How to Screen Mirroring iPad to PC/Mac
Screen mirroring on an iPad is possible thanks to a built-in feature on the device. This feature lets you mirror your iPad screen to various devices and that is exactly what we are going to check out in the following guide.
Author Avatar Roger Smith Last Updated: Sep. 22, 2023
An iPad is actually a larger version of the iPhone but people prefer it more for their commercial tasks. If you have an iPad, you likely draw things on it, create presentations, and so on. Although the screen on an iPad is really large and good for viewing items, sometimes you may want an even larger screen to view content, especially for viewing your presentations. Or, you want to share your live-streaming process of making painting creations on the iPad with others.
This is where the iPad mirroring comes into the picture. It allows you to show the contents of your iPad screen on a large screen of your computer. It should work on both Windows as well as Mac machines so you can use it regardless of what computer you have. Just keep reading for more details.
Further Reading: How to Mirror iPhone to Windows/PC >
Screen Mirroring iPad to Mac with AirPlay
What makes screen mirroring possible and easier on an iPad is a feature called AirPlay. It is built right into your operating system so you do not need to download or install it on your device. Once you invoke the feature, it lets you stream your screen to any other AirPlay-enabled device.
Your Mac, on the other hand, does not have built-in support for AirPlay. However, that does not mean you cannot mirror your device to it. You are going to need to install an app on your Mac that will add AirPlay support to it.
Let us take a look at how to AirPlay from an iPad to a Mac machine:
Step 1. Connect both your Mac and your iPad to the same WiFi network. This is the only way to use AirPlay and mirror your device’s screen.
Step 2. Head over to the Reflector website and download and install the app on your Mac. Launch the app but there is not anything to be configured. Just leave it as is.
Step 3. After installing the app, get back to your iPad and swipe down from the top-right corner of your screen. You will reveal the Control Center. Tap on the option that says Screen Mirroring in the list.
Access the Screen Mirroring option on the iPad
Step 4. The following screen lists all the AirPlay-enabled devices available on your network. Choose your Mac from the list by tapping on it.
You will instantly see your iPad being mirrored to your Mac machine. Any actions you perform on your iPad will instantly reflect on the screen of your Mac.
Further Reading: How to AirPlay No Sound Issues >
How to Share iPad Screen to Computer
If you fail to use Airplay to mirror your iPad to your computer, why not try a powerful iPad/iPhone mirroring tool? AnyMiro allows you to mirror your iPad on your Mac/Windows PC without technical requirements. And as we know, Apple does not support the use of airplay to mirror your iPhone to a Windows computer. So, if you want to share your iPad screen with a Windows computer, you must need AnyMiro. These are the reasons why:
  • AnyMiro supports mirroring all iOS devices and works well on both Windows and Mac computers and both WiFi and USB connections.
  • It will automatically sync the background audio and video of your iPad with timestamp adjustment.
  • AnyMiro provides the best screen mirroring experience ever. Supporting 10+ hours of a stable connection, a fast response time within 10 ms.
  • What’s more, AnyMiro allows you to integrate with popular streaming tools such as OBS and Streamlabs.
AnyMiro – Real-Time Mirroring Tool
Free download AnyMiro to mirror your mobile phone’s screen to a bigger monitor
Step 1. Download and run AnyMiro on your computer.
Step 2. Select mirror iPhone/iPad to enter iPhone mirroring.
Mirror iPhone/iPad to Computer
Step 3. Connect your iPad to PC or Mac with a lightning cable.
Mirror iPhone/iPad with USB
Step 4. Tap “Trust” on your iPad, and wait a few seconds, you can see the screen on the computer.
Trust Your Computer on iPhone
You can also mirror your iPad to your computer using a WiFi connection. Just remember to make sure the iPad and the computer are connected to the same WiFi.
Mirror iPad Screen to a Windows PC
If you want to mirror your iPad screen to a PC that runs Windows, you are also going to need to install an app on your computer. Windows machines do not have AirPlay support by default but a third-party app should help you add it.
While there are many apps that will let you do the task, we are going to cover how to use X-Mirage to do the task.
Step 1. Head over to the X-Mirage website and download and install the app on your PC. Launch the app when it is installed but you do not need to configure anything in it.
Step 2. Assuming both your PC and iPad are connected to the same WiFi network, swipe down from the top-right corner of your iPad to reveal Control Center. Tap on Screen Mirroring in the list and select X-Mirage.
Step 3. Select X-Mirage from the list of available devices.
Use X-Mirage as an AirPlay receiver on a PC
You are all set. Your iPad screen will be quickly mirrored to your Windows PC. Thanks to X-Mirage, you can now view your iOS device’s contents on the large screen of your PC.
Also Read: How to Mirror My iPhone to iPad >
Mirror iPad Screen with AnyTrans
If you have used the apps mentioned above yourself, you might have noticed they are quite old and do not have any modern features. They get the job done but are not really fun to work with.
Enter AnyTrans, a cool new modern app that helps you both manage your iOS device’s content as well as mirror your iPad screen to your computers. It is available for both Windows and Mac machines and it works like a charm on both machines.
Here we take a look at how you use the AnyTrans app to mirror your iPad screen to your PC or Mac machine. Please make sure both your iPad and your computer are on the same WiFi network.
Step 1. Download and install the AnyTrans app on your computer. Launch the app once it is installed.
Step 2. Click on Screen Mirroring in the left sidebar of the app on your computer.
Screen Mirroring with AnyTrans
Step 3. Reveal the Control Center on your iPad by swiping downwards from the top-right corner. Tap on Screen Mirroring and then select AnyTrans from the devices list.
Select AnyTrans on the iPhone to mirror screen to your PC
Your iPad will connect to your computer and you will see the iPad screen on your machine.
How to Enable AirPlay on Your iPad
Enabling AirPlay on an iPad is a piece of cake. All you need to do is tap on an option on your device and you are all set.
Here is how to enable and use AirPlay on iPad:
Step 1. Open the Control Center on your iPad. On old iPads, you need to swipe upwards from the bottom of your screen. On new ones, you can swipe downwards from the top-right corner of your iPad’s screen.
Step 2. Tap on the Screen Mirroring option. Then select the device you want to mirror your screen to.
That is all there is to it. Your iPad screen is now being mirrored to your chosen AirPlay-enabled device.
Sometimes you may need to mirror your iPad’s screen to your Mac or Windows PC. Learning how to do it is really handy and is quite easy as well as shown in the above guide.
Work for iMobie team for 5 years as well as an Apple fan, love to help more users solve various types of iOS or Android related issues.
