How to Mirror iPhone to PC with Easy Methods
Mirror iPhone to windows 10 allows you to view the content of your iOS device on your computer screen. There are various ways to do it and our guide below covers 5 ways to do screen mirroring from iPhone to PC.
Author Avatar Roger Smith Last Updated: Aug. 28, 2024
Read in: Read This Article in
Italiano
In today’s connected world, sharing content across devices is a common action. Whether sharing your latest photo, demoing a presentation, or just wanting to use your favorite apps on a bigger screen like iPad or MacBook, knowing how to mirror your iPhone to your PC is an invaluable skill. AirPlay has made screen mirroring iPhone on Mac a painless operation. But Windows computers do not support AirPlay, that’s why you need this article. This article will introduce you to various methods on how to mirror iPhone screen to PC, and also introduce some common problems that users may encounter during the process.
Further Reading: How Can I Mirror My iPhone to iPad >
What Does It Mean to “Mirror” an iPhone to a PC?
In simple terms, mirroring your iPhone to your PC free means showing your iPhone screen on your PC monitor. This feature allows you to share exactly what’s on your iPhone’s screen with your PC, making it easier to view content, demonstrate processes, or manage applications from your computer.
To share an iPhone screen on a PC, there are two methods, one is to use WiFi, and the other is to use a USB cable. No matter what method you prefer, software that can help you make a connection between your iPhone and the PC is necessary. There are several tools you can use to mirror your iPhone to your PC, each with its own pros and cons. Let’s explore the most popular options.
[Light & Easy] How to Mirror iPhone to PC with AnyMiro
Screen mirroring iPhone to PC has no longer been a difficult task with the help of a mirroring app. But what makes a screen mirroring app stand out is more related to the experience it provides during screen mirroring. For example, whether the screen mirroring app provides a smooth and high-quality mirroring, and whether the tool supports audio mirroring. AnyMiro, as one of the lightest and most stable screen mirroring tools, is the one you can rely on.
What’s Good About AnyMiro?
AnyMiro took a big step to improve the screencasting experience because it realized that screencasting is now closely related to live streaming. More and more people use screen mirroring apps to mirror their mobile games or Procreate footage to their computer, then use a streaming platform such as OBS or Streamlabs to start a live stream on Twitch or YouTube.
The Main Features of AnyMiro:
  • Easy to Use: AnyMiro makes mirroring your iPhone to PC an easy and simple process. It is straightforward and intuitive, requiring minimal setup or technical knowledge to let you connect and mirror two devices.
  • No Delay and Lag: With the USB 3.0 technology and AirPlay protocol compatibility, AnyMiro has managed to make the screen mirroring more smooth and responsive, thus promising a no-delay experience.
  • Support Audio-Video Sync: AnyMiro not only supports mirroring audio from iPhone to PC but also supports automatically synchronizing the audio and video.
  • Connect with Live Stream Tools: With AnyMiro, you can easily mirror screens to 20+ live streaming tools like OBS, and Streamlabs.
Here’s how to mirror iPhone to PC with AnyMiro, both video and text guides are available.
Step 1. Download and run AnyMiro on your computer.
Step 2. Select mirror iPhone/iPad to enter iPhone mirroring.
Mirror iPhone to Computer
Step 3. Connect your iPhone to PC with a lightning cable.
Mirror iOS Device to Computer via USB
Step 4. Tap “Trust” on your iPhone, and wait a few seconds, you can see the iPhone screen on the computer.
Trust Your Computer on iPhone
How to Mirror iPhone on Windows/PC – AnyMirror
Here is a professional mirror tool you can use – AnyMirror. It allows you to mirror your iPhone on your Windows PC with a few clicks and no technical requirements. These are the features of AnyMirror:
  • AnyMirror supports iPhone/iPad/iPod touch and works well on both Windows and Mac computers.
  • It can mirror multiple phones/tablets with different screens, mics, audio, and cameras at the same time.
  • Automatic landscape mode is supported by AnyMirror. The mirrored screen will automatically rotate with the device.
  • AnyMirror also allows you to record live or take a screenshot and live stream it during mirroring.
Step 1. Download AnyMirror on your computer > Then search AnyMirror in App Store and tap GET to download it on your iPhone/iPad.
Select Function on AnyMirror
Step 2. Launch AnyMirror on the computer and connect your iPhone to Windows with a USB cable > Choose Screen Mirroring on your computer and tap on OK.
Choose Screen Mirroring On Computer
Step 3. Select Screen Mirroring mode on your iPhone > Select USB > Click the Start button >Click Start Broadcast button. When your iPhone is detected successfully by AnyMirror, you can see the iPhone screen on your computer and do anything you want.
Mirror iPhone Screen to Computer Successfully
Please make sure you’ve installed iTunes on the computer to help detect iPhone/iPad.
Mirror iPhone to Your PC Using LonelyScreen
LonelyScreen also enables you to view your current iPhone screen and its content on your computer screen in real-time. It is designed as an AirPlay receiver for PC and Mac. In other words, even though your Mac or PC doesn’t support AirPlay, LonelyScreen can help your computer receive the AirPlay signal. Check these steps below to see how to mirror iPhone to PC using LonelyScreen.
Step 1. Head over to the LonelyScreen website and download and install the software on your computer.
Step 2. At one point during the installation, you will be asked for firewall permissions. Checkmark the first option in the list and click on the Allow access button at the bottom. The software will automatically launch once it is installed.
Allow firewall access to the app
Step 3. On your iPhone, open the Control Center by swiping it up from the bottom of your iPhone’s screen. Then, find and tap on the AirPlay option.
Access the AirPlay option on the iPhone
Step 4. You will see LonelyScreen as one of the AirPlay devices on the list. Tap on it to connect to it.
Choose LonelyScreen from the AirPlay compatible devices
You are all set. Your iPhone screen should now be visible on your computer screen. That is how you do screen mirroring on a Windows 10 PC.
Mirror iPhone to Computer Using Mirroring360
Mirroring360 is yet another software that allows you to view the contents of your iOS-based devices such as your iPhone and iPad on your Windows PC. It works pretty much the same way as the above software but this one is available for more operating systems. See how you can mirror iPhone with Mirroring360.
Step 1. The first thing you are going to need to do is to download the software from the Mirroring360 website. Then, install the software on your system.
Step 2. Once you have got the software up and running on your computer, it is time to configure your iPhone to make the connection. On your device, swipe up from the bottom of your screen to access Control Center. Then, tap on AirPlay.
Screen sharing software #2 - Mirroring360
Screen sharing software #2 – Mirroring360
Step 3. Choose your computer from the AirPlay list. Your iPhone screen will appear on your computer screen.
The procedure establishes the connection between your iPhone and your computer and lets you view the screen contents. If you ever encounter any issues and cannot get it to work, try the Mirroring Assist app from the iOS App Store to troubleshoot the issues.
Use Your PC As an AirPlay Device with AnyTrans
If you have used the above software to mirror your iPhone to your computer, you have noticed that that software is pretty old-fashioned. They do not have all the bells and whistles that you might expect from the software of this day and age.
Fortunately, there is one software that has it all. Enter AnyTrans, which would enable you to use AirPlay on your Windows PC with all the modern features and minimal effort. All that you must have is both of your devices connected to the same WiFi network and you are all set.
Here is how you go about mirroring your iPhone to your Windows PC using the aforementioned software:
Step 1. Head over to the AnyTrans website and download and install the software on your computer.
Step 2. Launch the software on your computer and click on the option that says Screen Mirroring in the left sidebar.
Screen Mirroring with AnyTrans
Step 3. Connect both your Windows PC and your iPhone to the same WiFi network, if they are not already.
Step 4. On your iPhone, swipe up from the bottom to launch Control Center. Tap on the option that says AirPlay and select AnyTrans from the list.
Select AnyTrans on the iPhone to mirror screen to your PC
Your iPhone will connect to the AnyTrans software on your computer. Then, you will be able to view your iPhone screen on your Windows PC. If you notice, all that the app asked you to do was connect your devices to the same network and you were able to get the task done.
FAQs
1. Why do you need to mirror iPhone to Windows PC?
  1. Better gaming experience.
  2. Better audio and video viewing experience.
  3. Participate in online video conferences.
2. Can you mirror iPhone to PC with USB??
YES, you can. Actually, some applications in the market ask you to connect your device to pc or laptop with a USB Cable to share a screen between your iPhone and pc. So, it depends on the application that you are using to share the screen between two devices.
In conclusion, AnyMiro is the ultimate screen mirroring tool for iPhone to PC, offering exceptional performance, a user-friendly interface, and a comprehensive set of features. Experience seamless mirroring, enhanced presentations, and enjoyable gaming on a larger screen by downloading AnyMiro today. Upgrade your mirroring capabilities and unlock a new level of convenience and productivity.
Work for iMobie team for 5 years as well as an Apple fan, love to help more users solve various types of iOS or Android related issues.
