Apple ID ‘Verification Failed’ is one of the many issues you would encounter as an iPhone user. Here in this post, we will discuss everything about Apple ID ‘Verification Failed’, from definition to the reasons why you encounter such a problem, and how to fix it.
Hi, I’m having issues with Apple ID on my iPhone. It keeps showing “Verification Failed: There was a problem connecting to the server” each time I try to validate payment or download an app from iTunes/App Store. I don’t know why I’m getting this error message. Has anyone encountered such a thing? Please, how do I fix it?
Having to deal with Apple ID verification issues can be frustrating just as we have in the scenario above. But it’s nothing to worry about now that you are on this page. Here, we look at the 10 troubleshooting techniques to fix Apple ID Verification Failed issues without compromising your device. However, before then, lets discuss what Apple ID Verification Failed means, and why you encounter such on your iPhone.
Apple ID Verification Failed is the error message displayed on your Apple device screen each time you are unable to verify or authenticate your Apple ID credentials. This message usually pops up when you want to validate payment for iTunes or install an app from the App Store.
Why you encounter this error isn’t specific as there are several reasons involved. The next section of this post will discuss what triggers Apple ID Verification Failed issues on an iPhone.
Verification Failed an Error Connecting to Apple ID Server
Find below the possible reasons why you are experiencing Apple ID Verification Failed on your iDevice:
Using Apple ID requires a data network. However, mind you, not just any type of network is needed. You have to be connected to a strong and reliable network for you to use Apple services, such as iTunes, App Store, and others, with your Apple ID.
Your inability to get a stable network would result in Apple ID Verification Failed issues. A simple way to fix this problem is to shuffle between data sources, that is from cellular data to WiFi. Alternatively, you can switch network carriers.
Another potential reason why your iPhone may display Apple ID Verification Failed is when there is downtime in the Apple server. The Apple server controls virtually all operations of all the devices under the Apple ecosystem. Once there’s a breakdown in this server, your device starts misbehaving.
Date and time play a crucial role in the Apple ID verification process. Apple often cross-checks the date and time on your device and matches it with what’s on its server. Should the system observe a difference, you may experience Apple ID Verification Failed issues.
Here is a common reason why Apple ID Verification Failed on your iPhone. You need to enter the correct details that correspond with your Apple ID for you to successfully gain access to your account.
The easiest and safest way to fix Apple ID Verification Failed issues is via a professional iOS Unlocker like the AnyUnlock software. This software helps you clear Apple ID Verification Failed notifications at a remarkably high speed without compromising your iPhone.
Step 1: Free download AnyUnlock on your Mac/PC > Launch it. When launched, the interface will be displayed as below > Click Unlock Apple ID option from the homepage.
Step 2: Connect your iOS device to computer via USB cable. Once your iOS device is detected, the interface below will display. Click Unlock Now and continue.
Click Unlock Now
Step 3: After that, AnyUnlock will start unlocking automatically if Find My iPhone is turned off. Wait for a while, you will get Apple ID removed successfully page below.
Unlock Apple ID Successfully
Since incorrect Apple ID credentials can cause your iPhone to display Apple ID Verification Failed, changing your details should be a cool solution to solve the problem. We strongly recommend that you use a password you can easily recollect to avoid a similar issue in the future.
Here’s how to change your Apple ID password:
Change the Apple ID password on your iPhone
Your internet connection plays a key role in your Apple ID connectivity. When your data/internet connection is down, using Apple ID is impossible. So we strongly suggest that you check your internet connection.
If the internet connection is poor, you should consider switching your data source from cellular data to WiFi or vice-versa.
Restarting your iPhone is another credible solution to fix the Apple ID Verification Failed error message coming up on your display screen. This helps you refresh your iPhone, remove all the bugs and glitches causing it to misbehave.
This solution is super easy to implement, and cost-free. You can use these steps to restart your iPhone without stress:
Have you checked your internet connection? If so, and your iPhone still displays Apple ID Verification Failed, then consider restarting/updating your network settings. This solution doesn’t result in data loss. Instead, it helps you refresh your network and allows you to sign into WiFi freely.
Restart your network settings following the detailed instructions given down here:
Select Reset Network Settings
Your network will automatically reset. Wait that to finish, then try using the Apple ID again to see whether or not the Apple ID Verification Failed issue is resolved.
As earlier stated, wrong date and time is one of the principal reasons why you experience Apple ID Verification Failed on your iPhone. A simple way to fix this is check and adjust your iPhone’s date and time.
You can check out these steps to adjust date and time on your iPhone:
Check the Date & Time Settings
Should the solution above fail, you can try signing out and in your Apple ID. This solution refreshes your Apple profile and clears the Apple ID Verification Failed error message you have on your screen in no time. It helps you resynchronize your details on the Apple server.
Use this guide to sign out/in your Apple ID:
Get Apple ID Verification Code
If you are still experiencing Apple ID Verification Failed issues, the problem might be from Apple server. Downtime in Apple server slows down or pauses all operations on the entire Apple systems, whether iPhone, iPad, or Mac. The simple thing to do now is to check Apple server status to confirm if this is true.
You can check Apple server status using this guide:
Check Apple Servers Status
Are you using VPN with your iPhone? If so, you can encounter the Apple ID Verification Failed message on your phone. In order to fix this, you need to disable VPN on your device.
To disable VPN, use the stepwise guide below:
Lastly, we suggest logging out and in your WiFi to fix Apple ID Verification Failed on your iPhone. It simply involves forgetting the WiFi and then reconnecting.
Apple ID Verification Failed isn’t a complex issue to fix anymore now that you have our comprehensive guide at hand. Just select any of the 10 solutions provided, and Apple ID Verification Failed will clear immediately.
Our best solution remains the AnyUnlock tool. The software fixes Apple ID Verification Failed without complications. It’s worth trying out.
