If you are wondering about how to set ringtone in iphone without itunes, this tutorial will show you with detail.
Looking for a personalized ringtone for an iPhone, then have a close look at this article based on the How to Set Ringtone in iPhone without iTunes? All the old days are washed off that you go for a premium plan for customized ringtone. After reading this article carefully, following one method out of both, you can quickly get a personalized ringtone on your iPhone.
If you want to make any piece of music as the ringtone on your iPhone, there is no better choice than AnyTrans. Although it is mainly known as an iOS data transfer tool, it is also an iPhone manager. For instance, you can use it to manage iPhone photos, add ringtones to iPhone, and organize apps, etc.
Moreover, you can use it to backup iPhone, switch from android to iPhone, restore iPhone backup, and so on. In a word, AnyTrans can meet your every demand in managing and using an iPhone. Just download AnyTrans and start customing ringtones for your iPhone.
Follow the steps below to create a ringtone with AnyTrans.
Step 1. Launch AnyTrans > Connect your iPhone to the computer via USB cable > Go to category management page > Choose Ringtone Maker and tap Import from Device.
Tap Import from Device
Step 2. Choose the voice recording you want to make a ringtone from Voice Memos (Here the music from your iPhone will be listed too).
Choose the Voice Recording You Want to Use
Step 3. Choose Ringtone (Also, you can choose Text Tone to make custom text tone directly here) > Then drag the slider to choose your favorite period > Click on Import to Device > Before that, you can play it and make sure that you like it.
Select and Set Ringtones to Transfer
Step 4. When the transfer is completed, go to Settings > Sounds/Sounds & Haptics > Ringtone to find and set the recording as your iPhone ringtone.
To set a particular ringtone on your iPhone with the help of GarageBand. In contrast, performing this method, users no need to use any kind of computer. It can be done only with the help of a mobile phone. Check out all the detailed steps that are given below carefully.
Set Ringtone in iPhone with GarageBand
This is another way to get a customized or personalized ringtone for your iPhone with the help of a ringtone maker application. You can create your own iPhone ringtone without any hassle. Check out all the detailed steps that are helpful to create a ringtone.
Set Ringtone with Ringtone Maker
We hope that all your issues related to how to set ringtone in iPhone without iTunes have been resolved after using any one method out of both ways listed above. However, it is entirely hassle-free to build a customized ringtone for your iPhone.
You can easily create your song ringtone with the help of the GarageBand and Ringtone Maker applications. There are zero charges applied for doing that. Now finally, after reading this article, your search ends here related to creating your ringtone on your iPhone.
