How to Fix App Store Keeps Asking for Password Issue
“This is extremely annoying. I have an iPhone 13 mini, and every time I download a free app, I’m prompted for my Apple ID password. I tried all the fixes that google have turned up for me, but nothing helps.” – An iPhone user asked on Reddit.
Author Avatar Joy Taylor Last Updated: Oct. 09, 2024
AnyUnlock – Best Apple ID Remover
AnyUnlock can help remove Apple ID and stop App Store from asking for password easily. Download it now and enjoy a smooth download and update in App Store.
Why does the App Store constantly prompt me for passwords, even after I enter them right numerous times? The popup simply will not go away, and I am unable to stop it.  How do I get App Store to stop asking for passwords? If your App Store continues prompting you to enter your password even after you’ve entered it properly numerous times, then You’ve come to the right spot. Several reasons can cause this issue. In this post, we will walk through ways to resolve this error message in four methods. All methods will be simple for you to implement.
You may also like: How to fix iPad won’t download apps
Why Does App Store Keep Asking for Password?
If you are prompted to again and again enter your iTunes Store password, there may be a problem with your account, including a software update, recovering an Apple device, or changing specific application or account settings. It is often triggered by a failed download that is undetectable to your devices. Let’s proceed further to know the fixes on the Apple App Store keep asking for my password?
5 Fixes to App Store Keeps Asking for Password Issue
In this article, we give you four traditional solutions to fix the App Store that keeps asking for password issues. Let’s have a look at them below.
1. Restart Your iPhone
Before trying any other techniques to address the problem of the App Store constantly asking for passwords, you should first restart your Apple device. After rebooting the iPhone or iPad, many issues or error messages can be resolved. Just follow the steps below.
  1. If you have an iPhone 8 or a previous model iPhone, just Press and Hold the Power button till you see the power off slider.
  2. If you have an iPhone X or later, Press and Hold the Side button and one of the Volume buttons simultaneously until the slide to power off shows.
  3. To restart your iPhone, swipe the red power symbol from left to right in either scenario.
  4. To switch your iPhone back on, wait a few minutes, then press and hold the power button until you see the Apple logo in the middle of the screen.
  5. Finally, check if the issue is fixed or not! If not, jump to the next method of this article.
    Restart Different Modes of iPhone
2. Check Updates of Apps
This issue might occur if you do not download or update an app from the App Store. As a result, you should verify your purchased app from the App Store to see whether any upgrades are required. The App Store symbol with a red circle indicates that updates are ready for installation. The number within the red circle indicates how many app updates are currently available. Then, to finish all app updates, you may need to do the following actions.
  1. Open “App Store” and click on “Updates”.
  2. Click on “Update” for each app or just click on “Update All” to fix the issue.
    Update Apps in App Store
3. Sign In and Out of Apple ID
If any of the above fixes fail to resolve the issue of the App Store continuously asking for passwords, you may need to reset or unlock your Apple ID. It can usually resolve account-related issues. You must sign out and then sign back into your device. You should remember your Apple ID password and proceed with the procedures below.
  1. Open “Settings” and select your name from the drop-down menu at the top of the screen.
  2. Sign out by scrolling all the way down this menu. To turn off “Find My iPhone”, you’ll need to enter your Apple ID password.
  3. After you’ve signed out, go back to this menu and touch “Sign In” to login back to your Apple ID.
    Sign out of Apple ID on Your iPhone
4. Arrange the Settings of iTunes & App Store
The App Store keeps asking for passwords; maybe it’s because you set the Password Settings for purchases and in-app purchases to Always Require, which means you must enter your password every time you purchase, even if you’ve already logged in with your Apple ID. And, for free downloads, the App Store keeps asking for passwords, most likely because you enabled the Require Password setting. You can turn it off if you don’t want to put passwords when downloading free things.
Simple Steps for You:
  1. Go to the “Settings” app and tap on your name. Then click on the “iTunes & App Store.”
  2. Click on “Password Settings” and tap on “Require After 15 Minutes”  just below the purchase and in-app purchase option.
  3. Turn off the  “Require Password”  field in the free downloads.
  4. Enter your password if asked and then tap on “OK.”
    Change Password Settings for iTunes and App Store
5. Remove Apple ID with Simple Clicks
If restarting your phone didn’t fix the problem, then you can remove the Apple ID to fix it. When your Apple ID gets locked, you are not able to log in to any of Apple’s services, such as App Store and iTunes. Therefore, if you can unlock the Apple ID, then with a high probability, the App Store won’t ask for a password anymore.
To unlock Apple ID, you need a professional iPhone unlocker. AnyUnlock, as a Complete Solution to iOS Locks, is capable of unlocking your device from any kind of iPhone lock, including unlocking Apple ID without password, bypassing MDM lock, iTunes backup password, etc. With this application, you will not risk losing any data or being attacked by viruses. Let’s see what else AnyUnlock can do for you.
AnyUnlock – Apple ID Unlocker
  • Unlock Apple ID with simple clicks in a few seconds.
  • Find, view, and export all kinds of iOS passwords.
  • No erase of data on your iPhone, 100% clean & safe.
  • iPhone 15/16 and iOS 17/18 are supported.
Follow the steps below to unlock the Apple ID. The following steps are applicable to iPhone running iOS 11.4 and above and the Find My iPhone function is enabled.
Step 1. Download and install AnyUnlock on your computer. Launch the app and click on the “Unlock Apple ID” option.
Click Unlock Apple ID from the Homepage
Step 2. Then, connect your iPhone to your computer via a USB cable and click on Unlock Now to continue.
Click the Unlock Now to Start the Unlocking Process
Step 3. It will start to unlock Apple ID automatically.
AnyUnlock is Removing Apple ID
Step 6. Just wait for a few minutes and take the following steps to set up your device and complete the Apple ID unlocking process.
Apple ID Removed Successfully
If the Find My iPhone function has turned on and the iOS version is below 11.4, you need to reset the settings on the device. Or if the Find My iPhone function has been enabled on your iPhone, please refer to the Apple ID unlock guide.
That’s all! The App Store’s constant request for passwords is irritating. The reasons behind this are multi-faceted. We’ve provided you with a number of options for dealing with this issue. You should be able to quickly resolve the popup password issue after attempting each of them. If you need to unlock your iPhone, just download AnyUnlock and follow the tutorial to do it.
