Struggling to bypass the iCloud activation lock on your Mac computer system? Learn how to fix this issue here in this post, as we explore the various ways to get rid of the iCloud activation lock currently displayed on your screen.
Hello, A few days back, I purchased a used Mac from one of the stores on my way back home. The previous owner/seller did well with the computer because it’s neat. However, unfortunately, it has the iCloud activation lock on it. I’ve tried reaching out to the seller concerning this issue, but no positive results. Please, who has encountered this issue in the past and fixed it? Kindly help with the solution.
Does the aforementioned scenario sound familiar?
Whether you bought an iCloud activation lock device, just like the situation above, or forgot the corresponding details to your Apple ID, Apple automatically restricts your access to the corresponding device for privacy protection purposes. To fix this, you must bypass the iCloud activation lock, and there are several ways to do that.
In this post, we will walk you through the 5 powerful techniques recommended by experts that you can follow to bypass the iCloud activation lock on your Mac. However, before then, let’s have a brief description of the iCloud activation lock on Mac.
Activation lock is a safeguard feature established and integrated into most Apple Inc., devices, both mobile and computer systems, for privacy protection purposes. The feature is programmed such that it restricts unauthorized persons access to your Apple device in case it goes missing.
This feature plays a great role in the security of an Apple device, and the mode of operation is pretty simple but complex for intruders or hackers to break. Activation lock works using the Find My Device feature and the Apple ID linked to your device. Wondering how the Find My and your Apple ID connect?
Well, when you enable Find My Device, your Mac or any Apple device automatically requests the Apple ID details linked each time you want to access the device.
Now you know what activation lock means and how it works. Let’s go into how to remove or bypass iCloud activation lock on your Mac computer easily and quickly. Find below the techniques to use:
Do you use a company Mac device? If so, this solution should come in handy if you want to remove iCloud activation lock. With activation lock bypass code, you can easily regain control of your Mac computer system without compromising it. This approach simply requires that you enter the corresponding bypass code, which is usually available with the administrator.
If you are able to get this code, follow the procedure down here to bypass activation lock on your Mac computer:
Limitations
With DNS. you can also remove iCloud activation lock on your Mac computer system. This method uses an online server or HTML network to fix activation lock on your device, so you reclaim full control of it with no restrictions. You don’t have to subscribe or pay anything to use this method, and it’s usually done directly from the device.
Find below the appropriate steps to follow for you to successfully remove the iCloud activation lock on your Mac using the DNS bypass method:
USA/North America: 104.154.51.7
Europe: 104.155.28.90
Asia: 104.155.220.58
Others: 78.109.17.60
Are you still in contact with the previous owner of your Mac computer? If so, count yourself lucky. You should connect with the previous owner of your Mac immediately, so he/she can provide you with the corresponding details of the Apple ID associated with the device. If the details remain confidential, you can travel down to wherever the person is located, so he/she can enter the details to your Mac, and remove the activation lock on it.
Limitations
CheckM8 is one of the many iCloud bypass tools that’s capable of removing activation lock from Mac. The software helps you remove the iCloud activation on your device without password by exploiting Apple security system. While this may help you regain control of your Mac computer, it’s crucial you know it only works for selected Mac computers, as it only works with T2 chip devices.
CheckM8 iCloud Activation Removal Tool
Find below some of the supported devices:
Limitations
Another simple method to get rid or bypass activation lock on your Mac computer system is via iCloud Find My. The iCloud Find My is a security system designed to help you track your device in case it goes missing. It can also be used to fix iCloud activation issues by simply wiping all content and settings on your device.
Using the iCloud Find My feature to remove activation lock is pretty straightforward, but you must have the details to the Apple ID linked to your Mac. Once you have this ready, follow the instructional guide below:
Click Erase Mac Option
Limitations
Still experiencing iCloud activation lock issues on your device? Then you should consider using a professional iOS unlock software like AnyUnlock which doesn’t require you to be in contact with the previous owner of your device or even recollect the corresponding Apple ID details linked to it.
AnyUnlock is one of the most reliable iOS unlock solutions available to fix iCloud activation lock issues on your iPhone or iPad. The software offers a quick and safe way to bypass activation lock, as it fixes your iPhone/iPad without compromising it.
Besides bypassing iCloud activation lock, you can also use the AnyUnlock software to remove SIM lock restrictions, especially when your device is locked to a specific carrier. This software also supports other features like Screen Unlock, Apple ID removal, MDM bypass, password manager, and many other interesting features.
Step 1. Download and launch AnyUnlock your computer > Click the Bypass iCloud Activation Lock on the main screen.
Click on Start Now to Bypass iCloud Activation Lock
Step 2. Connect your iPhone to the computer with a USB cable > Check the device information and read the Terms of Use. Click the Start Now button to initiate the process.
Connect Your iOS Device to the Computer
Step 3. Now, please follow the Jailbreak Tutorial to jailbreak your device since there is no direct jailbreak tool for the Windows system in the market currently. If your device is jailbroken successfully, please go back to the software and click on the Next button to continue.
Jailbreak Your Device
Step 4. Then, please confirm your device information and disconnect your device from Wi-Fi and turn off cellular data > Tap on the Bypass Now.
Confirm Your Device Information and Start Bypassing
Step 5. Now, AnyUnlock is bypassing iCloud Activation Lock, and please wait for a moment.
Bypassing iCloud Activation Lock
Step 6. When the iCloud Activation Lock is bypassed successfully, you can see the page below.
iCloud Activation Lock Is Bypassed Successfully
iCloud activation lock is a rigid security system established by Apple to help protect end—users of its product, whether mobile phones or computers, against data theft. In spite of this great benefit, you can still run into problems with this feature, especially when you lose the credentials to your iCloud account.
When this happens, you are restricted from using the device, and source for how to bypass the iCloud activation lock. We’ve provided various ways to bypass Mac iCloud activation lock in the article above.
