Want to know more about chrome bookmarks recovery tool? And also want to know how to recover deleted Chrome bookmarks? Well, you’ll find 6 ways to recover Chrome bookmarks in this article.
Google Chrome is one of the most popular web browsers that supports great features. It has a sleek interface that enables you to conveniently browse your desired websites once you are connected to a stable internet.
This browser is well-known for its bookmark option, a feature that lets you create shortcuts to your favorite websites so you can quickly access them in future. Chrome bookmarks are often stored permanently, unless deleted. And when such happens, you can always recover the bookmarks without hassles.
Here, we will discuss the 6 official ways to retrieve deleted or missing bookmarks on Chrome without difficulty. Our guide will contain the various techniques for all PCs such as Windows, Mac and Linux. Continue reading!
Recovering Chrome bookmark on Windows, Mac and Linux is simple with the detailed instructions given down here:
Step 1: Run Windows File Explorer and enter this line: C:\Users\%username%\AppData\Local\Google\Chrome\User
A new screen should pop up with lots of folders. Type Bookmarks in the search bar and folders with corresponding names will appear.
Step 2: Mark all the folders, and drag-&-drop them in the appropriate place just as seen below:
Step 3: Next, download the HTML file that comes up. Look through the file for Chrome bookmark.
Note: Large sized HTML files are most likely the right file containing Chrome bookmarks.
Step 4: Once done, launch Chrome browser and click the Hamburger sign. Select Bookmark > Bookmark Manager.
Step 5: Now select the menu icon next to the search bar and tap on Import Bookmark.
Choose the HTML folder containing your bookmarks to import them on Chorme browser.
Step 1: At the top of your Mac screen, click Go > Go to Folder. Enter ~/Library/Application Support/Google/Chrome in the appropriate field and click Go.
Step 2: Next, input Bookmarks in the search bar to access bookmark folders. Several folders with similar names will come up.
Step 3: Highlight the folders, then drag-&-drop them in the space below:
`Once done, download the HTML folder. Check each HTML file via Chrome to see which one has your bookmarks.
Step 4: On Chrome browser homepage, click the Hamburger icon, and select Bookmarks to access the dropdown menu. Click Bookmark Manager to continue.
Step 5: Now tap on the menu icon next to the search bar and click Import Bookmarks. Choose the HTML file with your bookmarks and in no time, your bookmark will be restored.
Step 1: Launch the File Explorer tab on your Linux computer, and hold the hotkeys: Ctrl + L (if you use Linux Nautilus). Alternatively, you can enter ~/.config/google-chrome in the appropriate field.
Step 2: Type Bookmarks in the search bar. All folders labeled will automatically appear. Drag and drop each other folders into the space below:
Once done, download the corresponding HTML folder.
Step 3: Next, launch each HTML using Chrome to see which one has your bookmarks in it. Once found, click the Chrome menu icon, and select Bookmark from the options that shows.
Step 4: Now click Bookmark Manager and tap on the menu icon next to search bar. A list of options will immediately appear. Click Import Bookmarks and choose the HTML folder with your bookma
From Google History, you can easily bring back your deleted bookmark sites. But with the condition that you have your Google account logged in before deleting the bookmarks. This is because Google tracks and stores activities, including recently visited sites, executed by an account in Google History.
If you meet the precondition above, you can implement this solution. Check below for the corresponding instructions:
Restore Bookmarks via Google History
Chrome’s bookmark manager is a page on Google Chrome browser where all your favorite or bookmark sites are stored. The page contains both old and newly added website links. Should you mistakenly delete a website link from your Chrome bookmark, you can restore it via this page.
The procedure involved is very straightforward. With hotkeys Ctrl + Z (for Windows), or Cmd + Z (on Mac), you can quickly get back the lost or deleted bookmark sites. All you need to do is open the bookmark manager page and press the corresponding keys. These keys are programmed to undo your actions.
If the technique above doesn’t bring back lost or missing bookmarks on Chrome, we suggest that you restore bookmarks from backup. If you use Chrome on Windows device, you can quickly bring back those lost or deleted bookmarks following the procedure down here:
Step 1: Firstly, close Chrome browser, and launch Windows Explorer. Enter the following command In the search bar: C:\Users\NAME\AppData\Local\Google\Chrome\User Data\Default
Replace the character NAME with your Windows user account, and hit the Enter key.
Step 2: A new interface as below will come up:
Restore Bookmarks in Chrome from Backup
Locate the folders Bookmarks and Bookmarks.bak. Rename these folders as follows:
Bookmarks >>> another name of your choice
Bookmarks.bak >>> Bookmarks
Step 3: Once done, launch Google Chrome and check your bookmark manager. Chrome will load all the bookmarks from the corresponding backup folder. You should see all of the lost or deleted bookmarks on your screen without delay.
Did you recently update your Google Chrome browser and observed your bookmark sites disappeared? If so, DNS cache can help you restore them. Although effective, and cost free, this solution is quite technical.
Here is the tutorial steps to recover lost Chrome bookmarks with DNS cache:
Step 1: Hold the hotkeys Windows + R, and enter cmd in the space that appears. Hit the OK icon to proceed. Alternatively, you can enter cmd in the Windows search bar at the bottom left corner of your Windows display screen.
Step 2: When the command prompt opens, enter ipcongif /displaydns and tap on the Enter key. Without delay, all of the websites you visited in the past will pop up.
Use DNS to Find Lost Chrome Bookmarks
Step 3: Browse through the list and bookmark your favorite websites. Chrome will store the sites under bookmark again.
For folks using Chrome browser on Mac computers, you can retrieve bookmark pages via Time Machine. Time Machine is one of the most versatile features integrated into Mac computers to help track and create backup logs of all Mac files.
Time Machine is capable of bringing back lost or missing Chrome bookmarks on Mac. It does this for free. Follow the detailed procedure down here to recover Chrome bookmark on Mac:
Step 1: Turn on your Mac device and launch Finder. Scroll and select Macintosh HD > Users. Select your username from the list and click Library.
Step 2: Next select Application Support > Google > Chrome > Default.
Step 3: Now move the bookmark folders to another location just as seen below:
Recover Chrome Bookmarks on Mac with Time Machine
After that, rename the Bookmarks.bak folder as a bookmark file.
Are you looking for the best way to bring back deleted Safari bookmarks on your iOS device? Then PhoneRescue is a lifesaver designed to help you recover missing data on your iDevice without compromising your data.
This software can retrieve all iOS data types, including bookmarks, at a remarkably high speed. To recover data, it offers three data recovery modes to bring back iOS data; from iCloud backup, iTunes backup, and directly from the iDevice. So it’s extremely straightforward to use, and highly secure.
Apply the following steps to retrieve deleted Safari bookmarks with PhoneRescue:
Step 1. Open PhoneRescue for iOS on your computer, then plug in your iPhone or iPad. Choose and enter the “Recover from iOS Device” mode. Then click the right arrow to continue. (Here we take Recover from iOS Device for example).
Choose Recover from iOS Device under Data Recovery
Step 2. All data will be displayed, remember only to choose Safari History & Safari Bookmarks. Hit “OK” button to start scanning.
Choose Safari Data to Restore
Step 3. Preview and select the safari history and bookmarks you’d like to bring back. Then click Recover button at the bottom right corner of the screen.
Restore Missing Safari Bookmarks to your Device or Computer
Below, we have some frequently asked questions and the corresponding answers to help you understand this topic better. Look through:
Retrieving bookmarks after uninstalling Google Chrome from your PC isn’t a big deal. There are several approaches available for you to restore bookmarks on your computer.
Below we list all the approaches:
The instructions required to retrieve bookmarks after deleting Chrome are given in the article above.
Both Microsoft and Apple deserve accolades for the quality features tucked into their Windows and Mac computer systems respectively. These computer systems are well-built with smart AI that tracks, and records your web activities.
If you lose your Chrome bookmarks, and any web-related information on Windows or Mac computer, you can find the records in Windows Explorer and Time Machine respectively. Check the appropriate guide above to recover Chrome bookmarks on your computer.
Whether you recently bought a new device or wish to change your browser, you can export Chrome bookmarks with minimal stress. The instructions required are as follows:
In future, you can access the file via the destination folder you selected.
Regardless of the reason why you lost Chrome bookmarks on your device, you can retrieve them using the tutorial guide given in the article above. We showed six (6) power techniques to recover Chrome bookmarks, look through and select the one that suits you.
If you wish to recover bookmarks on Safari browser, you can count on PhoneRescue for iOS. The software retrieves Safari bookmarks on any iDevice without data loss. It’s lightweight, secure, easy to operate, and offers a budget-friendly subscription service.
