Do you find yourself contemplating whether the CellUnlocker Net website is a legitimate platform to unlock your iPhone? If so, we’ve got an answer for you here in this post, as we review the CellUnlocker Net website. Also, we introduce a perfect replacement for CellUnlocker Net.
Hi there, I’m currently stuck on the iCloud Activation Lock screen on my iPhone. All efforts to bypass this screen are futile, as I cannot remember the corresponding password to my Apple ID. So I researched the internet and came across CellUnlocker.Net. I’m kind of skeptical about it. If you’ve used it before, kindly enlighten me about it.
It’s without a doubt that CellUnlocker.Net is one of the many iOS unlock tools that claim to bypass iCloud Activation Lock on iPhone excellently. How true is that? This is one question this post is structured to answer.
Here, we share a complete overview of the CellUnlocker Net website, including the mode of operation, subscription plans, pros, and cons. Also, we look at the best replacement for CellUnlocker Net. If you are ready, then let’s delve in!
CellUnlocker Net is a cloud-based platform where unlock codes and services are purchased for mobile phones. The corresponding codes are used for network and iCloud unlock. What this means in essence is that you can use the code obtained to remove SIM lock (when your device is tied to a specific carrier) and iCloud Activation Lock.
Unlock codes obtained from CellUnlocker Net work for all Android and iOS devices. This website comes in handy for folks who don’t have a computer system or want to install any third-party software.
CellUnlocker Review
Pros
Cons
The question about the legitimacy of CellUnlocker Net is quite technical as there are several factors to consider. For instance, when you consider region, CellUnlocker Net isn’t legitimate in all regions. It only works for people in Canada and the USA only.
If we move further into the quality of services, the results are poor. Unfortunately, CellUnlocker Net does not remove iCloud Activation Lock 100% as it claims. The majority of the users complain about it. Furthermore, CellUnlocker Net isn’t safe to use, as your device might crash or the data on it is compromised.
CellUnlocker Net helps you remove SIM lock or bypass iCloud Activation Lock on your mobile device by simply providing you with an unlock code which must be entered on the device to fix it. However, mind you, to get this unlock code, you have to provide some information about the device.
Some of the info required is listed down here, so check them out:
If you have all of the info above, just go on the CellUnlocker Net website and enter them accordingly in the fields provided. Once done, wait for the platform to scan its database for an unlock code to fix your device.
When CellUnlocker Net finds an unlock code, an email with the code will be sent to you immediately. In addition, an instructional guide on how to use the code will be provided. Follow the guide to unlock your phone in no time.
Before CellUnlocker Net can send you an unlock code, you must have subscribed or paid a premium.
To use CellUnlocker Net, you have to pay a premium just as mentioned above, and the pricing differs for different regions and network providers. Also, your phone model plays a crucial role in CellUnlocker pricing.
A simple way to know how much you are paying to use CellUnlocker, kindly select your mobile carrier (also known as the network provider), and phone model. After that, CellUnlocker will provide the subscription price to pay plus additional fees to finish unlocking your device.
Quick Note: The corresponding premium price for using CellUnlocker Net is quite expensive, as your region, phone model, and mobile carrier have a significant effect on pricing.
After thorough research on CellUnlocker Net, it’s obvious the online service isn’t the best tool to fix lock issues on any device including iPhone. Besides the complications involved in using an online service, CellUnlocker Net is quite expensive with poor results. If you need a complete iOS unlocking tool to remove restrictions (like carrier lock) or iCloud Activation Lock, then AnyUnlock is the perfect tool to use.
AnyUnlock is a simple iOS unlock tool suitable for fixing several types of lock issues without compromising your OS or the data stored in your device. It’s popular for removing SIM lock, bypassing MDM & iCloud Activation Lock, and more. You can also use it to unlock your Screen Time Passcode, Screen Passcode, and Apple ID with minimal effort.
This tool is suggested to be the best replacement for CellUnlock Net, as it fixes all dark sides linked to the online service. AnyUnlock has amazing customer service with over 20 support members who are well-trained, and experienced to provide the right solution to your queries.
Step 1. Free download AnyUnlock on your Windows PC or Mac. Click on Remove SIM Lock on the home page.
Choose Remove SIM Lock
Step 2. Connect your iPhone to the computer and make sure your iPhone is jailbroken before clicking Remove Now to continue.
Click Remove Now
If your iDevice isn’t jailbroken, follow the on-screen instructions to jailbreak your iPhone on your own.
Step 3. Follow the on-screen instructions to Forget This Network on your iPhone.
Forgot This Network on iPhone
Step 4. AnyUnlock will start removing SIM lock as below.
Start Removing
Step 5. Once the SIM lock is unlocked, you will get the success page.
SIM Lock Removed Successfully
From our review of the CellUnlocker Net, you can say that the online service isn’t the ideal tool to fix iOS lock issues. There are too many downsides linked to it. Imagine a tool that offers an expensive pricing plan with no guarantee of giving the best result.
If you need a better alternative to remove the SIM lock or activation lock, you should invest in AnyUnlock software. It’s the most trusted iOS unlock tool well known for offering excellent services. The subscription pricing is cheaper, and the operations are faster compared to many other iOS unlock tools online.
