Transfer, backup and manage iOS content in a smart way
Available for both Win & Mac
If you are looking to create a collage of your photos, the following post is all about how you can make photo collages on an iPhone. It lists out some of the best apps you can use to accomplish the task.
If you have multiple photos that you want to combine into one single photo, creating a photo collage will help you do it. A photo collage is basically a mixture of multiple of your photos. You can choose a layout, a color combination, your photos, and various other options to create a stunning collage for your pictures. If you use an iPhone, creating one is even easier.
There are a number of apps that you can use on your iPhone to create various types of collages. Most of these apps allow you to create custom as well as pre-defined collages on your device. The predefined layouts come with their own shapes and sizes, special effects, and so on. These help you quickly turn your photos into some good looking collages. The following are the steps and the apps you can use to do the task on your iPhone.
In order to make a collage on an iPhone, you are going to need to download a collage maker app on your phone. The built-in options on your device do not offer the ability to create a collage.
When it comes to apps for making collages, you are spoiled for choice. There are a number of apps that you can choose from and one of them is Layout by Instagram. This app is extremely easy to use and lets you quickly create any number of collage you want on your iPhone. The following are the steps on how you can use this app to make photo collage on your iPhone.
Step 1. Open the official iOS App Store on your iPhone and search for the app named Layout. When you find the app, download and install it on your iPhone.
Step 2. Launch the app when it is installed. You will immediately see all the photos you have on your iPhone. Select the ones you would like to add to your collage by tapping on them.
Step 3. At the top of your screen, you will find the layouts you can use for your new collage. Swipe to the left to see all the available layouts. Tap on the one you like and it will create a new collage accordingly.
Choose a Layout for Your Collage
Step 4. Once you choose a layout, your collage will open in full-screen mode. You then have various editing tools at the bottom to further enhance your collage. When you find it is good to go live, hit the Save button at the top-right corner of your screen. Your collage will instantly be saved on your device.
Save the Collage to Your iPhone
While the Layout app certainly gets the job done for you, you might want to explore other options as well. As said earlier, there are a number of apps to help you create custom and predefined collages on your iPhone. Here are some of the apps you can trust.
Not only is Google Photos one of the best apps to manage your photo libraries, but it is also one of the best collage makers out there. You can upload an unlimited number of photos with the app and then create a collage using any of your uploaded photos.
Use Google Photos to Create a Collage on the iPhone
It is one of those apps that requires a minimum number of inputs to create a collage. All you basically need to do is select your photos and the app will automatically make a nice collage for you. You can then keep the collage in the app or you can even bring it outside using any of the file manager or gallery apps available on your phone. Creating a collage on an iPhone with Google Photos is one of the easiest things to do. The app offers the following features:
PicCollage is another awesome collage maker available for the iPhone. It comes built with hundreds of collage layouts to choose from. Once you install the app on your device, it is then a simple procedure to create new collages by choosing your favorite grid layouts and applying various effects to your photos.
Create Collages on the iPhone with PicCollage
The app is actually more than just a collage maker. It lets you edit your photos as well using various editing tools it comes preloaded with. You can apply various stickers, backgrounds, and freestyles to the collages you create. You get the following features with the app on your iPhone:
It is a free app with in-app purchases.
If you are someone who heavily relies on templates to create your collages, you are going to love the Adobe Spark Post app for your iPhone. It is an amazing app that comes preloaded with tons of designs for you to choose from. You do not need to stress your mind to think of new ideas as it brings its own cool templates for you to work with.
Create Collages from Templates with Adobe Spark
When you install the app and explore the available designs, you will find that you have pretty much everything you ever needed to create an iPhone wallpaper collage on your device. You have a large number of templates, icons, and backgrounds to work with. Another interesting feature of the app is that it allows you to animate your designs as well. It has several other features as given below:
Canva is actually built to help you create amazing designs on your devices. Making collages is one of the many features of the app and it lets you do this task with ease and efficiency on your iPhone. When you launch the app and begin to create a collage, you will find that there are numerous designs and stock photos available to choose from.
Use Canva to Design and Create iPhone Collages
You can then choose a layout for your collage and add the photos you want. The great thing about this app is it lets you customize almost each and every part of your collage. You can have custom styled text, designs, icons, layouts, and all other things that are part of your collage. It offers the following features to its users:
You can download the app for free and some elements require an in-app purchase.
PicFrame is one of the premium apps to create collages on an iPhone. It lets you combine your photos as well as your videos into single designs and then share these designs with your social media contacts. It has over seventy collage designs to choose from and offers up to nine items per layout.
Create Photo and Video Collages with PicFrame
While you can definitely create some basic collages with the app, it has many more features to create advanced-level collage designs on your iPhone. With support for items like stickers, custom text, custom shapes, and various effects, you can turn your normal photos into some of the really amazing collages that are ever created. Since it is a premium app, it contains several more features than the free alternatives:
The app costs $1.99 on the iOS App Store.
If you are wondering how to go about creating a collage on your iPhone, there are many ways and apps to do it on your phone. The above guide should give you some ideas to get started on the task, and then it is up to your creativity to create some amazing collages on your device.
