How to Mirror Your iPhone Screen to Mac [6 Methods]
For the question about how to screen mirroring your iPhone to Mac, this ultimate guide will provide you with a comprehensive solution.
Author Avatar Roger Smith Last Updated: Nov. 14, 2024
Have you ever thought about viewing iPhone screen on Mac? Generally, iOS users may want to mirror iPhone screen to Mac for various purposes: doing a business presentation on a bigger screen can make work much more efficient; playing games is more fun; sharing personal photos with friends and families and transferring videos from iPhone to Mac creates a warmer atmosphere, and watching movies on a larger screen must be a great experience.
In this guide, we will explore various methods to help you seamlessly show iPhone screen on a Mac. Let’s get started!
You May Like: How to Mirror iPhone to Windows/PC >
Wireless Screen Mirror iPhone to Mac with No Limits
The built-in screen mirroring feature for Mac and iPhone is AirPlay. But AirPlay isn’t compatible with all Mac models. If you want to mirror iPhone to Mac with an easy and accessible method, you can use AnyMiro.
AnyMiro focuses on iOS and Android screen mirroring. It supports mirroring your iPhone screen to Mac with a USB cable and WiFi connection without installing any receiver. You could take it as an alternative to AirPlay but with a better experience and powerful features.
AnyMiro Screen mirroring iPhone to Mac Steps:
Step 1. Download AnyMiro on your Mac, and enter the mirror iPhone/iPad tab.
Mirror iPhone to Computer
Step 2. Choose the WiFi connection model.
Step 3. Make sure your iPhone and Mac are connected to the same WiFi.
iPhone Connect the Same WiFi with Computer
Step 4. Access your iPhone’s control center, tap the screen mirroring icon, then choose your Mac from the device list.
Working as the alternative to AirPlay isn’t the only thing AnyMiro can do for you. Beyond simply mirroring your iPhone screen to your Mac, AnyMiro goes a long way in helping to enhance the live streaming experience.
What’s Good on AnyMiro?
There are many people who choose to mirror their iPhone screen to their computer, and then use streaming platforms to live stream the mirrored content. With AnyMiro, both your mirroring and live streaming experience can be better.
  • By making the projection effect more stable and smooth, AnyMiro makes your live broadcast process more steady.
  • AnyMiro ensures your screen always looks vivid and stunning with up to 4K resolution. If you want to live-stream your artwork from iPad to Mac, the color accuracy will remain consistent and true to the original device in your hand.
  • Nobody wants lag during screen mirroring, especially not for gamers. If you choose AnyMiro, the cast audio will automatically stream to both your computer and your fan’s view, just like game tracks.
You can also check this video guide on YouTube to see how AnyMiro works for iPhone screen mirroring.
How to Mirror iPhone Screen to Mac Using AirPlay
If both your iPhone and Mac are compatible with AirPlay, it is the most straightforward method to mirror your iPhone screen to your Mac. If you’re not sure whether your devices are compatible with AirPlay, check this chart below.
AirPlay System Requirement
Use the steps here to screen mirror iPhone to Mac with AirPlay:
Step 1. Ensure that your iPhone and Mac are connected to the same Wi-Fi.
Step 2. On your iPhone, swipe up from the bottom or the top of the screen to access the Control Center.
Step 3. Tap on the “Screen Mirroring” option and select your Mac from the available devices.
Access the Screen Mirroring option on the iPad
Access the Screen Mirroring Option
Step 4. Voila! Your iPhone screen is now mirrored on your Mac.
How to Mirror Your iPhone Screen to Mac with QuickTime
QuickTime Player is an extensible multimedia framework developed by Apple Inc., capable of capturing the screen of your iPhone, iPad, or iPod. You can capture exactly what you’re seeing on your iPhone. Or you can make a video recording of your Mac screen, for example, a video of a working demo, game reviews, photos slide show, and so on. It is the recommended built-in tool for Mac models that are not compatible with AirPlay.
This capability requires a USB cable. Mirroring Requirements for devices are:
  1. The Mac: macOS X Yosemite or later
  2. The iPhone: iOS 8 or later
Here are the STEPS:
  1. Connect your iPhone to your Mac with a USB cable.
  2. Open the QuickTime Player on your Mac.
  3. Click “File”, and choose “New Movie Recording”.
  4. Click the Options pop-up menu, then Choose Your Connected iPhone.
    Choose "New Movie Recording" and "Your Connected iPhone"
    Choose “New Movie Recording” and “Your Connected iPhone”
  5. The iPhone screen will now instantly display on the Mac.
    Successfully Mirroring Your iPhone Screen to Mac with QuickTime Player
  1. The default input device will be set to the built-in camera. To change it to your iPhone, click the Optionspop-up menu (down arrow next to the Record button). Then select your connected iPhone.
  2. When connecting iPhone to Mac, the Photos and iTunes are automatically launched. You can close those apps and continue the process.
iPhone Mirror to Mac with Reflector
To fix some Mac models that do not support AirPlay, one way is to use the QuickTime Player we have mentioned above, and the other way is to use an AirPlay receiver to make your Mac detectable. The Reflector is one of the most popular receivers for Mac.
This capability requires a Wi-Fi network. Mirroring Requirements for Devices are:
  1. An AirPlay receiver: Reflector
  2. The iPhone: iOS 7 or later
Here are the STEPS on how to airplay from iPhone to Mac:
Step 1. Make sure your iPhone and Mac are on the same wireless network.
Step 2. Download and launch Reflector on your Mac.
Step 3. Open up Control Center on your iPhone:
  • On iPhone X or later or iPad with iOS 12 or later: Swipe down from the upper-right corner of the screen.
  • On iPhone 8 or earlier or iOS 11 or earlier: Swipe up from the bottom edge of any screen.
Step 4. Tap the “AirPlay/Screen Mirroring”.
Step 5. Select your Mac from the list.
Step 6. If a code appears on your Mac, enter the onscreen code on your iPhone.
Step 7. The iPhone screen will now instantly appear on the Mac.
Mirroring Your iPhone Screen to Mac with Airplay
If you can’t enable AirPlay for iPhone, please:
  1. Make sure that your Mac is near the iPhone, try moving closer to it, and try again.
  2. Make sure that your Mac and iPhone are updated to the latest software version.
Brief Comparison among AnyMiro, AirPlay, QuickTime, and Reflector
Features AnyMiro AirPlay QuickTime Reflector
Platforms Android, iOS, Windows, Mac iOS, macOS macOS Windows, Mac
Wireless connection
Wired connection ✅(iOS devices)
Multi-device Support
Cross-platform Mirroring
Screen Annotation
Performance Excellent Excellent Excellent Good
Ease of Use User-friendly User-friendly User-friendly User-friendly
Price Freemium Free Free (macOS) Free trial, paid
Third-Party Apps to Mirror iPhone to Mac
There are also third-party apps that can handle the screen mirroring functions. You can check these recommended tools and see if you want to have a try.
1. Mirror Your iPhone Screen to Mac with AnyMirror
AnyMirror allows you to mirror iPhone to Mac with synchronized audio in high quality in a few clicks. You can mirror your iPhone screen to Mac both via Wi-Fi flexibly or via USB cable stably as you like.
Step 1. Free Download AnyMirror on your MacBook > Then search AnyMirror in App Store and tap GET to download it on your iPhone.
Select Function on AnyMirror
Step 2. Launch AnyMirror on the computer and connect your iPhone to Mac with a USB cable (You can also use Wi-Fi to mirror iPhone to Mac) > Choose Screen Mirroring on your computer and tap on OK.
Choose Screen Mirroring On Computer
Step 3. Select Screen Mirroring mode on your iPhone > Select USB > Click the Start button >Click Start Broadcast button.
Choose Start Broadcast on iPhone
Step 4. Now you can see your iPhone screen is on your Mac and you can go to any screen that you want to mirror to the computer. You can also record and capture the mirrored screen by using the tools at the top-right corner.
Mirror iPhone Screen to Computer Successfully
What’s more, AnyMirror is more than a mirror tool, it can satisfy almost all your needs about mirroring iPhone to your Mac. There are the main features of AnyMirror:
  • Multiple Mirror Sources – With AnyMirror, you can mirror multiple phones/ tablets with different screens, mics, audio, and cameras at the same time and you can freely arrange these mirrored screen sections as you like.
  • Auto Rotation and Zoom in – The mirrored screen on the computer will automatically rotate with the device screen between portrait and landscape. And you can freely magnify the screen or zoom out.
  • Record and Capture Screen – AnyMirror can make real-time recordings during mirroring or take screenshots.
  • Live Stream Screen & Audio  Live stream your screens, audio, cams, and mics straight to YouTube, or to conferencing software, like Zoom, Microsoft Teams, etc
  • Suitable for Multiple Scenarios – Meetings, Game Live Streaming, School Teaching, or Work Result Demonstration, AnyMirror will meet all various screen-casting needs and without special equipment requirements.
2. Mirror Your iPhone Screen to Mac with AnyTrans
AnyTrans is a comprehensive iPhone data management software, it provides you with a Free Screen Mirror tool for iPhone screen mirroring. Here are some of its main features:
  • It allows you to mirror the iPhone screen to Mac (or PC) with a click.
  • During the screen mirroring, you can also record or capture the screen.
  • In addition, it can help transfer all your iPhone data to another iPhone/iPad, or Mac/PC computer, and vice versa.
  • Also, it helps you back up your iPhone completely to protect you from unexpected data loss. And then you can restore them whenever required.
Mirroring your iPhone to Mac with AnyTrans requires a WiFi network. Requirements for Devices are:
  1. The Mac: macOS Catalina beta, macOS Mojave, macOS High Sierra, macOS Sierra, OS X 10.11, 10.10, 10.9, 10.8
  2. The iPhone: iOS 5 or later
Here are the STEPS:
Step 2. Download AnyTrans and launch it on your Mac.
Step 3. Click the Screen Mirroring option on the left navigation of the interface.
Screen Mirroring with AnyTrans
Step 4. Open up Control Center on your iPhone:
Step 5. Tap the AirPlay/Screen Mirroring button, and Choose the Name AnyTrans_XXX (your computer name).
Tap the “AirPlay/Screen Mirroring” Button and Choose the Name AnyTrans_XXX
Step 6. The iPhone screen will now instantly display on the Mac.
Successfully Mirroring Your iPhone Screen to Mac with AnyTrans
Having problems with turning on Wi-Fi on your computer and iOS device, learn how to connect your iPhone and Mac to the same Wi-Fi.
FAQs on Mirroring Your iPhone to Mac
Why Mirror Your iPhone to Mac
Imagine what sharing your iPhone screen on your Mac can do for you. Integration between two devices allows you to easily multitask, collaborate and enjoy a more immersive experience. Here are a few scenarios where mirroring iPhone to Mac proves to be very useful:
  •  Presentations and Demos: Showcasing your iPhone’s screen on a larger Mac display can enhance your presentations, making it easier to engage with your audience and highlight key features.
  •  Content Creation: Whether you’re a vlogger, gamer, or content creator, mirroring your iPhone screen to your Mac enables you to capture high-quality footage or screenshots for editing and sharing purposes.
  • App Development and Testing: Developers can mirror their iPhone screen to their Mac for streamlined app development and thorough testing, ensuring optimal performance across different devices.
What system is the latest iPhone Mirroring feature for Mac computers compatible with?
It’s included with macOS Sequoia 15 or later.
Why is my screen sharing not working on Mac?
Here are 7 steps to troubleshoot:
  • Activate Screen Sharing and Recording Permissions: Ensure that screen sharing and recording access are enabled on your Mac.
  • Access with Admin Rights: Log in to your Mac using an Administrator account to have the necessary permissions for screen sharing.
  • Sync Wi-Fi Networks: Verify that both your iPhone and Mac are connected to the same Wi-Fi network for seamless screen sharing.
  • Adjust Display Sleep Settings: Prolong the display sleep timeout settings on your Mac to prevent the screen from turning off during screen sharing.
  • Update and Reboot: Keep your AirPlay app or Mac up to date, and restart it to fix any glitches affecting screen sharing.
  • Modify Firewall Settings: Check and adjust your firewall settings to allow screen sharing activities.
  • Reach Out to Support: If all else fails, reach out to Apple Support for further assistance.
Today, most people own more than one electronic product to entertain life. Screen mirroring iPhone to a bigger screen is one of the digital entertainment lifestyles. Once you’re screening your iPhone to Mac, you can fast control your media on your iPhone. Remote handling the functions and enjoying the bigger screen must be a unique experience provided by screen mirroring. Without further ado, just get the latest version of AnyMiro and have a try!
AnyMiro – Real-Time Screen Mirroring Tool
Work for iMobie team for 5 years as well as an Apple fan, love to help more users solve various types of iOS or Android related issues.
