How to Fix WhatsApp Won’t Send Pictures on iPhone
Want to send pictures to your friend in WhatsApp on iPhone, but end up with “WhatsApp won’t send pictures on iPhone” problem? Go through this quick guide as here we have covered various methods that can help you to fix this issue.
Author Avatar Joy Taylor Last Updated: Feb. 08, 2022
There is no doubt that WhatsApp is one of the most popular and convenient ways to send pictures to your friends. Sometimes, even most widely-used application like WhatsApp shows problems while sending pictures or messages to others. Recently, many social media networks, such as Instagram, WhatsApp, and Facebook have been out of action for a lot of users worldwide. The first indication of an issue discovered at around 12 p.m. E.T when many uses beginning to report they are not able to sign-in to Facebook. At the same time, many WhatsApp users started reporting that they are not able to send and receive messages and pictures.
So, if you fail to send pictures to your friend in WhatsApp, then it can be this reason why you are not able to do it. But, what if there is another reason for this problem? Here, in this post, we have covered several methods to resolve WhatsApp pictures not sending 2019 issue.
How to Fix WhatsApp Won’t Send Pictures on iPhone?
Here, we are going to show you numerous methods to fix “WhatsApp won’t send pictures on iPhone” problem. So, try out the below-mentioned methods.
Method 1: Turn On and Off Airplane Mode
The first and instant solution to fix the problem you are facing is enabling and disabling Airplane mode. If there is a network problem, then it can be solved by simply turning on and off Airplane mode. Here are simple steps on how you can do this:
Step 1: To begin the process, turn off cellular data or Wi-Fi you are using from your iPhone settings or Control Center.
Step 2: Next, turn on Airplane Mode from Settings or Control Center. Wait for a while, disable Airplane Mode and next, enable the internet connection you are using. Again, try to send pictures in WhatsApp to see if the issue gets resolved or not.
WhatsApp Won't Send Pictures on iPhone via Airplane Mode
WhatsApp Won’t Send Pictures on iPhone via Airplane Mode
Method 2: Check your iPhone Storage Space
Another reason why you are not able to send pictures to others through WhatsApp is due to the lack of storage space on your device. In this case, all you can do is to check your device storage space and if it is insufficient, then you have to free up some space to send pictures in WhatsApp.
Step 1: Navigate to your iPhone “Settings” and next, open the “General” settings.
Step 2: Next, click on “iPhone Storage”. Here, you can free up your device storage app by deleting unnecessary data or apps from your phone.
WhatsApp Won't Send Pictures on iPhone via iPhone Storage
WhatsApp Won’t Send Pictures on iPhone via iPhone Storage
Method 3: Reboot your iPhone
Maybe it is a software problem for which you are facing WhatsApp won’t send pictures on iPhone issue. That’s why the best thing you can do in this case is restarting your iPhone. A simple restart process on your iPhone can solve many minor software issues with ease.
On iPhone 8 or Above:
Hold down and quickly release the volume down button, and follow the same process with volume up button. Next, hold down the power button until you don’t see the Apple logo.
On iPhone 7/7 Plus:
Press and hold down the power and volume down button until you don’t see the Apple logo on your iDevice screen.
On iPhone 6 or Earlier:
Press and hold down the power and home button until you don’t see the Apple logo on your device screen.
Method 4: Reinstall WhatsApp
If there is a problem within the application, then the best way to fix the issue is to uninstall and reinstall the application again. So, uninstall the WhatsApp from your iPhone and then, download and install it again from App Store. It will fix out the many issues related to the WhatsApp application.
Method 5: Reset your iPhone Settings
If all above methods fail to WhatsApp pictures not sending 2019 problem, then the last method you can try is to reset your iPhone settings. In this way, you can solve a lot of minor iOS problems. Also, maybe the WhatsApp problem you are facing now also gets fixed.
Step 1: To commence the process, move to “Settings” on your iPhone and then, click on the “General” option.
Step 2: After that. Click on the “Reset” option and then, tap on the “Erase All Content and Settings” option.
WhatsApp Won't Send Pictures on iPhone via Reset iPhone Settings
WhatsApp Won’t Send Pictures on iPhone via Reset iPhone Settings
That’s how you can fix WhatsApp won’t send pictures on iPhone. Hopefully, you will be able to come out of this issue with this guide. Try out the above-mentioned methods and maybe you able to send pictures in WhatsApp from iPhone to others.
self serviceself service
iMobie Self-Service
reduceclose
customer service
End conversation
