How to Remove Jailbreak with/without Restore?
Do you own an iPhone which is jailbroken? If you’re reading this article, then most probably, your answer will be a yes. But, if jailbreaking has given you a lot of problems with your device, then you must be looking for how to remove jailbreak from your iPhone. In this post, you’ll learn about two effective ways to do the same. Let’s start exploring!
Author Avatar Joy Taylor Last Updated: Aug. 27, 2024
Though iPhone comes with a reliable and stable operating system, but you can still face some serious issues with your device. One of the major issues that iPhone users face is when they jailbreak the device. Hence, they look for how to remove jailbreak from iphone.
Jailbreaking allows you to have a prime access to the iOS file system. It further enables you to download third-party applications and other updates on your iPhone that are not otherwise available in the App Store. In a way, it opens up new avenues in terms of what your iPhone can do.
Remove Jailbreak from iPhone
However, a lot of times, it can also create instability across the device, which ultimately can prevent you from receiving the latest iOS updates that come with useful features, security enhancements, and bug fixes.
Thus, you can consider removing jailbreak from your device as it is the only way to bring back your device to its normal state. Before we proceed with the ways to remove jailbreak without restore, let’s clear some basics.
Will Factory Reset Remove Jailbreak?
If you have taken the decision that jailbreaking is doing harm more than good for your iPhone, then you can come back to your iPhone’s original state by resetting it. Hence, returning the device to factory settings will end up deleting all the jailbreak features. But, it will end up deleting all the images, audios, documents, files, etc., stored on the device.
So, before you go any further and reset your iPhone, make sure that you check all the downloaded jailbreak apps and the data they contain. If you wish to keep its data, then make sure to back up your iPhone in advance. Wondering why? Simply because iTunes or Apple iCloud will not backup jailbreak apps. Hence, you can consider resetting your iPhone to remove jailbreak for the following reasons:
Now, let’s discuss some benefits of removing jailbreak from iPhone.
  • To continue updating your iOS device normally
  • To enhance its security
  • If someone has unknowingly jailbroken your iPhone to hack it
  • It ensures that your iPhone’s warranty doesn’t lapse
Now, let’s discuss some ways to remove jailbreak from iPhone with or without restore.
How to Remove Jailbreak from iPhone with Restore by iTunes?
There’s no point in arguing that jailbreaking your iPhone can cause some major issues. In some ways, it removes the security protection from the device that keeps it safe from any kind of virus infection or hackers. Moreover, it also voids the warranty of your iPhone. But thankfully, you can easily remove jailbreak from iPhone via using iTunes. Follow these instructions to do the same.
  1. Install the updated version of iTunes on your computer.
  2. Attach your iOS device to the PC and select your device when it appears in iTunes.
  3. Select the Summary tab and tap on the Restore iPhone option.
  4. Click on the Restore and update option when the prompt message appears.
  5. Once the reset process is finished, your iPhone will restart automatically.
It becomes crucial to highlight that restoring your iPhone will erase all the data, so make sure to take a complete backup first.
How to Remove Jailbreak from iPhone without Restore by iCloud?
If you don’t want to restore your iPhone but still want to remove jailbreak, then you can easily remove jailbreak without restore via using iCloud. However, to be on the safer side, it’ll be beneficial for you to take a backup of your device before you go ahead and follow the below-listed steps.
  1. Reboot your iPhone, enable the Find My iPhone from the Settings app, and ensure that Wi-Fi is turned on.
  2. Now, open icloud.com and sign in by using the correct email address and password and click on the Find iPhone icon.
  3. Tap on the All Devices option and select your jailbroken iPhone.
  4. From the following screen, tap on the Erase iPhone option.
That’s a wrap for how to remove jailbreak with and without restore. Now that you know jailbreaking isn’t a good option for every iOS device, make sure you do it at your own risk. However, with all the solutions mentioned above, you won’t find any difficulty in resolving the issue of removing jailbreak from the iPhone.
