Get a comprehensive review about the Checkm8 iCloud Bypass software program, plus a perfect alternative to it here in this post.
With the integration of iCloud Activation Lock on iOS devices, an unauthorized user cannot access your device without your permission. While this security feature is regarded as a great solution for data theft and other related issues, it isn’t without its drawbacks.
In a situation where you purchased a second hand device with iCloud activation lock, you cannot use it except if you have the credentials to the iCloud account. However, if you don’t, you may have to use an iCloud Activation Lock bypass software like the famous Checkm8.
Although Checkm8 has successfully bypassed iCloud activation lock on several iDevices, is it still worth investing in? Well, you can find out by reading through our comprehensive overview. Read on!
CheckM8 is one of the game changers in the iOS toolkit industry. The software is capable of removing/bypassing iCloud activation lock on iOS devices without compromising users’ data. It’s also effective for bypassing activation lock on iPadOS. Mind you, this simple yet powerful software connects with iDevice running on iOS 12 down to iOS 17.
CheckM8 is so powerful, so does it have limitations when using it? Well, yes, there are certain limitations to using this software program. Learning about them will be helpful, so you won’t regret using them. Here are some issues you may encounter while using the CheckM8 software.
You can bypass iCloud Activation Lock on your iDevice using the CheckM8 software without stress by following the instructions given down here:
Step 1: Install the CheckM8 software on your computer system, macOS precisely. Once the installation is completed, you have to proceed to jailbreaking the corresponding iDevice. However, since CheckM8 doesn’t support such a feature, you may have to use another program, which is the Checkra1n software.
Step 2: Launch the Checkra1n software and connect your iDevice to the computer. Checkra1n will immediately analyze your device to see if it’s compatible, and can be jailbroken. If the device is compatible, Checkra1n will grant you permission to press the Start button for jailbreaking to commence.
Launch and Use Checkra1n
Step 3: Next, you will be directed to a new screen where you have the instructions on how to put your device in DFU mode. Follow the instructions accordingly, to enter DFU. Once DFU is activated, the Start icon at the bottom corner of your screen will activate. Click on it to proceed.
Wait until jailbreaking is completed, then you continue with the CheckM8 software to bypass iCloud Activation Lock.
Step 4: Launch the previously installed CheckM8 software, and ensure the iCloud Activation Lock device is connected to your computer. Once the software recognize your phone, the screen down here will appear. Click on Start Bypass, and CheckM8 will commence iCloud Activation Lock bypass.
iCloud Activation Lock Bypass Starts
Step 5. Once the iCloud Activation Lock bypass is completed, you get a notification.
iCloud Lock Is Bypassed
Sure, CheckM8 works with iOS 15/16. It fixes iCloud Activation Lock on iOS 12 down to iOS 17.1.2.
No, the CheckM8 software does not work with iPhone 11. Although it connects with iDevices running on iOS 12 up to iOS 16, it ‘s selective of the device type. You can use CheckM8 with iPhone 5 series, 6 series, 7 series, 8 series, and X. Every other iOS device type is out.
Yes, CheckM8 is absolutely free to use. No premium subscription is required for you to employ the services of this software to fix iCloud Activation Lock on your iDevice, whether iPad or iPhone.
CheckM8 isn’t without its limitations, which we have looked at in the paragraph above. However, this overview won’t be complete without mentioning the best alternative for CheckM8 software. Of all the tools we come across, AnyUnlock is the most outstanding amongst them.
AnyUnlock is one of the most versatile tools suitable for fixing iCloud Activation Lock on more iOS devices, unlike the CheckM8 software that works with selected iOS. This software works without restricting your access to a new/old iCloud account.
Moreover, with AnyUnlock, you can :
Step 1. Free get AnyUnlock – iPhone Password Unlocker installed. Launch the software and you will see the page below.
Click on Start Now to Bypass iCloud Activation Lock
Step 2. Connect your device and click Start Now button.
Connect Your iOS Device to the Computer
Step 3. Then, you need to jailbreak your device to allow AnyUnlock to bypass for you. Read the jailbreak tutorial to do and click Next once finished.
Jailbreak Your Device
Step 4. Then you can start bypassing after clicking Start Now button.
Bypassing iCloud Activation Lock
Step 5. Wait until the process finished, you will get iCloud Activation Lock is bypassed successfully page as below.
iCloud Activation Lock Is Bypassed Successfully
An iCloud locked iPhone or iPad can be frustrating to use, but when you have the CheckM8 software you can fix it. However, you need to consider the dark sides attached before investing in such a tool. Our best recommendation is the AnyUnlock software. It bypasses iCloud activation lock without limits while ensuring all of the features on your device remain functional. This software is worth using to fix iCloud activation lock. We advise that you invest in it to bypass any iOS lock issues on your iDevice.
