
With AnyUnlock, You don’t have to fret or worry about data loss when using this iOS unlock program, as it doesn’t interact with any content on your device. It handles disabled or locked Apple ID issues using a secure approach, by scanning your entire system and suggesting the most suitable firmware package to fix your iPhone.
Key Features
  • 1-click to remove or clear the Apple ID disabled error message on your iPhone or iPad.
  • Only 3 steps and a few minutes. As easy and fast as possible.
  • Supports all iPhone/iPad models and iOS versions.
  • All round functionality: screen unlock, Screen Time Passcode unlock, MDM bypass, iDevice verification, iCloud activation lock, SIM lock, and many others.
Free get the latest version of AnyUnlock and follow the steps below to unlock locked or disabled Apple ID>>
How to Unlock Locked or Disabled Apple ID with AnyUnlock:
Step 1. Free download and launch AnyUnlock on your Mac/PC > Click the Unlock Apple ID mode.
Click Unlock Apple ID from the Homepage
Step 2. Connect your locked or disabled iPhone to PC/Mac with a USB cable > Click Unlock Now and continue.
Click Unlock Now Button
Step 3. Once done, the Apple ID unlock process will commence immediately. Wait patiently for the AnyUnlock to finish bypassing your Apple ID lock issues, then you will get Apple ID removed successfully page below.
Apple ID Removed Successfully
2. Reset Your Apple ID Password on Apple’s Website
Resetting your Apple ID details on Apple’s website is another effective way to bypass or fix the “Apple ID is disabled” issue you are battling with on your iPhone. This technique requires that you visit the official website of Apple, provide the necessary details required to reset your device, and then hit the right buttons to regain control of your Apple profile so you can start using your iPhone again.
Here’s the guide you need to follow for you to reset your Apple ID via the Apple’s website successfully:
  • Open a browser on any internet-enabled device, whether mobile phone or computer. Visit appleid apple com, and tap on Sign In to proceed.
  • On the next interface, click on the blue Forgot your Apple ID or password icon.
Click on the Blue Forgot your Apple ID or Password Icon
  • Immediately, your device will redirect you to another page similar to the one down here: Enter your Apple ID (also known as the email address) in the space provided, then type the characters displayed in the field underneath.
  • Once done, the Continue button will activate. Click on the button to proceed.
  • Now, you will be directed to a new screen requesting you to confirm the mobile number linked to your Apple ID. Kindly enter the number correctly, and click on Continue
  • After that, a notification will be sent to one of the devices connected to your Apple ID. Here’s what will be displayed on your browser: Get the iPhone, and click on Allow to proceed with resetting your Apple ID.
  • After that, follow the on-screen guide provided to finish resetting your Apple ID in no time.
3. Remove Locked Apple ID Using the Recovery Key
With your recovery key, you can also resolve the Apple ID is disabled issue currently displayed on your iPhone screen. This free solution is very easy to implement and can be done with any mobile device or computer system. All you need is a reliable data connection, and you are good to go.
Apple the procedure down here to remove locked or disabled Apple ID on your iPhone using the recovery key:
1. Go to iforgot.apple.com, and click on the Reset Password icon.
click on the Reset password icon
2. A new interface with fields to enter your Apple ID will come up. Kindly provide the correct details, and hit the Continue button.
3. Another screen requesting you to provide the corresponding Recovery Key to verify you are the true owner of the device will appear.
4. Kindly check one of the devices connected to your Apple ID for the code. Once gotten, enter the code, then hit the Next icon.
5. Once Apple verifies your code, a new screen with empty fields where you enter your new password will be displayed.
6. Provide a strong password that you can easily remember, then click the appropriate button to finish.
4. How to Fix Locked Apple ID via iforgot
Still, having issues with your Apple ID? Then you should try fixing it via iforgot.com, a website designed by Apple to help end-users restore or reset their lost or forgotten Apple ID credentials.
The website offers a simple yet free way to reclaim access to your iPhone right from the comfort of your home. There’s not much requirement required for you to fix Apple ID successfully is disabled via iforgot. What’s required of you is a reliable data network and an internet-enabled device. e.
Once you have all of these in place, follow the stepwise guide shared down here to fix your locked Apple ID:
Step 1: Visit iForgot – Apple, and hit the Reset password button.
Provide your Apple ID credential, and then enter the captcha verification code in the appropriate space. After that, tap on Continue
Step 2: Next, you have to enter the phone number associated with your Apple ID, then click Continue
Enter the Phone Number Associated with Apple ID
After that, a 2FA verification code will be sent to one of the devices with your Apple ID signed in on it.
Enter the code correctly, and you will be directed to the screen down here:
Enter the Code Correctly
5. Fix Disabled Apple ID by Using Two-Factor Authentication
Have you enabled the two-factor authentication feature on your iPhone in the past? If so, you can always fix your disabled Apple ID using the feature. No subscription pricing or payment is required for you to use this approach to remove Apple ID issues on your iPhone.
Use this guide to fix disabled Apple ID via two-factor authentication:
  • Hit the gear icon on your iPhone home screen to open Settings, then click on your profile picture.
  • Tap on the Password & Security button, and this interface will come up:
Tap on the Password & Security Button
  • Click the blue Change Password button, and enter your screen unlock passcode in the interface that follows.
  • A new screen where you enter your new password will come up. Please enter the characters you can easily recollect in the future.
6. Contact Apple Support Directly to Fix Apple ID Is Disabled or Locked
If your iPhone still displays the Apple ID is disabled issue, contacting Apple support is the next thing to do. You should connect with Apple customer care to relay your complaint so it can be resolved for you.
Tip For You: How to Protect Your Apple ID
Apply the tips below to protect your Apple ID and all the crucial data on your iPhone:
  • Enable 2FA Authentication on your iPhone to add an extra security layer to protect your Apple ID.
  • Do not share your Apple ID details with anyone, whether relative or not.
  • Ensure you keep your Apple ID account updated, by simply using it to carry out operations from time to time.
  • Always update your iOS.
  • Always use a strong password or passcode for your iPhone.
Final Words
Apple ID is disabled or locked is very simple to fix when you have the guide above at your disposal. We’ve introduced the 6 ways to resolve Apple ID issues on your iPhone. Apply the one that suits you.
For folks requesting our recommendation, our best solution is AnyUnlock. AnyUnlock powers everything you need to unlock your iPhone without compromising it. Download and install AnyUnlock today to fix Apple ID disabled or locked >
