How Can I Mirror My iPhone to iPad
Viewing content on large screens is always a good idea and with screen mirroring, you can mirror your iPhone to your iPad and have your iPhone content shown on the large screen of your iPad. Here is how you make it happen.
Author Avatar Joy Taylor Last Updated: Aug. 20, 2024
One of the many things people like about Apple devices is that you get a ton of new and exciting features for your devices. These features let you get a number of tasks done with ease on your Mac and iOS-based devices. Screen mirroring is one of Apple’s features that lets you view the content of one Apple device on a bigger screen, which can be achieved by named Airplay. Then, you can directly view your iPhone/iPad/iPod/Mac on HomePod, Apple TV, and so on.
However, the iPhone screen cannot mirror to iPad directly. Some third-party software is needed. So if you’d like to mirror your iPhone to an iPad, bring the photos, videos, and many other files you have on your iPhone to the large screen of your iPad. In the following guide, we take a look at how you do screen mirroring from iPhone to iPad.
Also Read: Screen Mirroring Not Working? Get Solutions Here >
Part 1. Mirror iPhone to iPad with ApowerMirror
ApowerMirror is a wonderful screen mirroring app for both Android devices and iPhones, with full compatibility for Windows and Mac. Moreover, this tool offers not only casting your phone screen to the computer but also features streaming your iOS device to another iOS device or iPadOS (the streaming device requires iOS 11 or later). The following is how you can mirror your iPhone to iPad:
Step 1. First of all, download the ApowerMirror app on your two iOS devices and make sure both your iPhone and iPad are connected to the same WiFi network.
Step 2. Launch the app on the streaming iPhone and then tap the “M” button to search for another iOS device, which is your iPad name.
Tap the M Button in ApowerMirror to Search Your iPad
Step 3. Swipe up from the bottom of your iPhone and open Control Center > Tap on “Screen Recording” button in the list of available options (if it’s not available, go to Settings > Control Center > Customize Controls > add Screen Recording) > Choose the name of “ApowerMirror” > Tap “Start Broadcast” to start mirroring and then your iPhone will be mirrored to iPad.
Open Control Center and Tap on Screen Recording
You are all set. It will begin mirroring your iPhone’s screen to your iPad. When you are done mirroring and you want to stop it, simply open Control Center on your iPhone and disconnect from your iPad. That should disable the screen mirroring.
Part 2. Mirror iPhone to iPad with TeamViewer
Step 1. Download and install TeamViewer on both iPhone and iPad.
Step 2. Swipe up from the bottom of your iPhone and open Control Center > Tap on “Screen Recording” button (if it’s not available, go to Settings > Control Center > Customize Controls > add Screen Recording) > Choose the name of “ApowerMirror” > Tap “Start Broadcast” to start mirroring and then your iPhone will be mirrored to iPad.
Step 3. On your iPad: Open TeamViewer > Enter your connection partner’s ID and password > Tap “Remote Control”
Step 4. On your iPhone: Click on “Allow” when prompted. Your iPhone will connect with the iPad in real-time and you can control it as your need.
How to Fix AirPlay Not Working
What is Apple AirPlay
AirPlay is what you use when you want to stream audio, and video and mirror the screen from iOS devices/Mac to an AirPlay-compatible device. It takes care of the background tasks and you only need to tap on an option to get the job done. The feature comes preloaded on all modern Apple devices including the iPhone, iPad, Mac, and Apple TVs.
AirPlay works great most of the time. However, it does have its own share of issues. If you are facing any difficulties using the feature on your devices, the following fixes will help you sort out some of the common problems with AirPlay.
Fix 1. Same WiFi Network
You must make sure both of your devices are on the same WiFi network. If they are on different networks, you will not be able to use AirPlay with them.
Fix 2. Toggle WiFi and Bluetooth
Turn both WiFi and Bluetooth off on your devices. Then turn them on and see if that helps fix the issue.
Fix 3. Disconnect Multiple Devices
AirPlay only permits the use of one device at a time. If you are trying to connect multiple devices, do not do it.
Fix 4. Restart Your Router
It may be that your router has issues and so you are unable to use AirPlay. Small router glitches can be fixed by turning off and then turning on the router.
Fix 5. Update the Device’s OS
Older versions of the OS on your iPhone and iPad may cause issues with various features like AirPlay. Therefore, it is important that you keep your operating system version up to date on your devices.
Software Update
Software Update
Head into Settings > General > Software Update on your iOS device and get your device updated to the latest iOS version.
Fix 6. Disable Restrictions on Your Devices
Restrictions, as the word itself, says restrict what you can and cannot access on your devices. It may be that the feature is configured in such a way that it restricts the usage of AirPlay.
If that is the case, your best bet is to completely disable the feature on your iOS device. This can be done from Settings > Screen Time > Content & Privacy > Restrictions.
Fix 7. Restore Your Devices
If the issue still persists, you may be asked to restore your devices. You can do so using the iTunes app on your computer. Connect your iPhone or iPad to your computer, launch iTunes, select your device in the app, and click on Restore iPhone. Wait for it to finish restoring your device.
Restore your iOS device using iTunes
Also, keep in mind that mirroring the iPhone to an iPad without WiFi is not possible. So make sure to have an active WiFi connection to do the task.
Also Read: How to Disconnect an iPad from iPhone >
Bonus Tip. How to Screen Mirror iPhone/iPad to Computer Easily
If you want to display your iPhone/iPad screen on a computer, then, AnyMirror helps you finish it easily. Without any technical requirements, AnyMirror allows you to mirror your iPhone on your Mac/Windows PC with synchronized audio in high quality in just a few clicks. You can connect iPhone/iPad to a computer via Wi-Fi flexibly or a USB cable stably. What’s more, AnyMirror can make real-time recordings during mirroring or take screenshots. It can also help you stream your screens, audio, cams, and mics straight to YouTube, Zoom, etc.
Step 1. Get the latest version of AnyMirror on a Windows/Mac computer > Then search AnyMirror in App Store and tap GET to download it on your iPhone/iPad.
Select Function on AnyMirror
Step 2. Now, launch AnyMirror on the computer and connect your iPhone with a USB cable > Choose Screen Mirroring on your computer and tap on OK.
Choose Screen Mirroring On Computer
Step 3. Then, please also select Screen Mirroring mode on your iPhone > Select USB > Click the Start button >Click Start Broadcast button.
Choose Start Broadcast on iPhone
Step4. When your iPhone is detected successfully by AnyMirror, then you can go to any screen that you want to mirror to the computer.
Mirror iPhone Screen to Computer Successfully
Please make sure you’ve installed iTunes on the computer to help detect iPhone/iPad.
Many iPhone users wonder “can I mirror my iPhone to my iPad” and the answer to that question is yes. With some third-party apps, you can easily mirror one iOS device to another.
