Gone are the days when you need to struggle just to reset your locked iPhone just to regain access and full control of it. Right now, you can perform a factory reset on your iPhone when locked easily and quickly using any of the four simple hacks/techniques introduced in this post. Read on>>
Hi, I got an iPhone 8 Plus I haven’t used for a while now. Few days back I decided to hand it over to a friend who is in need of a mobile device. But unfortunately, I can’t remember the unlock passcode. So I decided to perform factory reset on the locked iPhone but no way. Is there anybody who has been in this type of situation and fixed it? Please help with the corresponding solution.
Factory reset is one of the many troubleshooting techniques to fix problems like lost or forgotten password issues on an iPhone, your iPhone is disabled, or iPhone screen passcode not working. But sometimes the procedure can be quite difficult just as in the situation above.
If you are in a similar shoe and need to reset urgently, this post is what you need. Here we will guide you on how to factory reset iPhone when locked. The techniques introduced are simple to employ, fast and reliable. Keep reading as we unveil them.
Lost or forgotten passcode is the major reason why most iOS devices, including iPhone, are locked. When you experience such on your device, it’s definitely because you cannot recollect the corresponding unlock passcode.
Losing the unlock passcode to your iPhone can be quite painful, especially when you have an urgent task to fulfill with the device. When such happens, factory resetting is a great thing to do.
Factory reset helps you bypass the screen lock issue by simply wiping your iPhone to clear all content and settings on it, including passcode protection. When you do this, all data is lost leaving the system apps and data.
Just before you proceed to perform a factory reset on your locked iPhone there are some crucial things to note. Some of them include:
Then, if you forgot Apple ID or its password, how to factory reset a locked iPhone? Don’t worry! Here we will guide you on how to factory reset locked iPhone when locked in different ways. Please keep reading!
The best way to perform a factory reset on an iPhone is to use an effective iOS unlock tool like AnyUnlock – iPhone Password Unlocker. With AnyUnlock, you can successfully reset your locked iPhone with minimal stress right at your home. This software resets your device without complications.
AnyUnlock allows you to perform a factory reset without putting your iPhone in recovery mode or connecting the device to iTunes. It’s the safest iOS unlock tool you will come across online because of the fascinating features installed in it.
Free get AnyUnlock explore more about AnuUnlock and follow the detailed steps to reset a locked iPhone:
Step 1. Free download and launch AnyUnlock on your computer >Click Unlock Screen Passcode mode.
Choose Unlock Screen Passcode
Step 2. Connect your iPhone to your PC/Mac > Hit the Start Now button to proceed.
Click Start Now Button
Step 3. Then AnyUnlock will match a firmware package for your iPhone. Follow the on-screen instructions to get a matching firmware package > Click the Unlock Now option. Then AnyUnlock will unlock the screen passcode automatically.
Tap on Unlock Now
Step 4. Wait for the unlocking process to be completed, you will get the page below.
While the aforementioned solution is the ultimate one to perform a factory reset on your iPhone, you can also leverage the iTunes app to carry out a similar task. iTunes allows you to wipe any iOS device, whether iPhone or iPad, with minimal stress.
The approach is quite straightforward, as you just have to overwrite data by simply restoring the device. Here’s how to use iTunes to factory reset an iPhone:
Factory Reset Locked iPhone using ‘Restore iPhone’ via iTunes
From iCloud, you can also bypass screen locks or reset your iPhone to factory settings. All you need is the corresponding Apple ID details connected/logged in on the iPhone, then use the Find My Device feature to erase it.
To use this technique, check the guideline below:
Hit All Devices Option
Hit the Erase iPhone Icon
Recovery Mode is another simple technique you can use to reset your iPhone to factory settings right from the comfort of your home. To use the technique, you need the Apple iTunes app.
The iTunes app lets you perform a factory reset on your iPhone by simply entering recovery mode, so as to facilitate communication between the locked device and iTunes. Once done, you can then proceed with erasing all content and settings without restrictions.
You can reset your locked iPhone with iTunes via recovery mode by using the step-by-step guide below:
Step 1: Download and Install the iTunes App
Get the iTunes app on your Windows or Mac computer system. Make sure it’s the latest version you have. Once confirmed, proceed to the next step.
Step 2: Enter Recovery Mode
Put off the iPhone using the correct key combinations. Ensure the screen is blank, then proceed to ensure recovery mode. Use the guide that corresponds with your iPhone model:
iPhone 8 and Later Models
iPhone 7/7 Plus
iPhone 6 and Earlier Models
Step 3: Restore the iPhone
The iTunes app should automatically come up on detecting your device in recovery mode. However, if it doesn’t, you can launch it manually. An interface with a prompt notifying you that there’s a problem with your iPhone will pop up just like below:
Tap on the Restore Button
Tap on the Restore button, then hit Restore and Update to validate your click. Once done, agree to the terms and conditions that follow, and iTunes will commence a factory reset on your locked iPhone.
After the reset is completed, your iPhone will reboot, and the setup screen will come up for you to configure it. Follow the on-screen instructions to set up, then restore data from backup.
All methods would fix screen lock issues and reset your iPhone, so you can select anyone. However, if you don’t want to experience data loss, then you should proceed with the AnyUnlock method. The software resets your iPhone and clears screen lock issues without compromising your system or the data existing on it.
Resetting your iPhone to factory mode is no longer a challenge with this guide at your disposal. We’ve provided several methods to factory reset a locked iPhone.
And AnyUnlock should be the most efficient way to reset/unlock iPhone without iTunes or iCloud. It supports you to reset screen passcode, Face ID, or fingerprint, even when your iPhone is cracked. Explore more about AnyUnlock now>>
