iCloud Activation Lock is a great security feature, but can cause havoc when you lose the corresponding details associated with your iCloud. Discover the best 7 ways to bypass iPhone X iCloud activation lock in this guide.
Hi, Recently, I got a secondhand iPhone XR from eBay with iCloud activation lock on it. However, unfortunately, I don’t know the previous owner, or have the iCloud details linked to the device. So I can’t access the device. Can someone explain to me how to bypass iCloud activation lock on iPhone XR? Please!
A scenario as above or one in which you cannot recollect the corresponding credentials to your iPhone can be frustrating, but it’s nothing to stress about. There are some simple tricks you can employ to regain control of the device, which will be shared in this post.
Whether it’s an iPhone X, XR or XS you want to bypass iCloud activation lock on, the solutions provided here will surely come in handy. Continue reading!
Sure, an iPhone X/XR/XS can be iCloud bypassed, but so far you’ve got the details at your disposal. However, in a scenario where you can’t remember or don’t have access to the details, you need a professional iOS unlock tool.
Before we discuss how to unlock iCloud activation locked iPhones or introduce the right software, let’s look at what iCloud activation lock is. In addition, we will explain how to know if an iPhone is iCloud locked.
Activation Lock is one of the best security features tucked by Apple into all its devices, whether mobile or computer. This feature is programmed to provide the utmost security needed to protect users’ data from unauthorized access.
The activation lock has a simple mode of operation, which depends solely on iCloud credentials. When you sign in your iCloud details on an iPhone, whether X/XR/XS or the latest models, the device is automatically locked.
Your device remains active and can be easily accessed without any issues, in as much as you have the details at hand. However, in a scenario where you need to reset the device, or forgot the corresponding iCloud details, using the device becomes a challenge. And that’s where you know that the phone is iCloud locked.
Below, we have the various ways to bypass iPhone X/XR/XS activation lock without iTunes, apply the procedure that suits you:
If you bought a secondhand iPhone X/XR/XS from a close person or relative, and don’t know the corresponding details to the device, you need not be disturbed. You can simply connect or contact the previous owner to help you with the iCloud details so you can gain full control of the device you purchased from them.
Once you get the details, enter them in the correct order and hit the Next button to deactivate activation lock. After gaining access to the device, we advise that you delete the iCloud account, and create or sign in yours.
Activation Lock on iPhone
Note: If the iPhone is running on iOS 11 or later versions, you need 2FA code to successfully bypass iCloud activation lock. This means, that after entering the iCloud details, the previous owner must provide the two-factor-authentication (2FA) code sent by Apple to you, so you can bypass activation lock completely.
In a scenario where you don’t know the previous owner or cannot reach out to them, you can ask the Apple support team for help. This approach is simple, and cost free. However, you must be ready to answer and provide all the necessary information needed. Also, you may have to provide documentation proving that you bought or inherited the device.
Apple Support Webpage Interface
With an iPhone unlocker like AnyUnlock, you can easily bypass activation lock on any iPhone model, including iPhone X/XR/XS, without compromising your device. AnyUnlock is the most versatile tool, well-known worldwide for its excellent results.
There are some outstanding features you need to know about AnyUnlock – iPhone Activation Lock Unlocker:
To bypass the iCloud Activation lock, you should free download the AnyUnlock – iPhone Password Unlocker based on your computer operating system. This application is compatible with both Windows PC and Mac.
Step 1. Free get AnyUnlock – iPhone Password Unlocker installed. Launch the software and you will see the page below.
Click on Start Now to Bypass iCloud Activation Lock
Step 2. Connect your device and click Start Now button.
Connect Your iOS Device to the Computer
Step 3. Then, you need to jailbreak your device to allow AnyUnlock to bypass for you. Read the jailbreak tutorial to do and click Next once finished.
Jailbreak Your Device
Step 4. Then you can start bypassing after clicking Start Now button.
Bypassing iCloud Activation Lock
Step 5. Wait until the process finished, you will get iCloud Activation Lock is bypassed successfully page as below.
iCloud Activation Lock Is Bypassed Successfully
Via DNS, you can bypass iCloud activation lock on your iPhone X/XR/XS without stress. All you need for this approach to work is to change the corresponding readable domains on your iPhone into numerical IP addresses, and the activation lock will disappear immediately.
However, mind you, this solution only works when you have your iCloud details at hand. If you don’t, then bypassing the activation lock on iPhone X may be impossible.
Follow the instructions below to bypass the activation lock on iPhone X via DNS:
Click the Configure DNS Option
Limitations
iRemove is another powerful tool that offers quality iOS unlock services. With this software, you can remove the iCloud activation lock from your iPhone X or XR without stress. Using this software is simple, as you don’t need iTunes to bypass the activation lock.
iCloud Removal Tool – iRemove
Limitations
iToolab UnlockGo is also capable of removing or deactivating iCloud activation lock on iPhones, both X series and later versions. It’s one of the simplest tools that lets you remove activation locks without iTunes. The approach to using this tool is straightforward, as it offers a clean user interface to ease navigation.
iToolab UnlockGo to Bypass iCloud Activation Lock
Limitations
If applying the solutions above your iPhone X or XR remains locked, consider using an online service to bypass the activation lock. There are lots of online services you can use to bypass the activation lock on your iPhone without connecting to iTunes. All you need to use this approach is the IMEI of the device, that’s all.
Limitations
Here are some frequently asked queries and answers related to this topic that you can read through to understand it better:
No, jailbreak won’t bypass iCloud lock. Instead, it can only help you remove the restrictions placed by the manufacturer. If you need to remove or bypass activation lock, then a professional iOS unlock tool is what you need.
No, you cannot jailbreak an iCloud-locke d iPhone. The reason is that jailbreaking requires access to the device itself.
If you are considering jailbreaking your iCloud-locked phone, kindly use any of the solutions above to bypass the iCloud activation lock, then proceed with jailbreaking.
Depending on the approach you follow to bypass the iCloud activation lock, you may or may not lose data. For instance, when you bypass the activation lock using iTunes, you have to lose data, as you need to restore your device. Also, when you use the Find My Phone feature, you will surely experience data loss.
However, if you use trusted software or any of the approaches above, the possibility of losing data is zero. This means, no data loss will be incurred.
The best ways to remove the activation lock on iPhone X/XR/XS have been given in the article above. Select any of the 7 solutions to bypass the activation lock without iTunes.
However, of all the solutions, AnyUnlock offers the best way to get rid of activation lock on iPhone X/XR/XS. The software clears a fixation lock error on all iPhone models without connecting to iTunes. It would help if you used it for your iOS unlock services.
