If you want to make your group chat special and remarkable, you can give it a customized name. Don’t know how to name it? Here in this post, we will show you how to name a group text.
Apple released its revolutionary new iOS system, iOS 18, in September 2024. Now, more and more users are getting used to the new iOS system and enjoying its new features.
Name a Group Text on iPhone/iPad
Speaking of iOS 18 new features, the iMessage has some exciting updates, including enhanced text formatting, animated text effects, etc. With the powerful and funny updates of iMessage, the need for naming a group text on iPhone is increasing. However, some users don’t know how to customize a group chat name. Don’t worry, here in this post, we’d like to show you how to name a group text on an iPhone.
If you want to name a group text, first of all, you need to start a group chat, which means sending a message to all of the group members, otherwise, you won’t see “Enter a Group Name” at all. To do this, open your Messages app, and tap on the edit button in the upper right corner. Tap on the “+” button to add contacts. Then enter your message and tap to send. Then, you can follow the steps to name a group text on iPhone.
1. Open the Messages app, then tap on the group chat you want to rename.
Starting a Group Message on iPhone
2. Tap the top of the conversation, then tap on the “i” info icon. Tap on to enter a Group Name. (If you don’t see the option, there is likely a group member who is not using iMessage.)
Enter a Group Name
3. Enter the new name, then tap on Done to confirm.
If you are using iOS 11, and also have this question about how to name a text group on iPhone, we’re sorry to tell you that this function can’t be supported in iOS 11 anymore.
Before using iMessage, please make sure you have turned on the iMessage on your iPhone.
Your text messages might contain a lot of important information and memorable conversations. Here we would like to recommend a backup tool – AnyTrans, an all-in-one data manager for your iOS device. It allows users to back up iPhone text messages to their computers seamlessly. Unlike iTunes or iCloud, AnyTrans supports previewing every single piece of data in your backups before transferring, making sure you can restore the right backup. It can back up more than just text messages, also including emojis, voice recordings, etc. With this tool, you can also transfer photos and videos from an iPhone to a computer to save your life memories.
Main Benefits of AnyTrans:
Here are steps to backup iPhone text messages to a computer with AnyTrans:
Step 1. Free download AnyTrans on your computer. Launch it and connect your iPhone to it.
Step 2. Find the Message in the upper right corner of the main interface, and click to start to manage.
Click Messages in AnyTrans
Step 3. Select the text messages you want to save to the computer, then click the To Computer button. AnyTrans will start to transfer the content to your computer.
Select and Transfer Messages to Computer
Then your text message from your iPhone will be transferred to the computer without any omissions.
There might be different reasons why you cannot name a group text on your iPhone:
If you’re having trouble creating a group message on your iPhone, check if your iMessage is disabled. It would be best if you made sure participants are all iPhone users. Besides, your iOS version may be outdated to support the function, so updating your iOS version might work.
That’s all about how to name a group text on iPhones. Hope you can create a unique name for your group chat successfully. If you want to have full control over your iPhone, AnyTrans is a great choice. With its fast backup process and easy steps, you can transfer data from iPhones to computers effortlessly. Free download AnyTrans now to enjoy the three-day free trial!
