How to Reset Restriction Password on iPhone?
Do you know how to reset restriction password on iPhone? If you don’t know, just read this post to get some tips to make it.
Author Avatar Joy Taylor Last Updated: Nov. 15, 2023
AnyUnlock – Remove/Reset Restriction Password iPhone
Free download AnyUnlock to 1-click unlock and reset the Restriction passcode on iPhone.
The main purpose of Restrictions on iPhone is to block certain apps or functions on your iPhone to prevent others from accessing. Sometimes, in order to offer more security to the iPhone, you might set a complex passcode. But as time goes by, you may forget restriction passcode on iPhone. Besides, there are many other reasons that might require you to reset or turn off the Restriction passcode iPhone.
Restriction Passcode iPhone
No matter what are the reasons, if you are wondering about how to reset restrictions passcode, this guide will offer you proven ways. If you can remember the previous restriction password, you can easily reset it via Settings. However, what if you forgot restrictions passcode on iPhone or iPad? In this post, we will also offer 4 ways to reset restrictions passcode on iPhone/iPad without password. Continue to read and find a solution that is feasible for you.
What Is Restrictions Passcode on iPhone?
The Restrictions password prevents restrictions settings on your phone from being changed or disabled. You can turn on the password under Restrictions when you go to the Settings app. When turned on, it prevents people you want blocked (e.g. children, employees, etc.) from accessing settings.
But sometimes, you may encounter a situation where the restrictions passcode is incorrect after updating iOS, in which case you can try entering the default restrictions passcode, which is 1234. if that fails then try something else!
How to Reset Restrictions Passcode on iPhone?
To reset Restrictions passcode on iPhone without computer, normally you can make it via Settings. This method requires you to enter the old passcode you seek to reset.
  1. Go to your Settings > General > Restrictions, enter your passcode.
  2. Tap on “Disabled Restrictions”, then enter your existing passcode again.
  3. Tap on “Enable Restrictions” and enter a new passcode twice.
How to Reset Restrictions Passcode on iPhone without Password?
If you forgot restrictions passcode on iPhone, you cannot reset it via Settings. However, if you’ve chosen the right tool, you can also reset it on your own. In this part, we will show you how to reset restrictions passcode on iPhone without password. Generally speaking, you need to unlock or remove the old restrictions passcode so as to reset it as a result.
You’d better back up your iPhone to iTunes or iCloud before setting the passcodes because some methods will erase existing iPhone data when you removing the old restrictions passcode.
Way 1. Reset Restrictions Passcode on iPhone without Data Loss
The default way of resetting restrictions passcode requires you to factory reset your iPhone. And this will erase existing data on your iOS device and fail to satisfy most iOS users’ needs. Therefore, first of all, we’d like to introduce how to reset restrictions passcode on iPhone without password or data loss. We highly recommend you use the professional passcode unlock tool, AnyUnlock – iPhone Password Unlocker. It provides several iOS passcodes issue solutions. With this software, you can remove and reset Restrictions passcode easily and quickly. See what other things it can do below.
AnyUnlock – Unlock/Reset Restrictions Passcode
  • Remove Restriction (Screen Time Passcode) without data loss.
  • Remove the iPhone screen password with simple clicks.
  • Bypass MDM lock and iCloud activation lock with ease.
  • Save users from SIM lock.
Step 1. Download AnyUnlock on your computer and install it. Launch the app and click on the Unlock Screen Time Passcode option.
Choose Unlock Screen Time Passcode Mode
Step 2. Connect your iPhone to your computer using a USB cable. Once your iPhone has been recognized, please click on the Unlock Now button to begin the process.
Click on Unlock Now
Click on Unlock Now
Step 3. AnyUnlock will backup your iPhone automatically. Please wait for it to remove the password from your iPhone.
Unlock Screen Time Passcode Process
Step 4. Minutes later, you’ll see Screen Time passcode removed successfully page.
Successfully Removed Screen Time Passcode
You have to turn off the Find My if your iPhone is working on iOS 13 or later.
Way 2. Reset Restrictions Passcode on iPhone via Factory Reset
By factory resetting your iPhone, you can easily and quickly remove all iPhone settings, including the Restriction password iPhone. After that, you may need to restore iPhone backup. Now, you can follow the step-by-step guide to make it.
1. Go to Settings on your iPhone.
2. Tap General in the Settings.
3. Scroll down to find Reset, just tap it.
4. Choose Erase All Content and Settings.
Remove Restriction Code on iPhone via Factory Reset
After that, your iPhone is reset up as a new one. Also, the restriction passcode iPhone is reset.
You May Also Like: How to Recover Deleted Files from iPhone with/without Backup >
Way 3. Reset Restrictions Passcode on iPhone via iCloud
Apple provides Find My to secure the iPhone/iPad information. Once you lost your device, you can erase the device data via Find My through iCloud remotely.
  1. Go to iCloud.com and sign in to the iCloud with Apple ID & passcode.
  2. Click on the Find My iPhone icon.
  3. Tap on the option All Devices and then chose the device you want to erase.
  4. Click Erase iPhone/iPad.
When you finish these steps above, you can wake up your device and then enter your Apple ID and passcode to reset whatever you want to reset.
Way 4. Reset Restrictions Passcode on iPhone via iTunes
After removing the old Restriction passcode, you may set a new one with iTunes following the steps below.
  1. Connect your iPhone to the computer and launch iTunes.
  2. Select your iPhone (your iPhone’s name) from the top left menu.
  3. Click on Restore iPhone.
Reset Restriction Code on iPhone via iTunes
4. You will be warned that all your data will be erased. Click on Restore again to confirm.
Click Restore to Reset Restriction Code on iPhone
5. After restoring, you can set your iPhone from scratch. Now, you can go to Settings > Screen Time > Turn on Screen Time to reset a new Restriction passcode.
That’s all about how to reset the Restriction passcode on iPhone. If you have any other problems, you can leave your comments below, we will try our best to help you out. If you have mastered the skill of resetting the Restriction passcode, then just download AnyUnlock to reset it right now!
