How to Factory Reset iPhone SE with/without Passcode
In this article, you will discover five methods to factory reset iPhone SE. We will walk you through their step-by-step guides so you can perform them easily. No matter if you are a beginner or a professional, this guide has got you covered.
Author Avatar Joy Taylor Last Updated: Aug. 20, 2024
Have you locked yourself out of your iPhone SE and don’t even remember the passcode? Or do you want to sell it and delete all your personal data? The iPhone SE is a powerful device for users who prefer a smaller phone but better performance. It has an A13 Bionic chip, a great camera, and impressive battery life. But even with these features, this device can cause you trouble.
But don’t worry! A factory reset of the iPhone SE can solve many problems. This process erases all data and restores the device to its default settings. However, most iPhone SE users don’t know how to perform a factory reset. This article will explore how to factory reset iPhone SE with/without a passcode. Let’s get started!
Hard Reset iPhone SE with Buttons
Before trying any other method, you should hard reset or force restart your iPhone SE with buttons. This process is quite simple and easy. Also, it doesn’t require any third-party tools or software. A hard reset usually helps when your phone stops working correctly, such as getting stuck or showing a black screen. So, if a glitchy iPhone SE is your concern, you can try a hard reset.
The good thing is that it will not erase any data from your device; it will just reboot the phone, which can sometimes fix minor issues. Let’s see how you can perform a hard reset on your iPhone SE!
Here is a quick guide to hard reset the iPhone SE with buttons:
Step 1: First, you are supposed to press the “Volume Up” button of the iPhone SE and quickly release it.
Step 2: Then follow it up by doing the same with the “Volume Down” button.
Hard Reset iPhone 14
Hard Reset iPhone
Step 3: Now, press and keep holding the “Power” button. Don’t release it until the iPhone screen goes black.
Step 4: You can finally release the side button once the Apple logo appears.
However, if you still face the same issues, or you want to unlock your iPhone SE without a passcode, you can factory reset iPhone SE.
Factory Reset iPhone SE with Buttons
If you plan to sell your iPhone SE or have forgotten your passcode, you should use this method. It is basically a manual way to delete everything from your device. It will also remove the passcode unless you haven’t activated the FRP lock. In that case, you must know your Google ID credentials to access your phone.
The recommended way to factory reset iPhone SE is to restore it with iTunes. To do that, you may need a computer and a USB cable to connect your iPhone SE to the computer. If you have them both, you can proceed.
You can follow the instructions given below to factory reset iPhone SE without a passcode:
Step 1: Connect your iPhone SE to your computer via a USB cable.
Step 2: Wait until it shows your device. If it doesn’t recognize your device, enter your iPhone into recovery mode. To do that:
For iPhone SE 1:
  1. Press and hold the “Power + Home” button together.
  2. Wait until you enter the recovery mode on your iPhone SE.
For iPhone SE 2/3:
  1. First, press the “Volume Up” button.
  2. Then, the “Volume Down” button.
  3. Then, press and hold the “Power” button until you enter recovery mode.
Step 3: Now, you will see a pop-up on your computer in iTunes that says there is a problem. Click the “Restore” button.
The process will take some time to complete. You are supposed to wait until the iPhone SE starts up by itself.
However, if you are unable to follow the above steps or find the process difficult, we have a better option for you. Let’s explore it together!
Factory Reset iPhone SE without Passcode
Users often forget their iPhone SE passcode and think they can’t unlock it now. But there’s good news: You can factory reset your iPhone SE without passcode. Meet AnyUnlock, a powerful tool for unlocking iOS devices without a passcode. With this tool, you don’t have to follow manual and daunting steps to regain access to your iPhone. It will help you unlock and reset your device automatically.
But do you know what is the best part of AnyUnlock? Its user interface. Whether you are a tech expert or not, its user-friendly interface is easy to navigate. You can unlock your phone in just a few clicks. You can learn more about AnyUnlock below.
  • Unlock all screen locks – 4-digit/6-digit passcode, Touch ID, Face ID, PIN, pattern, etc. All can be unlocked.
  • Unlock in clicks – Just click the buttons to unlock your device. No skills are needed.
  • High compatibility – Unlock all iPhone and iPad models running iOS 5 and above, including iPhone SE.
  • Unlock more – Also unlock iCloud activation lock, screen lock, MDM, SIM lock, Apple ID, iTunes encrypted backup, etc.
You must be wondering how to use this amazing tool to factory reset your iPhone SE. Worry not! Let’s explore its step-by-step user guide!
Before starting, download AnyUnlock on your PC/Mac. Then, follow the instructions given below to factory reset iPhone SE without passcode:
Step 1. Launch the AnyUnlock software and select Unlock Screen Passcode mode.
Choose Unlock Screen Passcode
Step 2. Connect your iPhone to the computer and click the Start Now button to proceed.
Click Start Now Button
Step 3. Next, AnyUnlock will detect your device model and provide you with firmware. Select your device’s firmware version and click the Download button.
Get a Matching Firmware
Step 4. Once the downloading is completed, you will see the below interface. Click the Unlock Now button and proceed.
Tap on Unlock Now
Tap on Unlock Now
Step 5. AnyUnlock will start to remove the screen passcode. Once it is done, you will see the below interface.
How to Factory Reset iPhone SE without Computer
If you don’t have a PC/laptop, you can still factory reset your iPhone SE. Apple offers a feature called “Find My” that helps factory reset locked and lost iPhones. However, to use this feature, you must follow the below conditions:
  • Ensure that your iPhone SE is running iOS 15.2 or later.
  • You must have an extra iPhone with an internet connection.
  • The “Find My” option must be enabled in your iPhone SE.
  • You know your Apple ID credentials.
If you fulfill all the above conditions, you can proceed.
You can follow the instructions given below to factory reset your iPhone SE without a computer:
Step 1: On another Apple device, visit icloud.com in the browser.
Step 2: Here, sign in with your Apple ID credentials.
Step 3: After signing in, click the menu icon on the top right and select the “Find My” option.
Step 4: Here, enter your password to continue.
Step 5:  Now, select your iPhone SE and then click the “Erase iPhone” option.
hit the Erase iPhone icon
After this, all data from your iPhone SE, including your passcode, will be deleted. You can also do it remotely if you lose your iPhone and want to erase all the information and data. Now, let’s move forward and see how to factory reset iPhone SE 3rd gen.
How to Factory Reset iPhone SE 3rd Gen
Resetting your iPhone SE 3rd gen is very simple. You can either do it to fix glitches or to set it up for a new user. As discussed earlier, a factory reset will erase everything from your device, so make sure to back up your essential data. In this section, we will follow the official method to factory reset iPhone SE. However, you must have access to your phone settings to do that.
Here is how you can factory reset your iPhone SE 3rd generation:
Step 1: First, unlock your iPhone SE and open the “Settings” app.
Step 2: Here, in the settings app, scroll down and click “General.”
Step 3: Now, scroll and find the “Transfer or Reset iPhone” option. Click it and proceed.
Step 4: Select “Erase All Content and Settings” from the options and enter your passcode to allow it.
Step 5: You will see a warning message saying this will delete all of your data. Click “Erase iPhone” to confirm.
So, these are the five methods that you can follow to factory reset iPhone SE with/without passcode. If you don’t want to get into daunting steps, go for AnyUnlock. It is the most reliable and effective way to do so.
FAQs about Factory Reset iPhone SE
Q1. What will happen after you factory reset iPhone SE?
After a factory reset of your iPhone SE, all your data, including apps, media, and settings, will be deleted. Your device will return to its original state as if you bought a new one. So, when your iPhone SE will restart, you will need to go through the initial setup process. A factory reset on the iPhone SE makes sure that no information or data is left behind.
Q2. How to get back data after factory reset iPhone SE?
Here is how you can restore your data after factory reset iPhone SE:
  1. Connect your iPhone SE to your computer via a USB cable.
  2. Open iTunes (Windows or Mac) or Finder (Mac).
  3. In iTunes or Finder, select your iPhone SE from the device list.
  4. Click the “Restore Backup” button.
  5. Choose the latest backup and click “Restore.”
  6. Wait while your data is restored to your iPhone SE.
Wrapping it up! In today’s busy world, it is very common for smartphone users to forget their passwords. But thankfully, there are certain ways to remove them, and factory reset is one of them. In this article, we have explored how to factory reset iPhone SE. We walked you through both methods, with and without a passcode.
However, if you want a reliable and effective way to get the job done, AnyUnlock is recommended. This tool is very easy to use and provides various other solutions for your iOS-related issues. So, download it now and regain access to your iPhone SE.
