How to Reset iPhone without Screen Time Passcode?
When you try to reset your iPhone, you may be asked for the screen time passcode. This post will demonstrate how to reset iPhone without Screen Time passcode. Besides, you will better understand what a Screen Time passcode is and learn how to reset the forgotten screen time passcode. The following guide should provide you with all the information.
Author Avatar Joy Taylor Last Updated: Apr. 11, 2023
AnyUnlock – Reset iPhone without Screen Time Passcode
Free download AnyUnlock to remove Screen Time passcode so as to reset iPhone without screen time passcode.
Recently, some iOS users responds that they were required to enter the screen unlock pin and screen time passcode when they tried to erase their iPhone or iPad device. Here came the question that many users fail to remember their screen time passcode, as a result of which, they couldn’t erase their device as they wanted.
Don’t worry! This post will tell you what to do if forgot screen time passcode. In the following guide, you are going to learn how to reset iPhone without Screen Time passcode and what to do if you forgot your screen time passcode. Besides, you will learn what your Screen Time passcode is by the end of the post.
Here are some more guides on screen time for you:
How to Turn off Screen Time without Passcode >
How to Hack Screen Time on iPhone >
To reset iPhone without screen time passcode, you can remove Screen Time Passcode first. Some iPhone users may seek to get rid of the forgotten Screen Time passcode via restoring from iTunes backups. This sometimes doesn’t work since the iTunes backup may cover the screen time passcode in it. Afterward, you’ll be required to enter the screen time passcode again when you try to reset your iOS device.
For these reasons, we highly recommend you use AnyUnlock – iPhone Password Unlocker. With this tool, you can unlock the Screen Time passcode without data loss. After that, you can factory reset your iPhone as you want. Despite unlocking Screen Time passcode, AnyUnlock also helps iOS users to unlock screen passcode, remove Apple ID/ iCloud accountbypass iCloud activation lock well on iPhone, etc. Check some of its main features below.
  • Bypass iPhone Screen Time Passcode of any kind in one click.
  • Remove Apple ID from iOS devices quickly and easily.
  • Bypass Remote MDM & remove Local MDM within simple steps.
  • Bypass iCloud activation lock and SIM lock easily.
Here are the steps to unlock the Screen Time passcode:
Step 1. Free download AnyUnlock and launch it on your computer. Connect your iPhone to the computer > Choose Unlock Screen Time Passcode on the right-up corner.
Choose Unlock Screen Time Passcode Mode
Step 2. Click on Unlock Now to start the unlock journey with AnyUnlock.
Click on Unlock Now
Click on Unlock Now
Step 3. AnyUnlock will back up your iPhone in case the data loss, and also it will encrypt the backup.
Unlock Screen Time Passcode Process
Step 4. After it finished the unlock work, you will see this page below.
Successfully Removed Screen Time Passcode
Now, AnyUnlock has successfully removed your Screen Time Passcode, and then you can reset your iPhone device.
Please make sure you do turn off the Find My Phone function if your iPhone is running in iOS 13 or higher. Encrypt your iTunes backup would be necessary as well.
Reset iPhone to Remove Forgotten Screen Time Passcode
Another way to successfully remove the forgotten Screen Time passcode on your iPhone or iPad is to reset your device. All you need to do is wipe off your device and it should reset the passcode for you on your device. However, there is a catch.
If you reset your iPhone or iPad, you are going to lose all the data stored on it including your photos, videos, apps, and so on. You will likely not want to do it if you have got your important data saved on your device. But there is still a way to do the task. What you can first do is get all the data transferred from your device over to your computer and then reset the device. That way you will be able to retain your data even if you fully reset your device.
Once the data is transferred, follow the following steps on how to recover a Screen Time passcode:
  1. On your Screen Time locked iPhone or iPad, launch the Settings app and tap on General followed by Reset. It will open the device reset menu on your screen.
  2. Tap on the option that says Erase All Content and Settings. It is to fully reset your device to the factory settings and to remove the forgotten passcode from your device.
  3. Follow the instructions shown on your screen to confirm the prompts and reset your device.
  4. When your device is fully reset, set it up as a new device. Remember, you cannot use any of your iTunes or iCloud backups as those will also bring over your Screen Time passcode with them.
Choose Erase All Content and Settings
That’s all there is to it. You may now transfer your data from your computer over to your device and your phone will be just like how it was before. You may also set a passcode for the Screen Time feature if you would like to do it. However, be sure to write it down somewhere so you do not need to reset your device to recover it ever again.
Reset Screen Time Passcode on iPhone
If you can access your Apple ID, then you will be able to reset your Screen Time passcode easily. This is useful when you have forgotten your screen time password or the screen time password of a member of your home share group.
  1. Head over to Settings from the home screen of your iPhone or iPad.
  2. In the settings menu, scroll down and tap on Screen Time.
  3. Then, scroll down and tap on Change Screen Time Passcode.
  4. Choose Change Screen Time Passcode to proceed further.
  5. Tap on Forgot Passcode?. This will take you to Screen Time Passcode Recovery.
  6. Now, you can enter your Apple ID login details and tap on OK to continue.
  7. Enter a new Screen Time passcode you like.
Reset Screen Time Passcode on iPhone via Find My
Deleting your iPhone without a screen time password via Find My iPhone is also a good way to do this. Follow the steps below.
  1. Go to Settings > Your Apple ID name > Find My > Find My iPhone and make sure Find My iPhone is turned on.
  2. Open the Find My iPhone app, click the Device tab and tap the iPhone you want to erase, and then choose Erase This Device.
  3. Tap Continue followed by Erase. Enter the Apple ID password and tap Erase again. The iPhone will immediately start erasing itself without asking for a screen time passcode.
Reset iPhone without Screen Time Passcode via iTunes
Finally, if none of the above solutions have solved your problem then you can try using iTunes for a last-ditch effort. This approach is the equivalent of using iTunes to restore your device. In this case, your iPhone will be restored to its factory settings and the iOS system will be upgraded to the latest version.
  1. Open iTunes and connect your iPhone to your computer. Note: Please make sure you turn Find My iPhone off.
  2. Find your smartphone in the iTunes interface. The phone icon is positioned in the upper left corner of the window.
  3. Select Summary on the left, and then click the Restore iPhone button on the right.
Restore the iPhone with iTunes
Restore Your iPhone with iTunes
FAQs About Screen Time Passcode
If you want to better understand what Screen Time passcode is as well as its benefits, you can continue to read. Also, we collect some users’ frequently asked questions by the end of the post.
Screen Time passcode is a passcode that you set up when you first use the Screen Time feature on your device. It is a combination of various digits that you need to enter each time you want to access the Screen Time feature on your iPhone or iPad. Using a passcode with the Screen Time feature has many benefits with regard to security. If you have enabled the passcode on your device, your device will only let you access the feature if you enter the correct passcode.
If you ever forget the passcode or someone else tries to access the feature with an incorrect passcode, they will be denied access and they will not be allowed inside until and unless they enter the correct passcode.
What is Screen Time Passcode
What Is Screen Time Passcode
Are There Some Default Screen Time Passcodes?
No, there is no default passcode for Screen Time on your iPhone and iPad.
The Screen Time passcode will be set when you use this feature for the first time.  If you have switched from an older version of iOS to the latest iOS 13, the feature does not ask you to set up a new passcode on your device. The passcodes that you used with the Restrictions feature on your older iOS version is now your passcode for the Screen Time feature.
How Many Times You Can Try Screen Time Password?
Unlike the main passcode on your iPhone, entering the Screen Time passcode incorrectly multiple times will not erase your device. Instead, you will be asked to wait for hours if you enter the passcode wrong a lot of times.
Enter Screen Time Passcode
  1. One minute to go if you enter an incorrect passcode six times.
  2. Five minutes you need to wait If you enter a wrong passcode seven times.
  3. Hours you will have to wait if you keep on entering the wrong passcode on your device.
It is human to forget things and if you ever forget your Screen Time passcode, the above guide should help you reset it on any of your iOS-based devices. We hope the guide helps you out when you need it the most. With the help of AnyUnlock, you can get through your Screen Time easily. Download AnyUnlock now!
