Full Guide on How to Change Screen Timeout on iPhone
Discover how to change screen timeout on iPhone for enhanced battery life, convenience, and security. In this guide, we have also explored what screen timeout is, why it’s helpful, and why you might be unable to change it. Moreover, if you get locked out of your iPhone, we got you covered there as well with AnyUnlock.
Author Avatar Joy Taylor Last Updated: Aug. 28, 2024
AnyUnlock – Professional iPhone Unlocker
AnyUnlock – iPhone password unlocker helps unlock iPhone when forgot passcode. Download it now to unlock your iPhone without restore.
As you hold your iPhone, have you ever noticed how quickly its screen dims and locks when not in use? It’s as if the device has a mind of its own, dictating when it’s time to take a break.
But what if I told you that you could seize control of this automated process?
With the screen timeout feature, you can adjust the settings of how quickly or slowly the screen turns off. Adjusting it can enhance the efficiency, battery life, and overall interaction with your device.
In this article, we will tell you the ins and outs of screen timeout on iPhones. Our guide will also show you how to change the screen timeout on your iPhone.  So, let’s start!
What Is Screen Timeout on iPhone?
Apple has a Screen Timeout feature on iPhone. It refers to how long the screen stays lit and active when you’re not actively using it.
Screen timeout is like a power-saving feature. When you’re not tapping or swiping, the screen takes a rest. This helps save battery life and prevents accidental taps.
You can think of it as your iPhone’s way of conserving energy when you’re not using it.
So, why would you need to change the settings? Here is why.
Why Should I Change the Screen Lock Time on iPhone?
You might wonder, why bother changing how long the screen stays awake? Well, there are good reasons!
Let’s see what they are.
Enhanced Ease of Use
If your iPhone is set to have a shorter screen lock time, you will have to unlock your iPhone constantly. This can be a hassle for you.
By extending the screen lock time, you can enjoy uninterrupted usage without frequent unlocks.
Battery Efficiency
Your iPhone’s screen consumes battery power. The longer it remains active, the more energy it uses.
Opting for a shorter screen lock time conserves battery life, ultimately extending the time between charges.
Increased Security
The security of your iPhone is essential. A prolonged screen lock time increases the window during which unauthorized individuals could potentially access your data.
Reducing the screen lock time reinforces iPhone security. It minimizes the time to access data without entering your passcode.
Thus, changing the screen timeout setting according to your need is really important.
So, stick around to learn how to change the screen timeout on your iPhone.
How to Change Screen Timeout on iPhone?
Changing the screen timeout settings on your iPhone is pretty easy. We will walk you through the steps to customize this setting according to your preferences.
Follow the simple steps given below.
Step 1: Unlock your iPhone using your passcode.
Step 2: Go to the “Settings” app.
Step 3: Scroll down and tap on “Display & Brightness.” This is where you’ll find various display-related settings.
Tap on "Display & Brightness."
Tap on “Display & Brightness”
Step 4: Here, tap on the “Auto-Lock” option. You can access different time intervals for screen timeout.
The “Auto-Lock” Option
Step 5: Select the desired screen lock time from the available options. It ranges from 30 seconds to 5 minutes. You can also choose “Never” if you prefer your screen to stay on indefinitely.
Note: If you do not see a “Never” option, your iPhone might be managed by your organization, school, or other administrator. Contact that administrator for guidance.
Step 6: After selecting your preferred timeout, your iPhone will automatically apply the changes. You’ve successfully customized your screen timeout settings.
This is a pretty simple method. However, read the next section if you do not have your passcode to unlock your screen.
Why Can’t I Change Screen Timeout on iPhone?
Even though changing the screen timeout on your iPhone is a simple process, you might face some hurdles in some instances.
Here are three common reasons why you might find yourself unable to change the screen timeout setting.
Device Management
If your iPhone is managed by an organization, school, or administrator, they might have set restrictions on certain settings. This may include the screen timeout settings.
In such cases, you must consult the administrator for further guidance.
Software Updates Required
Outdated software can sometimes lead to unexpected glitches.
If you’re unable to modify screen timeout, check if your iPhone’s software is up to date. Updating to the latest iOS version might resolve the issue.
Third-Party Apps
Some third-party apps can interfere with system settings, such as screen timeout.
You can uninstall recently installed apps or troubleshoot known problematic apps. This might help restore your ability to adjust screen timeout.
Accessibility Settings
Certain accessibility features might affect screen timeout settings.
Check if any accessibility settings are enabled and causing conflicts. Adjusting these settings could potentially resolve the issue.
Hardware or Software Issues
Occasionally, hardware or software malfunctions can impact various device settings.
You can restart your iPhone or perform a soft reset to resolve the problem. As a last resort, try restoring your device to factory settings.
Note: Remember that each iPhone configuration can differ, and the cause of the issue might vary.
If you cannot change screen timeout despite trying these solutions, reach out to Apple Support.
Forgot Screen Lock Passcode & Locked Out of Your Phone [1-Click to Unlock]
There may be instances when you forget your lock screen passcode or lock yourself out of your iPhone. Well, no need to panic! We have got you covered. In such an instance, you can use AnyUnlock – a great tool for unlocking your iPhone!
What Is AnyUnlock?
 AnyUnlock – iPhone password unlocker is specialized in iOS password removal, including MDM bypassing, Apple ID removal, iCloud activation lock bypassing, etc.  And it supports all iOS systems and iPhone models. You can use it to unlock iPhone 6, 7…even use it to unlock your new iPhone 14, IOS16. Check its main features and try it. While using this tool, all you need to do is to connect the found iPhone, select the option, and then AnyUnlock will take care of everything.
Key Features
  • Support to unlock any iPhone screen locks, like 4-digit or 6-digit numeric code, custom numeric code, custom alphanumeric code, Touch ID, or Face ID.
  • It only takes a few minutes to unlock your iPhone screen locks. Much faster than you think and save your precious time.
  • Customer-friendly to fresh users as no tech knowledge is required.
  • No need to connect with iTunes or log into iCloud.
  • Additional features include SIM Lock removal, iOS password management, iTunes Encryption removal, Apple ID unlock, MDM unlock, and more.
Free get AnyUnlock>> and explore the other features of AnyUnlock more!
How to Unlock Screen Lock with AnyUnlock?
Step 1. Free get and run AnyUnlock on your Windows or Mac > Select the Unlock Screen Passcode mode.
Choose Unlock Screen Passcode
Step 2. Click on the “Start Now” button. Hit the Download button to download the matched firmware package for the found iPhone model.
Get a Matching Firmware
Step 3. Once the firmware is downloaded, click “Unlock Now”. AnyUnlock will initiate the unlocking process.
Tap on Unlock Now
Tap on Unlock Now
Step 4. A few minutes later, the passcode will be successfully removed from the iOS device. You can use your iPhone freely.
How to Turn off Screen Time without Passcode without Data Loss
You may set up a screen time lock for a long time so that you fail to recall screen time password to turn off it. Or you bought a second-hand iPhone, whose previous owner did not turn off the screen time lock, but you don’t know the account and password. Then, how to disable screen time in these situations? AnyUnlock can be here to save your day again!
As a complete iPhone password unlock software, AnyUnlock’s Unlock Screen Time Passcode function can help you solve how to get rid of screen time without passcode completely and quickly.
AnyUnlock – Turn off Screen Time
  • Only 3 steps are needed to turn off screen time without passcode.
  • No data will be erased when disabling screen time.
  • Unlock both the screen time passcode and restrictions passcode.
  • Unlock screen passcode/Apple ID/MDM/iCloud Activation Lock
Step 1. Free get and run AnyUnlock on your computer, and connect your iPhone or iPad to the computer > Choose the Unlock Screen Time Passcode mode.
Choose Unlock Screen Time Passcode Mode
Step 2. Click on Unlock Now > Then, AnyUnlock will ask you to back up your iPhone and encrypt the backup.
Unlock Screen Time Passcode Process
Step 3. After the analysis, AnyUnlock would remove your Screen Time Passcode successfully.
Successfully Removed Screen Time Passcode
Final Words
Although the screen timeout feature seems like an insignificant thing, it makes all the difference. It not only saves battery life but also ensures your iPhone’s security.
With our guide on how to change screen timeout on iPhone, you are now perfectly equipped to shape your device to work how you want it to precisely.
Moreover, we have also shown you what to do if you get locked out of your iPhone. With AnyUnlock, you can unlock any iOS device and regain access. Free get AnyUnlcok and give it a try>>
