If the screen mirroring feature is not working on your devices, you may want to look into the issue and fix it. The following post walks you through some of the common solutions you can use to fix the issue on your devices.
Screen mirroring allows people to project their phone’s screen on a large TV, iPad, or computer monitor. Entertainment is not the only purpose for users screen mirroring iPhone, people tend to apply mirroring tools in the field of presentation, content creation, App development, and live streaming.
However, it is not fully error-free. There are times when it gets hiccups and does not work the way it is supposed to. If this happens to you as well, there are a few fixes you can apply to get around the issue on your devices. The following guide covers some of the basic things you can do when screen mirroring is not working on your TVs.
Performing the following methods does not require any technical abilities. If you can do basic things on your device, below are the solutions to fix the screen mirroring not working issue:
The first thing you will want to check is if the input of your TV is set to screen mirroring. If the input is something else, say an HDMI source, you will have issues mirroring your phone’s screen to your TV.
On most TVs, you can head into the settings menu to change the current input. Or you can also use the options available on your screen to do so.
Most screen mirroring services restrict you to using one device at a time. Therefore, make sure that you are only connecting one device at a given time to your TV.
If your TV finds that you are trying to connect multiple devices, it may refuse the connection and you will not be able to establish the connection.
Sometimes it may be that your smartphone has a minor software glitch that prevents you from mirroring your phone to your TV. These small glitches do not require much effort to be resolved. Simply reboot your devices and these issues will be likely fixed. You may then try connecting your phone to your TV to see if it works then.
Turn off and Then on Your Device
Some smart televisions require you to first pair your smartphone with your TV before you are able to use the screen mirror function. This is to ensure you are the authorized user to do the task.
Your TV manual will have the steps on exactly how to pair your phone with your TV. Once the phone is paired with the TV, try to mirror your screen and you should be able to do it.
Since the screen mirror feature uses wireless technologies, you must ensure there are no physical objects causing interference between your phone and your TV. If there are any objects, remove them first before you try to connect the phone to your TV.
Get Rid of the Interferences
Screen mirroring usually works over a WiFi connection and so you do not need Bluetooth enabled on your TV. Since Bluetooth is a wireless technology, it may cause interference with your connection. Turn the Bluetooth feature off on your TV and then try again.
Most users prefer to use the default screen mirroring app that comes preloaded on their devices. However, you are not limited to using those apps. If the one on your phone does not work, get another from your app store and see if it works.
Your smart TV could also be experiencing issues and restarting the TV will most likely solve all the small glitches on it. Use the TV remote or the button on your TV to turn it off. Then, turn the TV back on.
Since screen mirroring takes place over your WiFi connection, you must make sure your WiFi router is properly working. If it is not, reboot the router and see if that helps fix the issue.
Restart the Internet Router
If you still cannot do screen mirroring, there may be an issue with the protocols you are using. Apple AirPlay and Google Cast do not always work.
You may try using other services like Chromecast and see if they help you get your job done. This should also fix the Samsung Smart TV no sound issue if you were facing it on your TV.
Applying screen mirroring is much simpler than fixing the issues that it brings. If you don’t know how to mirror your phone to PC or TV yet, you will find the answer in this part.
Whether you’re using an iPhone or an Android, there are two methods you can use: with a USB cable and with a WiFi connection.
1. Mirror Screen with USB Cable:
Using a USB cable to connect devices can make the screen mirroring more stable, especially when you need to mirror from your phone to the PC and do not want any interruptions. Most of the built-in mirroring functions of the system rely on a WiFi connection, so if you want to use USB mirroring, you need to download a third-party app like AnyMiro, or AirDroid.
Inside the third-party screen mirroring software, there are options for you to choose whether you want to connect your device via USB or WiFi. Choose to use the USB cable, and follow the on-screen instructions to start mirroring.
2. Mirror Screen with WiFi:
Common screen mirroring options like AirPlay, QuickTime Player, and Smart View are all methods of mirroring screens by WiFi.
On your iOS devices, you can open Control Center and tap on AirPlay to start using the screen mirror feature. You must have a device that supports AirPlay to receive the content.
On an Android device, you may use an app like SmartThings to perform screen mirroring.
Set Up Screen Mirroring on iOS
AirPlay works great when you want to mirror your iOS device’s screen to another AirPlay-enabled device. It doesn’t require you to download any app and can promise you a relatively stable connection. However, most Windows PCs are not AirPlay-enabled. There are some handy AirPlay alternatives you can try to mirror your iPhone to PC.
AnyMiro works as the best partner for live-stream platforms like OBS and Streamlabs. If you’re a game player, artist, or Vtuber who needs to stream your phone screen to Discord, Twitch, or YouTube, you must have a try on AnyMiro. Here is what makes AnyMiro stand out of the crowd:
Here are the steps of how to mirror your phone’s screen with AnyMiro, it takes iPhone as an example.
Step 1. Download and run AnyMiro on your computer.
Step 2. Select mirror iPhone/iPad to enter iPhone mirroring.
Mirror iPhone to Computer
Step 3. Connect your iPhone to PC with a lightning cable.
Mirror iOS Device to Computer via USB
Step 4. Tap “Trust” on your iPhone, and wait a few seconds, you can see the iPhone screen on the computer.
Trust Your Computer on iPhone
AnyMirror is one of the best alternatives that allows you to mirror your iPhone on your computer (Mac/PC) with a few clicks. These are why you need AnyMirror to mirror your iPhone:
Step 1. Free Download AnyMirror both on the computer and on your iPhone/iPad.
Select Function on AnyMirror
Step 2. Then launch AnyMirror on the computer and connect your iPhone with a USB cable > Choose Screen Mirroring on your computer and tap on OK.
Choose Screen Mirroring On Computer
Step 3. Please select Screen Mirroring mode on your iPhone > Select USB > Click the Start button >Click Start Broadcast button.
Choose Start Broadcast on iPhone
Step4. When your iPhone is detected successfully by AnyMirror, then you can go to any screen that you want to mirror to the computer.
Mirror iPhone Screen to Computer Successfully
If it is the first time that you connect iPhone to the computer you need to click “Trust” on your device.
Please make sure you’ve installed iTunes on the computer to help detect iPhone/iPad.
AnyTrans is also one of the best alternatives you can use to mirror your iPhone or iPad to any of your computers. It works on both Windows and Mac and lets you quickly stream the content of your device to your computer. To get more info, just refer to How to Screen Mirroring with AnyTrans > Or, you can download and install AnyTrans now to try this free feature.
Also Read: How to Move iPhone Photos to Mac >
We hope the above guide helps you fix the screen mirroring not working issue on your devices. And if you cannot get the default feature to work no matter what, you should consider using a third-party app to mirror your iPhone or Android to a TV or a PC.
