All You Need to Know about DoulCi Activator and Alternative
For individuals facing the predicament of iCloud-locked devices, the DoulCi iCloud Activator has been of great help. This article discusses how to use DoulCi iCloud Activator, pros and cons, and an alternative tool, AnyUnlock.
Author Avatar Joy Taylor Last Updated: Mar. 25, 2025
AnyUnlock – Best Alternative to DoulCi Activator
Free download AnyUnlock – iPhone Password Unlocker to bypass iCloud Activation Lock without Apple ID or password.
Apple’s activation lock protects user data and prevents unauthorized access. Often, users may be locked out of their devices due to forgotten passwords or second-hand phones. However, grounds of hope have emerged with apps and tools designed to bypass the iCloud activation lock. This article will explore DoulCi Activator which has sent shockwaves through the tech community. Let’s delve into the details of Doulci Activator, exploring a guide to use it and a functional alternative. So, without further ado, let’s dig in!
What Is DoulCi Activator?
DoulCi Activator has gained prominence for its ability to bypass iCloud-locked devices. By exploiting the amenabilities of Apple’s security feature, it helps users regain access to their data.
Developed by a team of anonymous skilled experts, it is the first free tool that can unlock any Apple device without iTunes.It effectively bypasses the lock without the need for Apple ID credentials. The application unlocks the lock activator and connects it with an alternate server to decode the password. DoulCi allows users to set up new Apple IDs or restore with existing backups. Doulci had made waves in the market until Apple realized the vulnerabilities in its security protocol.
How to Bypass iCloud Activation Lock with Doulci iCloud Unlocking Tool
DoulCi Activator only works on iOS 7.1.2 and lower versions. If you have the correct file link to download DoulCi iCloud, here is a quick guide on how it works.
Step 1. Unzip the Files and Launch DoulCi Activator
Click on the link to download the DoulCi iCloud activation unlock tool. The file is compatible with Windows and Linux only. Install the script on a local server. Launch the DoulCi Activator on your computer. Select the model of your iOS device, e.g. iPhone 5s.
Step 2. Select the iOS version
Next, select the iOS version of your device, e.g. iOS 12.0. DoulCi Activator works well with iOS 7.1.2 and lower. Any device running a newer version will not be compatible.
Step 3. Connect and Run DoulCi Activator
Connect your iCloud-locked device to the PC using a USB cable. Run DoulCi Activator on your PC. The device will be connected to a server. Wait for a few minutes before the device is unlocked.
Set up DoulCi Activator
Step 4. Disconnect the Device
Once the program runs successfully, a message says: ‘You have successfully bypassed the iCloud Activation. Turn on the iPhone.’ will be displayed on the screen. You can now disconnect the device and set up a new Apple ID or restore an existing backup.
Best DoulCi Activator Alternative to Bypass iCloud Activation Lock
If you are considering removing the iOS activation lock and exploring a functioning alternative iPhone unlocker, AnyUnlock is a good choice. As an alternative to DoulCi Activator, many options are available in the market. It is versatile and one of the finest equipped to bypass iCloud activation.
AnyUnlock’s ‘Bypass iCloud Activation Lock” feature works well with iOS 12 to iOS 16.5 devices. With simple steps, AnyUnlock can easily remove iCloud activation lock even without Apple ID and password, which restores the phone almost instantly. Here are a few key features of this solid application.
  • Access to the iPhone/iPad/ iPod touch without Apple ID and password immediately.
  • After Bypassing, you can sign in with different Apple ID credentials to download apps.
  •  No technical difficulty. No tedious and long waits.
  • iOS devices cannot be tracked via the old Apple credentials.
  • No risk of data being erased remotely by the previous owner.
  • Also allows you to unlock forgotten passcode, bypass MDM, unlock Apple ID, etc.
Free download AnyUnlock on a Mac or Windows PC and follow the steps below to learn how to bypass the activation lock.
Step 1. Install and launch AnyUnlock on your computer, then select the Bypass iCloud Activation Lock mode.
Step 2. Connect your iPhone/iPad/iPod to the PC via a USB cable. Click the Start Now button.
Click on the Start Now to Go On
Step 3. Follow the instructions to jailbreak your device. When the jailbreak process is complete, click Next to proceed.
Jailbreak Your Device
Step 4. Confirm your device information and disconnect your device from Wi-Fi, then click Bypass Now button.
Confirm Your Device Information and Start Bypassing
Step 5. When the bypassing is complete, the iCloud activation lock is removed successfully, you’ll see the page below. Note: Do not reset the device, flash, or firmware, or the device will be locked again.
iCloud Activation Lock Is Bypassed Successfully
Resetting the iCloud Activation Lock with AnyUnlock is simple and easy. It is reliable and offers a great alternative to Doulci. Before concluding the article, here are some answers to frequently asked questions.
Is It Possible to Remove iCloud Activation Lock without Previous Owner?
In simple words- Yes! If you can’t ask the previous owner to give you the passcode, there are still many ways to bypass the iCloud activation lock without the previous owner. Such as DNS, Doulci iCloud, AnyUnlock, etc.
What’s the Best iCloud Activation Lock Removal Tool?
We understand the need for self-controlled programs that are easy to maneuver. This is why we recommend using a user-friendly yet functional tool like AnyUnlock. In the realm of iOS-locked devices, AnyUnlock is a versatile and legitimate tool for bypassing the iCloud activation lock. It stands out for its easy interface, comprehensive suite of features, and compliance with Apple’s laws and terms.
Final Words
DoulCi activator has gained fame as an effective solution to bypass the iCloud activation lock. However, as an alternative, AnyUnlock emerges as a safer and more legitimate option. It offers an efficient means to regain access to your iOS device while adhering to Apple’s laws and regulations. By choosing alternatives like AnyUnlock, users can ensure the integrity of devices and data protection. Learn more about AnyUnlock now!
