Struggling with an Activation Lock on your device? Our guide outlines five easy methods to bypass iPod Touch Activation Lock. Whether you have access to the previous owner’s information, we have a solution for you.
iPod activation lock is a security feature to protect the device’s data. But it can be frustrating when it prevents you from using your own iPod. When does this happen? You may have forgotten the passcode for your iPod Touch. It also happens when someone purchases a second-hand device linked to the previous owner’s account.
In this article, we will guide you through five methods to get past this issue. We’ll also provide step-by-step instructions for these methods. But first, is it possible to bypass the activation lock on the iPod touch? Let’s answer this simple question.
Bonus Tip: You may also like the tips about activation lock removal below.
The answer is yes, you can. Now, how to do it varies depending on your situation. If you know the original owner of your device, a quick request to them can resolve the issue.
On the other hand, if you don’t have access to the previous owner’s information, software like AnyUnlock can help you regain control of the device. Other than that, there are technical loopholes, like altering DNS settings. You can also choose options like Apple Support or using iCloud features remotely.
We’ll now explain each of these methods and break them down step-by-step. Let’s start with a method that doesn’t require the previous owner.
We can bypass the iPod touch activation lock without the previous owner using some professional unlocking tools. Many tools can do this job. Out of those, we highly recommend you use AnyUnlock – iPhone Password Unlocker. AnyUnlock is a powerful password unlocker that can unlock almost all locks on iPhone, iPad, and iPod touch, like iCloud activation lock, SIM lock, screen lock, iTunes backup lock, MDM lock, etc. You can use this tool to bypass iCloud activation lock without password or Apple ID, even if you cannot contact the previous owner. You can learn more about what AnyUnlock can do for you in bypassing iCloud activation lock below.
Now free download AnyUnlock on your computer. Here is a stepwise guide to bypass iPod touch activation lock with AnyUnlock.
Step 1. Open AnyUnlock on your computer and select the Bypass iCloud Activation Lock option.
Step 2. Use a USB cable to connect your iPod Touch to the computer. Click Start Now after the device is recognized.
Step 3. Follow the software’s instructions to jailbreak your iPod Touch.
Step 4. Click Bypass Now and it will start to bypass iCloud activation lock automatically. Keep your device connected throughout the process.
Step 5. Wait for a while. And when it is completed, you can see the screen below.
If you’ve bought a second-hand device tied to an iCloud account, reaching out to the previous owner is the easiest action. They can give you the Apple ID and password linked to the device.
With this information, you can easily sign in to activate your iPod Touch again. Then go to the Settings menu and sign out of the previous iCloud account. This simple approach saves time and avoids technical complexities.
If you are still looking for another solution, let’s tell you about the DNS loophole.
DNS stands for Domain Name System. It’s essentially your internet’s phonebook. DNS translates domain names into IP addresses and lets browsers load internet resources.
But why are we talking about it here? Can we use it to bypass iPod Touch activation lock? Yes! In the context of an iPod Touch, DNS can be manipulated to help you bypass the iCloud Activation Lock. The method works particularly well on 5th and 6th-generation iPod Touch devices. It’s also a free approach to tackle this issue.
Here are the steps to bypass the iPod Touch activation lock using the DNS method.
Step 1. Start or restart your iPod Touch device. Now, during the setup process, select the option that says “Choose Wi-Fi network.”
Step 2. Tap on the information (“i”) icon located next to your connected Wi-Fi network.
Step 3. Choose the “Configure DNS” option and tap “Manual.”
Step 4. Add the correct server address based on your geographical location. Tap “+Add Server” and input the address. Server addresses based on location are as follows:
Step 5. After entering the server details, tap “Save.” Then go back and choose “Ask to Join Networks.”
Step 6. Provide the password for your Wi-Fi network and tap “Join.”
Step 7. Finally, tap the back button when the device tries to activate to complete the setup process.
Although it’s not a foolproof method, this DNS method does work most of the time. But if it doesn’t work, you can ask the previous owner to remove the iCloud account remotely.
Sometimes, previous owners of iPod Touch are reluctant to provide their Apple ID credentials. In these cases, there’s also a method to remove the Activation Lock from your iPod Touch without physical access. You can do so remotely via the official iCloud website.
This previous owner of your iPod Touch can erase the device from their iCloud account and make it usable again. Follow this stepwise guide to bypass the iCloud activation lock via the iCloud website.
Step 1. Open a web browser on a computer and go to the official iCloud website.
Step 2. Log in using the Apple ID and password associated with the iCloud-locked iPod Touch.
Step 3. Once logged in, click on “Find My iPhone.” Then click “All Devices” and locate the iPod Touch you wish to unlock.
Step 4. Select the “Erase iPod” option on the device’s information page. This option initiates the erasing process that will wipe all the data and settings from the device.
Step 5. After the erasing is complete, click on “Remove from Account.” This action will remove the Apple ID from the iPod Touch. The activation lock is also removed along with it.
Turning to Apple Support is the right choice if you’ve tried other options and still can’t remove the Activation Lock. This method can offer a secure way to remove the Activation Lock. However, it usually involves certain fees unless you still have the warranty on your device. Follow these steps to bypass the activation lock via Apple support.
Step 1. Gather all required documents first. You may need your purchase proof, the device’s serial number, and your AppleCare agreement number.
Step 2. Contact Apple Support through their website, helpline, and online chat. You can also schedule an appointment at the nearest Apple Store.
Step 3. Explain the issue in detail to the Apple representative. Remember that you are dealing with an Activation Lock issue on your iPod Touch.
Step 4. Provide the Apple representative with the necessary information and documents.
Step 5. If requested, visit your local Apple Store with the gathered documents. It’s advisable to take the iPod Touch with you.
Step 6. Pay the applicable fees for the removal of the Activation Lock. If your device is still under warranty and you have the purchase proof, you can remove the lock for free.
Step 7. Wait for confirmation from Apple that the Activation Lock has been removed. Once done, you can set up your iPod Touch as a new device.
Before we end our article, let’s give some tips to avoid being locked by activation lock iPod Touch again.
While the Activation Lock is an essential security feature, it can sometimes pose challenges. This issue especially happens when you purchase a secondhand phone. So here are some pointers to avoid being unnecessarily locked by it.
iPod Touch Activation Lock can be both a safeguard and a hindrance. At times, bypassing it becomes essential for regaining full use of your device. In this guide, we have provided 5 different methods to bypass iPod Touch activation lock. Among all the available options, we recommend AnyUnlock for its powerful features. It not only helps bypass the Activation Lock but can also solve various iOS password-related issues. It’s a versatile tool that can be a valuable addition to your digital toolkit. Why not free download AnyUnlock to try it?
