4 Easy Ways to Bypass iPhone 6/6 Plus iCloud Activation Lock
Bypassing iCloud activation lock on your iPhone 6/6 plus can be tedious but not anymore now that you are on this platform. In this post, we will explore the simplest ways to bypass iCloud activation on iPhone 6 and 6 plus without compromising your device.
Author Avatar Joy Taylor Last Updated: Aug. 27, 2024
AnyUnlock – Bypass iPhone 6/6 Plus iCloud Activation Lock 1-Click
How to bypass iPhone 6/6 Plus iCloud Activation Lock? Just free download AnyUnlock to bypass iCloud activation lock on iPhone/iPad/iPod touch without Apple ID or password. No skills are needed. Available for Windows & Mac.
Hi there,
I got a used iPhone 6 Plus a few days back. Everything on this device is in good condition, only that the previous owner forgot to clear the data on it. I decided to do that now by resetting the device. But unfortunately, I can’t. I kept getting the prompt to enter the iCloud credentials on the iPhone 6 Plus. I’ve tried reaching out to the seller but all efforts are to no avail. Please who knows how to bypass iCloud activation lock on iPhone 6 Plus?
While the iCloud Activation Lock security feature is aimed at protecting users’ privacy on an iOS device, it also poses a challenge to the legitimate owner, just like the scenario above. If you are struggling with iCloud activation lock on your iPhone 6 or 6 Plus and looking for how to fix it, this post has got you covered.
Here, we’ve compiled a guide with multiple techniques that you can select and apply to successfully bypass the activation lock on your iPhone 6/6 Plus.
What Is iCloud Activation Lock on iPhone 6/6 Plus?
Established by Apple Inc., iCloud activation lock is a rigid security technology tucked into Apple devices to help safeguard end-users data from prying eyes. With this technology, nobody can access your Apple device without your consent.
iCloud activation lock uses your Apple ID and the corresponding password to disconnect/disqualify anyone from accessing your device. This technology works by requesting the current holder of an Apple device the corresponding Apple credentials linked to it each time a security operation needs to be carried out. Some of these operations include; disabling Find My Phone, reactivation an iDevice, and more.
Failure to provide the right credentials automatically disconnects the person from carrying out the operation. What this means in essence is that the device is iCloud activation locked.
Can I Remove Activation Lock on iPhone 6/6 Plus?
Yes, you can remove the iCloud activation lock on your iPhone 6 or 6 Plus.
Removing iCloud activation lock is the only way to regain or reclaim control of your iPhone 6 or 6 Plus, and there are many ways to go about this. Can I Remove Activation Lock on iPhone 6/6 Plus without Previous Owner? Of course! This post will demonstrate the best 4 ways suggested by iOS experts. Continue reading!
1. Bypass iPhone 6/6 Plus iCloud Activation Lock via Previous Owner
One of the easiest ways to bypass the activation lock on your iPhone 6 or 6 Plus is via the previous owner. Although it can be stressful, if you are still in touch with the previous owner of your iDevice, and you have activation lock issues, all you need is to contact the person to provide you with the corresponding Apple ID details.
However, the credentials are confidential, you can meet with the person so you can bypass iCloud activation lock and regain control of your device in no time. This approach is simple and costs nothing.
Limitations
  • You must have the contact of the previous owner for you to use this technique to successfully bypass the activation lock.
2. Bypass iPhone 6/6 Plus iCloud Activation Lock without Apple ID [100% Work]
As one of the most popular and professional iCloud bypass tools for iOS devices in 2023. The easiest and safest way to bypass iCloud activation lock on your iPhone 6 or 6 Plus is via the iOS unlock utility – AnyUnlock – iPhone Password Unlocker. This software removes the activation lock in one click without requesting you to enter or provide your Apple ID credentials. Whether you are tech-savvy or not, this software is the most ideal to invest in because of the sleek UI.
AnyUnlock handles iCloud activation on your iPhone 6/6 Plus without compromising the data on it or jailbreaking your device. It fixes activation lock issues for any scenario, including unknown Apple ID, lost or forgotten Apple credentials, and more. What’s more, AnyUnlock uses an advanced unlock algorithm to scan your iOS security system and then suggests the most appropriate firmware package for your iPhone.
Key Features
  • Seamless iCloud activation unlocks services on all iPhone and iPad models.
  • Check iPhone/iPad unlock status when you bought a second-hand one.
  • Find the linked Apple ID or sign out of the current Apple ID of the iOS device in a simple way.
  • AnyUnlock resolves iCloud activation lock with data loss incurred.
  • More advanced features; iTunes Backup Password Recovery, SIM Unlock, Screen Unlock, Screen Time Passcode Unlock, Apple ID Unlock, and several others.
Free install AnyUnlock on Mac or Windows computer and follow the steps below to learn how to bypass iPhone 6/6 Plus iCloud Activation Lock>>
Bypass iPhone 6/6 Plus iCloud Activation Lock for Windows Users:
Step 1. Free download AnyUnlock and open the program on your computer > Click the Bypass iCloud Activation Lock mode.
Step 2. Connect your iPhone to the computer with a USB cable > Click the Start Now button after checking the device information.
Click Start Now Button
Connect Your iOS Device to the Computer
Step 3. Then, you need to jailbreak your device to allow AnyUnlock to bypass for you. Read the jailbreak tutorial to do and click Next once finished.
Jailbreak Your Device
Step 4. Then, AnyUnlock will bypass iCloud Activation Lock automatically. Please wait for a moment. When the iCloud Activation Lock is bypassed successfully, you can see the page below.
iCloud Activation Lock Is Bypassed Successfully
Bypass iPhone 6/6 Plus iCloud Activation Lock for Mac Users:
Step 1. Free download AnyUnlock on your Mac > Connect your iPhone with Mac > Choose Bypass iCloud Activation Lock and Start Now to get started.
Step 2. Click Start Jailbreak to continue, you need to read the “Terms of Use” carefully and confirm. Enter DFU mode by following the on-screen guide and jailbreaking process will start immediately.
Start to Jailbreak Your Device
Step 3. When the jailbreaking process completes, you can click on Bypass Now to start bypassing iCloud Activation Lock on your device.
Tap on Bypass Now to Start Bypassing
Step 4. Then, it will bypass the activation lock automatically. Do not disconnect your device until it restarts. Wait a minute and you will see bypassed successfully page.
  • Once the iOS device has been jailbroken successfully, some functions will not be available.
  • The jailbreak will disable cell phone call making, cellular data using, FaceTime calls making, iMessage sending, etc.
  • Any reset or upgrade processing will lock this iOS device again.
  • Please DO NOT log into iCloud from the Settings on your iPhone iPad iPod touch or factory reset your device which will lock the device again.
3. Bypass iPhone 6/6 Plus iCloud Activation Lock by Using iCloud DNS Bypass
With iCloud DNS, you can also remove the activation lock on your iPhone 6 or 6 Plus. This technique requires that you trick the WiFi DNS address on your iPhone by altering one or more of the figures and you are good to bypass iCloud activation lock.
Here is how to remove activation lock with iCloud DNS:
  • Hit the gear ⚙️ icon on your Home Screen and the Settings panel will pop up.
  • Choose WiFi on the page displayed to access the interface below:
Choose WiFi Option
  • Next, hit the i icon (also known as info) beside any of the WiFi networks shown on your iPhone.
  • Head down the page displayed, and click on Configure DNS button.
  • Next, select Manual, then click the red icon beside the DNS address displayed, and enter any one of the following below:
select Manual
Select Manual
  • Ensure the DNS address corresponds with that of your region.
  • After that, head back to the WiFi screen, and navigate to the Activation Help page.
  • Now, head back to the WiFi page by clicking on the corresponding button at the upper right corner of your screen. Once done, prevent your iPhone 6/6 Plus from activating by opening another screen.
4. Bypass iCloud Activation Lock on iPhone 6/6 Plus via Apple Help
By contacting the Apple helpline, you can also fix iCloud activation lock issues on your iPhone 6 and 6 Plus. Here, what you need to do is connect with the Apple Support team, and relay your issues.
To use this approach to bypass iCloud activation lock, you must have all the necessary information about the iPhone 6 or 6 Plus at hand. Some of the info needed include; name, email address, phone receipt, and more.
Limitations
  • Not a suitable solution for bypassing iCloud activation lock on a second-hand iPhone 6 or 6 Plus.
  • You must be able to provide all the required information.
Tip for You: How to Unlock Apple ID without Password [HOT]
Are you locked out of your iPhone or iPad due to Apple ID issues? Many users have the confusion like “Why is my Apple ID locked?” “How to unlock my Apple ID?” AnyUnlock is also a great tool to unlock your device without a password! This software is an all-round software for handling iOS security lock issues. It helps you unlock Apple ID on any iPhone or iPad model without stress.
Stepwise Guide to Unlock Apple ID without Password with AnyUnlock
Step 1. Free download AnyUnlock on your Mac/PC > Click the Unlock Apple ID option from the homepage.
Click Unlock Apple ID from the Homepage
Step 2. Connect your iOS device to computer via USB cable. Once your iOS device is detected, the interface below will display. Click Unlock Now and continue.
Click Unlock Now Button
Step 3. After that, AnyUnlock will start unlocking automatically if Find My iPhone is turned off. Wait for a while, you will get Apple ID removed successfully page below.
Apple ID Removed Successfully
If Find My iPhone is turned on or Two-Factor Authentication is enabled, you can click here and follow the guide to unlock your Apple ID. And after Apple ID is removed successfully, please do not erase all contents and settings on the device or restore the device with iTunes.
Final Words
Removing iCloud activation lock from your iPhone 6/6 Plus is very simple with the guide above. We demonstrated the 3 powerful ways to bypass activation lock without compromising your iPhone. Select and apply the technique that’s best for you. AnyUnlock is the most appropriate tool to fix activation lock and unlock your Apple ID. AnyUnlock is worth trying out>>
