If you have bought an iPhone and found out that it is locked to AT&T, which makes you unable to use another cheaper network, how to unlock your AT&T locked iPhone? Here, in this post, we will discuss several proven ways to unlock AT&T iPhone.
Want to change the carrier of your AT&T locked iPhone, how to unlock it? Just free download AnyUnlock to unlock AT&T iPhone with ease. Only simple clicks and a few minutes are needed.
It might be possible that you have bought a new mobile phone or a second-hand iPhone from a previous owner and it is locked to a specific network carrier, i.e., AT&T. You bought an iPhone on AT&T’s network and now want to know how to unlock AT&T iPhone so you can use it on other networks.
AT&T Unlock iPhone
When you buy a phone from a carrier, it is usually locked to that carrier’s network, so you can’t take an AT&T phone and switch to another network right away. There are, however, a few ways to get AT&T unlock iPhone so that you may use it on other networks. How? In this article, we will illustrate the proven ways to unlock AT&T iPhone easily and quickly.
To remove Apple ID, you can read: How to Remove Previous Owner’s Apple ID without Password >
Many users ask: Can iPhone AT&T be unlocked? Yes, it is possible to unlock AT&T iPhone. Once your phone is paid for in full and your account is in good standing, you may unlock iPhone AT&T free. The approval of your request normally takes a few minutes, but it might take up to 48 hours.
If you make AT&T unlock iPhone, you can use them with another network carrier. The AT&T unlock can help you switch to a cheaper network carrier which provides tariffs to save more money and make your call and data usage better.
If you bought a network locked SIM card inserted AT&T a long time ago, the device may be restricted to the AT&T network. Check to discover if your iPhone or iPad is locked to the AT&T network if you purchased it on a particular plan.
Step 1. First, go to Settings, then to Cellular.
Step 2. If you see a Cellular Data option in the Cellular menu, your iPhone is unlocked.
Yes, unlocking your AT&T phone yourself is possible. You can use professional iOS unlocking tool, like AnyUnlock to unlock your AT&T locked iPhone by yourself.
There are many requirements and limitations to unlock AT&T iPhone directly, and you’ll need to wait at least two business days. So if you are looking for a quick and easy way to make AT&T unlock iPhone, then you need a professional iPhone unlocker: AnyUnlock. This powerful unlocker integrates SIM unlocking, iCloud activation lock unlocking, finding Apple ID, unlock screen passcode, and other functions into one platform, so that you are no longer restricted by SIM. For more features, read below.
Free download the latest version of AnyUnlock and unlock AT&T iPhone by following the instructions below!
Step 1. Start AnyUnlock. Select the Remove SIM Lock function and tap Start Now. After successfully connecting your iPhone and computer with a USB cable, click Confirm.
Choose Remove SIM Lock
Step 2. Please read the instructions on the screen carefully, and click Confirm again if you agree. Tap on Jailbreak Tutorial and follow the instructions. When done, click the Next button. Finally, press the Remove Now button.
Click Remove Now
Step 3. Make sure to follow the guide to turn off WiFi and insert the SIM card. After clicking Unlock, AnyUnlock will automatically remove the SIM lock for you.
Pull Out of SIM Card and Disconnect the Internet
Step 4. Wait a few minutes. When the unlocking process is finished, you will see the interface below.
SIM Lock Removed Successfully
When you purchase an iPhone from AT&T, it is “locked” to their network. That implies you won’t be able to use another network SIM card. If you are traveling, the same goes with a foreign SIM. Then can AT&T unlock my iPhone? Yes, of course. AT&T has a system in place that allows you to request a code to conduct AT&T iPhone unlock. Of course, there are some conditions and limitations that you must first be aware of before you make AT&T unlock iPhone.
There are a few things you should know before contacting the network carrier to unlock AT&T 2023.
Different AT&T services, such as pre-paid customers and others, may have unique situations. Before you go any further to unlock iPhone AT&T 2023, double-check that your iPhone is eligible.
AT&T claims that it will unlock your phone within two business days after receiving a request. And here is the guide to unlock AT&T iPhone.
Step 1. Visit att.com/deviceunlock to unlock your device.
Visit AT&T Device Unlock Portal
Step 2. To unlock your smartphone, read and agree to the eligibility requirements.
Step 3. Fill out the request form and send it in.
Step 4. A confirmation email containing your unlock request number will be sent to you.
Step 5. To confirm your unlock request, click the link in the email within 24 hours after receiving it.
Step 6. Within two working days, AT&T will respond.
Step 7. If your request is accepted, AT&T will provide you with information on how to unlock your handset.
It is impossible to unlock AT&T phone not paid off, you first need to fulfill the contract, and then you can only forward to proceed for the unlocking process.
Now you may know how to unlock AT&T iPhone. And below, we also list some other questions about the AT&T unlock. Let’s take a look together.
Phones do not have a single master pin to unlock them since each is unique to the individual who sets it up. They may have a SIM pin that is set to 0000 or 1234 by default, however, this is the SIM card’s pin, which may be modified by the user. Your smartphone will prompt you to enter a PIN code when you enable SIM lock. The default AT&T SIM card PIN code is “1111”.
It often takes 48 hours to unlock AT&T iPhone. And if you don’t want to wait, you can use AnyUnlock to unlock your device in 5 minutes.
To unlock your smartphone, call your provider and request a Network Unlock Code (NUC). Most will give you one, and some will even do it for free after your contract is over. You should be able to type the code into your phone to unlock it after you have been given it.
Yes, AT&T can refuse to unlock your phone if you owe them money or are currently under contract, but if you have completed the contract, you can simply request AT&T to unlock your device and provide proof of your deployment.
Yes, a Verizon SIM card may be used in any AT&T unlocked phone. Simply visit a Verizon Wireless store or use the phone activation tool online through your Verizon account login to activate the SIM card and phone. And you can also click and see how to switch from AT&T to Verizon.
We hope that these methods help you to unlock your AT&T locked iPhone in an easier and faster manner. As you have read, it is possible to let AT&T unlock iPhone with the required documents, you just need to follow the above ways. But if you want to unlock your iPhone as soon as possible with the easiest way, AnyUnlock is undoubtedly your best choice. Just free download AnyUnlock and unlock AT&T iPhone now!
