Being locked out of your iPhone 11 or 11 Pro Max due to the iCloud Activation Lock can be a real headache. In this article, we’ve explored effective methods to bypass this lock. Whether you’ve forgotten your Apple ID or purchased a used device with lingering lock issues, we’ve got you!
Is the iPhone 11 locked? Stuck on the iCloud activation lock? Don’t worry! AnyUnlock, a professional iOS unlocker, can help you to perform iPhone 11 iCloud bypass without the previous owner, Apple ID, or password. Only simple clicks. Within a few minutes. Just try it for free!
Have you ever found yourself locked out of your iPhone 11 or 11 Pro Max due to the infamous iCloud Activation Lock?
It’s a common problem faced by iPhone users, and it can be incredibly frustrating. But fear not because we know what to do!
In this article, we’re going to reveal effective methods for iPhone 11 iCloud bypass. Whether you’ve forgotten your Apple ID and password or acquired a second-hand device with the Activation Lock still in place, we’ve got you covered. Read on to discover the solutions that can help you regain access to your device and get back to using it without any hassles.
Imagine this scenario: you misplace your iPhone 11, and someone else gets their hands on it. Without the Activation Lock, they could easily erase your device, factory reset it, and set it up as if it were their own.
This is where the Activation Lock comes into play.
When you enable the “Find My iPhone” feature on your device, it activates the iCloud Activation Lock. This means that even if a thief attempts to erase your device, they won’t be able to set it up as a new device without entering your Apple ID and password.
It is a valuable security feature. However, it can become a hindrance if you forget your Apple ID or purchase a second-hand device locked to someone else’s account.
You now know why iCloud Activation Lock is important. However, there may be instances where you want to bypass. For example, if you don’t have your Apple ID, what do you do? In such cases, you can use a reliable iPhone unlocker to bypass the Activation Lock. For this purpose, we suggest AnyUnlock.
AnyUnlock is one of the most popular and professional iCloud bypass tools for iOS devices in 2023&2024, it would be the best solution for your iOS device when it is stuck on the “Activation Lock” screen.
As a powerful iOS unlocker, AnyUnlock can easily meet your unlocking demands. No matter whether your iPhone is linked to an unknown Apple ID, you need to remove your Apple ID, or you forget your Apple ID email or password. By using its iCloud Activation Unlocker feature, you can easily bypass iPhone 11 iCloud Activation Lock without Apple ID or Apple ID password.
Step 1. Free download AnyUnlock and open the program on your computer > Click the Bypass iCloud Activation Lock mode.
Step 2. Connect your iPhone to the computer with a USB cable > Click the Start Now button after checking the device information.
Connect Your iOS Device to the Computer
Step 3. Then, please to jailbreak your device to allow AnyUnlock to bypass for you. Read the jailbreak tutorial to do and click Next once finished.
Jailbreak Your Device
Step 4. Next, AnyUnlock will bypass iCloud Activation Lock automatically. Please wait for a moment. When the iCloud Activation Lock is bypassed successfully, you can see the page below.
iCloud Activation Lock Is Bypassed Successfully
Step 1. Free download AnyUnlock on your Mac > Connect your iPhone with Mac > Choose Bypass iCloud Activation Lock and Start Now to get started.
Step 2. Click Start Jailbreak to continue, and read the “Terms of Use” carefully and confirm. Enter DFU mode by following the on-screen guide and jailbreaking process will start immediately. After the jailbreaking process completes, you can click on Bypass Now to start bypassing iCloud Activation Lock on your device.
Tap on Bypass Now to Start Bypassing
Step 3. Then, it will bypass the activation lock automatically. Do not disconnect your device until it restarts. Wait a minute and you will see the bypassed successfully page.
If your iPhone 11, 11 Pro, or 11 Pro Max is second-hand or used, you’re in luck. To bypass iCloud, all you have to do is contact the previous owner of your iPhone. Get the Apple ID and password and bypass the Activation Lock easily. Once you have the Apple ID and password of the previous owner, follow these steps.
iPhone iCloud Activation Lock
If you are unable to get a hold of the previous owner, you can try out the DNS method given below.
If all else fails, you can try to bypass the Activation Lock on 11/11 Pro Max via DNS. To do so, follow the steps given below.
1: Turn on your iPhone 11, 11 Pro, or 11 Pro Max.
2: When you reach the “Hello” screen, proceed with the device setup until you reach the Wi-Fi screen.
3: Connect to a Wi-Fi network by tapping on the “i” icon next to your network name.
Wi-Fi Setting
4: Enter a DNS server IP address according to your location.
USA: 104.154.51.7 / South America: 35.199.88.219 / Europe: 104.155.28.90 / Asia: 104.155.220.58 / Australia and Oceania: 35.189.47.23 / Other continents: 78.100.17.60
Adding DNS Address
5: Go back to the iCloud Activation Lock screen. You can now bypass it.
It is important to note that this method is not very reliable and may not work on all iOS devices.
Are you locked out of your iPhone or iPad due to Apple ID issues? Many users have the confusion like “Why is my Apple ID locked?” “How to unlock my Apple ID?” AnyUnlock is also a great tool to unlock your device without a password! This software is an all-round software for handling iOS security lock issues. It helps you unlock Apple ID on any iPhone or iPad model without stress.
Step 1. Free download AnyUnlock on your Mac/PC > Click the Unlock Apple ID option from the homepage.
Click Unlock Apple ID from the Homepage
Step 2. Connect your iOS device to computer via USB cable. Once your iOS device is detected, the interface below will display. Click Unlock Now and continue.
Click Unlock Now Button
Step 3. After that, AnyUnlock will start unlocking automatically if Find My iPhone is turned off. Wait for a while, you will get Apple ID removed successfully page below.
Apple ID Removed Successfully
If Find My iPhone is turned on or Two-Factor Authentication is enabled, you can click here and follow the guide to unlock your Apple ID. And after Apple ID is removed successfully, please do not erase all contents and settings on the device or restore the device with iTunes.
Don’t let the iCloud Activation Lock leave you feeling frustrated. With our techniques and tricks, you can easily get around the iPhone 11 iCloud bypass. Whether you choose AnyUnlock, reach out to the previous owner, or attempt the DNS method, solutions are at your fingertips. What’s more, AnyUnlock is the most appropriate tool to fix the activation lock and unlock your Apple ID. AnyUnlock is worth trying out>>
