If you find Face ID not available on your iPhone, just read this post to learn some proven ways to fix this issue easily and get access to your device again now.
Encountering the “Face ID not available” message on your iPhone can be a baffling and frustrating experience. This issue often arises in scenarios such as post-software updates, physical damage to the device, or even due to obstructed sensors.
In this article, you’ll discover the common reasons why Face ID is not available and learn about various solutions to resolve it. While the fixes vary, understanding their context is key to restoring your iPhone’s Face ID functionality efficiently.
When your iPhone displays the message “Face ID not available,” it’s an indication that something is preventing the Face ID function from operating correctly. This error can stem from a variety of factors, each impacting the system’s ability to recognize and process facial features effectively. Here are some of the most common reasons for the Face ID not working issue:
Understanding these reasons is the first step in troubleshooting the “Face ID not available” issue and restoring full functionality to your iPhone.
AnyUnlock – iPhone Password Unlocker is a versatile tool designed to tackle various iPhone unlock issues, including the troublesome “Face ID not available” error. It offers a straightforward solution for users facing locked screens due to Face ID problems. Whether the Face ID is not available or Face ID is not working, it will solve this problem with ease.
Features of AnyUnlock’s Screen Unlock Function:
In addition, AnyUnlcok can also help you bypass iCloud lock, bypass MDM, unlock Apple ID, unlock encrypted iTunes, and more.
Now, you can follow the steps below to fix Face ID not available with this tool.
Steps to Use AnyUnlock to Unlock iPhone Screen:
Step 1. First, download AnyUnlock from its official website and install it on your computer. Select the “Unlock Screen Passcode” option.
Choose Unlock Screen Passcode
Step 2. Use a USB cable to connect your iPhone to the computer and click “Start Now”.
Click Start Now Button
Step 3. AnyUnlock will prompt you to download the appropriate firmware package for your iPhone. Click “Download.”
Get Matching Firmware for iPhone
Step 4. Once the firmware is downloaded, click “Unlock Now” to begin the unlocking process. This will remove the screen lock, bypassing the Face ID issue.
Tap on Unlock Now
Step 5. After the process completes, you can set up your iPhone as new or restore it from a backup.
By following these steps, AnyUnlock can efficiently resolve the “Face ID not available” error, granting you access to your iPhone.
Restarting your iPhone is a straightforward and often effective method for resolving the “Face ID not available” error. This technique can refresh the system processes, which might be causing the Face ID malfunction.
Steps to Restart Your iPhone:
Step 1. Initiate the Power Off:
Step 2. Slide to Power Off: Drag the power off slider to turn off your iPhone. Wait for a few seconds to ensure the device is completely off.
Restart Your iPhone
Step 3. Restart the iPhone:
Step 4. Test Face ID: After your iPhone turns back on, try using Face ID to check if the issue has been resolved.
A simple restart can often clear temporary software glitches that may be causing issues with Face ID functionality.
In cases where the “Face ID not available” message appears, it’s important to ensure that the TrueDepth camera on your iPhone is not obstructed. This camera, vital for Face ID functionality, can be blocked by elements like screen protectors, cases, or even residue on the lens. Regularly checking and cleaning this area, located in the top notch of your iPhone, can help maintain the effectiveness of Face ID and prevent errors related to camera obstruction.
Resetting Face ID is a direct and effective method to address the issue when you find Face ID not working on your iPhone. This process clears all existing facial recognition data, allowing you to set up the feature from scratch, potentially resolving any errors or glitches.
Steps to Reset Face ID:
Click on Reset Face ID
Resetting Face ID can often solve problems related to facial recognition errors and is a recommended step when encountering issues with Face ID not working properly.
Sometimes, iOS system issues will also cause Face ID not available or Face ID not working issue. In this situation, you need a professional iOS repair tool to solve this problem. AnyFix – iOS System Recovery can help you out!
It can fix 150+ iOS system issues, like Face ID not available/working, stuck on Apple logo, frozen screen, won’t turn on, touch screen not working, etc. 3 repair modes are offered and you can even fix the system issues without data loss. Most importantly, no skills are needed! Anyone can use this tool to fix iOS in simple clicks without any hassle. All iPhone/iPad models and iOS systems are supported. So just follow the steps below to fix Face ID not available now:
Step 1. Free download AnyFix and choose System Repair mode.
AnyFix System Repair Option
Step 2. Connect your iPhone to the computer with a USB cable. Choose the issue type and click on Start Now.
AnyFix System Repair Device Bug
Step 3. Select a repair mode. We recommend you try Standard Repair first, because it will not erase data.
AnyFix Standard Repair
Step 4. Then you need to download the firmware. Just click Download.
Step 5. After that, it will start to fix the system. Wait for a while and you will see the screen below when it is completed.
Repair Is Completed
Updating the iOS on your iPhone is another effective solution to troubleshoot the “Face ID not available iPhone” issue. Software updates often include fixes for bugs and glitches that could be causing Face ID to malfunction.
Steps to Update iOS to Fix Face ID:
Update iOS on Your iPhone
Regularly updating your iPhone’s iOS can prevent many common issues, including the “Face ID not available” problem, ensuring your device runs smoothly and securely.
Resetting all settings on your iPhone is a broader approach that can resolve the “Face ID not available” issue, especially when specific settings conflicts are causing the problem.
Steps to Reset All Settings on iPhone:
Select Reset All Settings
Remember, this method resets all settings, so you’ll need to set up your preferences and connections again, but it can be particularly useful when more specific solutions fail to resolve the Face ID issue.
If all previous methods fail to resolve the “Face ID not available” issue, it’s advisable to seek assistance from Apple Support. This step is crucial, especially if the problem persists, as it could indicate a more serious hardware issue that requires professional attention. Apple’s support team can offer tailored troubleshooting steps and, if necessary, arrange for a repair or replacement. Contacting Apple Support ensures that you receive expert guidance specific to your device’s condition and can be the most reliable solution for more complex issues with Face ID.
In conclusion, while various methods exist to address the “Face ID not available” dilemma, solutions like AnyUnlock stand out for their ability to tackle a wide array of issues, making it a versatile tool for more complex scenarios. If you’re seeking an all-encompassing fix, we recommend giving AnyUnlock a try. Download AnyUnlock today to efficiently restore your iPhone’s Face ID functionality and enjoy uninterrupted access to your device.
