“Unable to Upgrade. An error occurred installing iOS 18 on your iPhone or iPad?” Here in this article, we’ll show you some troubleshooting tips to fix this update problem.
AnyFix handles 150+ iOS/iPadOS/tvOS problems, covering almost all possible scenarios. So you can get back a nicely working Apple device in minutes. Free download AnyFix to 1-click repair your iPhone or iPad.
Aimed at making your iPhone and iPad experience more responsive, faster, and delightful, iOS 18 will be released with powerful AI features. But while installing the new iOS update, some people got an error saying “unable to install update an error occurred installing ios 18”. If you have encountered an error occurred installing new iOS problems, how can you settle these issues? Now let’s follow this tutorial and get 6 simple tips to fix this iOS 18 install error on your iPhone iPad.
One of the reasons why this error occurs is that your iPhone has encountered some iOS system errors. In this case, you cannot update to the new iOS until you have got rid of the problem. You can fix the error by yourself with the help of AnyFix – iOS System Recovery.
AnyFix can repair 150+ common iOS system issues for iPhone, iPad, iPod touch, and Apple TV. When you encounter an error installing iOS, you can turn to AnyFix to get rid of update errors like iOS update not showing up, unable to check for iOS update, can’t download the iOS update, etc. Check some of its main features before using it.
Let’s check out how to resolve the problem with AnyFix.
Step 1. Download and launch AnyFix on your computer > Connect your iPhone/iPad to the computer via a USB cable. Click System Repair panel.
AnyFix System Repair Option
Step 2. After that, you can choose the repair mode displayed below. Then you will go to an interface to download the matching firmware for your device. After downloading successfully, you can fix the issues by clicking the Fix Now button.
AnyFix Standard Repair
Step 3. After a while, the error that occurred installing iOS 18 will be fixed completely.
Repair Is Completed
You can also try to delete and download the new iOS update again. Just go to:
After removing the old iOS installer, and re-downloading, you may be able to successfully get the new update.
There are chances that your network settings cause the problem of “unable to install update an error occurred installing ios 18”. Check your network settings and make sure the cellular network is turned on. You can reset your network settings in Settings > General > Reset Network Settings under the “Reset” tab.
If you are unable to install iOS 18 over the air, then updating your device to the new iOS via iTunes is an option.
Run iTunes > connect your device to iTunes via a USB cable > click on your device > Summary > Check for Update > Download and Update.
Many users will restart their iPhone or iPad in this situation, but what if restarting the device still won’t work? Some users suggest that disabling low-power mode and restarting the device is helpful.
Turn Off Low Power Mode
Your iPhone/iPad may be unable to install iOS 18 due to insufficient storage on iDevices. You can go to Settings > Storage > iPhone Storage to check your available storage and free up space for the new iOS system.
Choose the iPhone Storage option
Downloading and using AnyFix, is quite an easy way to fix the problem of an error that occurred installing iOS. Surely, you can downgrade iOS 18 to the earlier versions of iOS with AnyFix. And if you find this post useful, please share it. You can comment on your ideas on how to solve this issue if you find some better solutions.
