5 Ways to Reset iPhone without iCloud Password [2025]
If I forgot my iCloud password, how to reset iPhone? Don’t worry. The guide below will provide several easy methods to show you how to reset iPhone without iCloud password in an easy manner.
Author Avatar Joy Taylor Last Updated: Mar. 14, 2025
Read in: Read This Article in
Deutsch
AnyUnlock – Reset iPhone without iCloud Password or iTunes or iCloud
If you forgot your iCloud password, AnyUnlock – iPhone Password Unlocker helps quickly factory reset iPhone without iCloud password or iTunes or iCloud in minutes. No skills are required. [iOS 18 Supported]
How to Erase an iPhone without Apple ID
I have an old iPhone and don’t have to Apple ID to erase info to give phone away. How can I reset?
–Apple Community
If you want to donate or resell your old iPhone, you won’t wish any possibility of personal info leaking. Or if you buy a secondhand iPhone, you may need to reset it. Or you need to reset iPhone to fix some faulty settings on your iPhone. By resetting your device, you will erase all data on your device, including settings, apps, accounts, music, images, videos, etc.
Normally, you can go to iCloud to factory reset your iPhone. But this method can’t be used if you forgot iCloud password or Apple ID password.
Then, can I factory reset my iPhone without iCloud password? The answer is an absolute YES. In the following guide, we will show you how to reset iPhone without iCloud password. Notably, these methods are applicable to all iPhone models, including iPhone 16/15/14/13/12/11/X, etc.
Want to reset Apple Watch as well? Just read this guide on How to Reset Your Apple Watch without Apple ID >
#1. How to Reset iPhone without iCloud Password in Minutes-AnyUnlock
How to factory reset iPhone without iCloud password? If you forgot your iCloud password or Apple ID password, you can also use AnyUnlock – A Complete iPhone Password Unlocker to reset iPhone without iCloud password/Apple ID. With the help of AnyUnlock, you can factory reset iPhone in only 3 simple steps without entering the password. After resetting, you can remove the old iCloud account or Apple ID and create a new one to enjoy your device and its services as you like.
Before resetting iPhone, make sure you have a local backup of the iPhone to avoid any data loss if necessary.
In addition, this one-stop iOS unlocker can also help you unlock iOS screen lock, bypass iCloud activation lock, remove iTunes backup encryption, bypass MDM, etc.
  • Factory reset iPhone without iCloud password or Apple ID in seconds.
  • 1-Click remove Apple ID/iCloud account from the iOS device.
  • 100% secure and no data and privacy leakage risks.
  • Supports all iPhone/iPad models and iOS versions. [iOS 18]
Here you can follow the steps below to learn how to unlock iPhone without iCloud password. And your iPhone will be reset as well.
Steps to Reset iPhone without iCloud Password in Clicks:
Step 1. Select Unlock Apple ID Mode
Free download the latest version of AnyUnlock on your computer. Launch it and the homepage will be displayed as below. Then select the Unlock Apple ID option to get started.
Click Unlock Apple ID from the Homepage
Step 2. Connect iPhone and Click Unlock Now
Connect your iPhone to a computer via a USB cable and click Unlock Now button from the interface below. Then AnyUnlock will remove Apple ID automatically. Please do not disconnect your device until it restarts. Meanwhile, please don’t use your device or launch iTunes during removal.
Click Unlock Now Button
Step 3. Remove Apple ID and Reset iPhone
When the removal process is completed, you will see the interface below.
Apple ID Removed Successfully
  • After the Apple ID gets removed successfully, please DO NOT “Erase All Content and Settings” on the device or restore the device with iTunes/iCloud.
  • If you have enabled Find My iPhone feature or if your iPhone is running iOS 11.4 and above, you are expected to take further steps to remove Apple ID.
#2. How to Reset iPhone without iCloud Password via iTunes
“If I forgot my iCloud password, how to erase iPhone without iCloud password?” If you have synced your iPhone with iTunes, you can use recovery mode to factory reset iPhone without iCloud password.
However, if the “Find My iPhone” feature is enabled on your device, your iPhone will be stuck at the iCloud activation lock page after the resetting process, as it needs the iCloud password to set up your iPhone. Also, this way is very time-consuming. So please disable Find My iPhone feature on your device and follow the guide below to reset and unlock iPhone without iCloud password.
Steps to Reset iPhone without iCloud Password with iTunes:
Step 1. Connect your iPhone to your computer via a USB cable, and open iTunes.
Step  2. Force restart your iPhone with the Volume buttons
Step  3. Click Restore when you see the Restore or Update screen.
How to Reset/Erase iPhone without iCloud Password via iTunes
#3. How to Reset iPhone without iCloud Password via Settings
How to factory reset iPhone without iCloud? To reset or erase iPhone without iCloud password, you can try to finish the task from Settings.
But it requires you to disable Find My iPhone feature on your iPhone. In addition, it will ask for a restriction passcode if you have set up your iPhone with one. If you meet these two conditions, then you can follow the steps below to learn how to reset iPhone without iCloud password.
Step 1. Go to “Settings” on your iPhone > “General” > Scroll down and choose “Reset”.
Step 2. Choose “Erase All Content and Settings” > Enter your passcode if it is prompted, tap on “Erase iPhone” to confirm.
How to Factory Reset iPhone without iCloud Password via Settings
#4. How to Reset iPhone without iCloud Password via iOS Repairer
Finding another time-saving way to reset iPhone without many limitations,  PhoneRescue for iOS can be the most ideal choice to do the job. PhoneRescue for iOS is a comprehensive and 100% safe iOS device manager and repairer that has helped millions of users reset iPhone iPad successfully, even without any password.
More importantly, PhoneRescue for iOS makes the complicated reset process as plain as 1 simple click. It just takes you a few minutes to finish the entire process. Besides that, it helps you fix various annoying iPhone errors effortlessly, like iPhone running slowly, getting stuck on a black screen, white screen, and Apple logo, or even in restarting loop. It is also capable of recovering lost files on iPhone or iPad as well.
Now, Free Download PhoneRescue for iOS on your computer first, and then follow the simple steps below to learn how to reset an iPhone without iCloud password.
Step 1. Connect your iPhone to the Computer
Run PhoneRescue > Connect your iPhone to your computer with a USB cable > Click on Repair iOS Systems mode > Click on Right Arrow at the bottom right corner to continue.
How to Reset/Erase iPhone without iCloud Password – Step 1
Choose Repair iOS System
Step 2. Choose the Reset Mode
Choose Advanced Mode, your iOS system will be updated to the latest version and all device data will be completely erased.
If you choose Standard Mode, it will repair your iOS system and the data on your iPhone won’t be erased.
How to Reset/Erase iPhone without iCloud Password – Step 2
Choose Standard Mode to Erase iPhone
Step 3. Enter Recovery Mode.
Follow the on-screen to enter your device to Recovery Mode. If the access failed, try again.
How to Reset/Erase iPhone without iCloud Password – Step 3
Enter Recovery Mode
Step 4. Download the Firmware Package
After entering Recovery mode, click the “Download” button to download the firmware for your device. It will take a few minutes to download the package.
How to Reset/Erase iPhone without iCloud Password – Step 4
Download a Matching Firmware
Step 5. Reset/Erase your iPhone
Once the download completes, it will reset your iPhone to factory settings automatically. Do not disconnect your iPhone until it restarts.
How to Reset/Erase iPhone without iCloud Password – Step 5
Restoring iPhone
#5. How to Reset iPhone without iCloud Password in 1 Click-AnyFix
To reset iPhone without iCloud password, here is another tool that can help you: AnyFix – iOS System Recovery. It provides you with two reset modes to fulfill all your demands. So you can use this tool to reset your iPhone/iPad/iPod touch in 1 click, whether you forgot iCloud password or screen passcode.
And AnyFix is also designed to revive your Apple devices, including fixing 150+ system issues for iPhone/iPad/iPod touch/Apple TV, fixing 200+ iTunes errors, upgrading and downgrading to any iOS versions as you wish, enter/exit Recovery Mode with ease.
Please note that reset iPhone will erase all data and settings on your device you need to back up your device data in advance. Then, you can follow the steps below to resolve how to factory reset iPhone without iCloud password.
Here is how to reset iPhone without iCloud password in 1 click:
Step 1. Free download and install AnyFix on your computer and launch it by double-clicking the icon. Connect your iPhone with a USB cable and choose Reset Device from the homepage.
AnyFix Reset Device Option
Step 2.  Then you will see the interface below. Choose 1-Click Reset since you can unlock the iPhone screen and tap on Reset Now.
Choose 1-Click Reset if you Can Unlock your Device
Step 3. Follow the guide on the screen to put your device into recovery mode. Then click Download to get the firmware for your iPhone. Then AnyFix will start to reset your iPhone. Please wait for a while.
 Reset Completed Page
Frequently Asked Questions
In addition to the methods for how to factory reset iPhone without iCloud password, here are some other related questions. To seek the answers, just read on.
Q1. How to erase iPhone without Apple ID?
It is not as difficult as you think to erase iPhone without Apple ID. You can try the traditional way – iTunes – to reset it. Or you can also choose AnyUnlock, an easier way, to reset your iPhone without Apple ID within simple steps.
Q2. How to sign out of iCloud without password?
As is known to all, you cannot sign out of iCloud if you don’t know the password for it. But what if you forgot the password or bought a secondhand iPhone linked to an unknown iCloud account? One solution to this problem is to sign out of iCloud by using Settings. However, it does not always work. To make it more quickly, AnyUnlock is also a good choice for you, because it can help you remove your iCloud account or Apple ID with ease.
Q3. How do I hard reset my iPhone manually?
To manually hard reset your iPhone, follow these steps based on your model:
iPhone 8, SE (2nd gen) & later: Quickly press and release the “Volume Up” button, then the “Volume Down” button. Press and hold the “Side” button until you see the Apple logo.
iPhone 7 & 7 Plus: Press and hold the “Volume Down” and “Power (Side)” buttons together until the Apple logo appears.
iPhone 6s, SE (1st gen) & earlier: Press and hold the “Home” and “Power (Top/Side)” buttons until the Apple logo appears.
This won’t erase data but helps fix minor issues like freezing or unresponsiveness.
That’s all about how to reset iPhone without iCloud password. And to factory reset your device quickly and easily, AnyUnlock will do you a big favor. You can free download AnyUnlock to have a try. And if you meet other trouble while factory resetting iPhone without an iCloud password, leave them in the comment section below and we will reply to you soon.
