7 Ways to Fix Screen Recording Not Working on iPhone/iPad
This guide will introduce 7 common solutions to help you fix screen recording not working on iPhone iPad. Check the solutions one by one to get the workable way for you.
Author Avatar Joy Taylor Last Updated: May. 16, 2024
After enabling Screen Recording on your iPhone or iPad that runs in iOS 15, you can use it to record your screen easily rather than using third-party applications.
However, sometimes you may encounter an annoying problem that is iOS 15 screen recording does not work as expected. Some iPhones do not record videos, the screen recording fails to save, the recording videos have no sound, or the screen recording does not show up iPhone, etc. To get screen recording to work on your iPhone, here are some potential solutions you can try NOW.
Why is My iPhone Screen Recording Not Working?
The most common reason is that you might turn on the Content Restrictions on your iPhone, which is used for blocking possible inappropriate content. Other reasons are also related to the iPhone settings, for example, you can’t use the iPhone screen recording might be because the iPhone doesn’t have enough storage space, you didn’t turn off the low power mode, or the model of your iPhone is too old for this new feature.
No matter what the reason in your case, try the following solutions and see if they can fix the problem.
Solution 1. Add Screen Recording to Control Center
Before you use a screen recorder to record your iPhone or iPad screen, you need to ensure that you’ve enabled Screen Recording and add it to the control center on your device. To do this:
  1. Go to Settings and choose Control Center.
  2. Scroll down to find out Screen Recording and add it.
Then you can use iPhone screen recording from the control center directly.
Solution 2. Check Restrictions and Reopen Screen Recording
If you enabled Screen Recording and meet screen recording doesn’t work problem, then you can try to turn it off and turn it on again. During this process, it’s better to restart the iOS device.
For iOS 12 or later: Open Settings > Tap Screen Time > Choose Content & Privacy Restrictions > Go to Content Restrictions to check if Screen Recording is allowed from the Game Center.
For iOS 11 or earlier: Go to Settings > General > Restrictions > Game Center and turn off-screen recording, restart your device, and then turn it on again. Sometimes, this also can fix the Screen Recording won’t start just the icon blinking.
Check iPhone Content Restriction
Solution 3. Repair iOS System with AnyFix
The iPhone screen recording not working issue can be caused by some system-related failures and you may need to consider iOS system repair. AnyFix is a trustful system repair tool for iPhone, iPad, iTunes, and Apple TV. It will go through your device system quickly and find out the problems, then repair them in minutes. You can check the main features of AnyFix in the following:
To fix screen recording not working on iPhone/iPad:
Step 1. Download and install AnyFix on your Windows or Mac computer.
Step 2. Launch it and choose System Repair.
AnyFix System Repair Option
Step 3. Then choose App Issues and click Start Now.
AnyFix System Repair App Issues
Step 4. You can choose from the 3 repair modes you want and follow the instructions to finish preparing iOS system with AnyFix. Please note that the Standard Repair will not cause data loss.
AnyFix Standard Repair
After repairing, you can try the screen recording on your iPhone again.
Solution 4. Fix iPhone Screen Recording no sound
Some users reported that what they capture on the screen is displayed on their devices but without actual sound. This is a simple problem because it is just due to the witch of the Microphone not being turned on. To fix it, simply reveal Control Centre and tap on the Screen Recording icon, then hit the “Microphone” icon to turn the audio on.
Besides, you can try to record iPhone audio on a PC with Gemoo Recorder Lite. It is a powerful PC screen recording software that is designed to capture your screen activity. You can use it to record the camera, screen, audio, or both screen and camera. You can choose the preferred mode based on your needs. To record iPhone screen with audio, mirror your iPhone on PC and record whatever you need.
Gemoo Recorder Lite
Gemoo Recorder Lite
Solution 5. Reset All Settings
If the above 4 methods can’t fix your problem, then you can try on resetting your iPhone. This method won’t remove any data from your iPhone and it will help you reset some settings that may affect screen recording work. Simply go to Settings > General > Reset > Reset All Settings.
Click on Reset All Settings
Solution 6. Fix Screen Recording Failed to Save
If the screen recording fails to save due to 5823 or other issues, the screen record doesn’t work. Then you can check the tips below to try to fix it:
1. Turn Off Low Power Mode
When the low power mode is enabled, it will temporarily reduce background activity like downloads and mail fetch until you can fully charge your iPhone. Screen recording may not be saved to Photos. Just go to Settings > Battery to check.
2. Check iPhone Storage
If you do have not enough space on your iOS device, the screen recording won’t be saved. Please make sure that there is enough space in your iPhone storage. You can check by going to Settings > General > iPhone Storage. If your iPhone Storage is almost full, delete some videos you don’t need. Or if you don’t want to delete anything, then you can try to upload screen recording videos to iCloud or export them to the computer.
3. Force Restart your Device
If you can’t use screen recording or it fails to save, maybe the button or the function is not running properly. Except that you can exit and reopen it from the control center, you can also restart or force restart your device like this:
iPhone 8 and later: Press and quickly release the Volume Up button > Press and quickly release the Volume Down button > Press and hold the Side button until you see the recovery-mode screen.
iPhone 7/7(plus): Press and hold both the Side and Volume Down buttons at the same time > Keep holding them until you see the recovery-mode screen.
iPhone 6S or earlier: Press and hold both the Home and the Top (or Side) buttons at the same time > Keep holding them until you see the recovery mode screen.
Solution 7. Upgrade to the Newest iOS Version
Due to system glitches, your iPhone may have a black screen or screen recording not working issue. You wait for the new iOS version and try to upgrade your iOS device to the newest iOS version. Every update will provide some bug fixes and improvements. Updating iOS may fix your problem without effort.
That’s all for how to fix the screen recording not working on iPhone. Hope this guide can give you a hand in fixing this issue. By the way, AnyFix is worth trying for iOS system repair and fix the screen recording issues. If you encounter other problems with Screen Recording, or you have any further solutions on the topic, feel free to leave them in the comments.
